Boujour,
Pouriez-vous rajouter les interrupteurs Aqara model WXKG12LM de chez Xiaomi
Jeedom les détecte bien lors de l’inclusion, mais ce model n’est pas dans la liste des équipements Xiaomi et les commandes sont inopérante.
Merci d’avance !
"ieee": "00:15:8d:00:06:33:89:18",
"nwk": 43646,
"status": 2,
"lqi": "255",
"rssi": "-34",
"last_seen": "1620320281.2623875",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.sensor_switch.aq3",
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"input_clusters": [
"id": 0,
"name": "BasicCluster",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 5
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.sensor_switch.aq3"
"id": 6,
"name": "date_code",
"value": "20180629"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "3000-0001"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 30.6
"id": 33,
"name": "battery_percentage_remaining",
"value": 175
"id": 18,
"name": "MultistateInputCluster",
"attributes": [
"id": 85,
"name": "present_value",
"value": 18
"signature": {
"model": "lumi.sensor_swit",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
0,
1,
18
0,
6
"class": "zhaquirks.xiaomi.aqara.sensor_swit"
