Ajout équipement Zigbee "Commutateur de Relais Intelligent ZigBee à 1 Canal"
Pouvez-vous ajouter l’équipement suivant :
  • Modèle : Commutateur de Relais Intelligent ZigBee à 1 Canal
  • Modèle : ZB-SW01
  • Marque : EACHEN
  • Compatible : Tuya / ewelink
  • Input voltage : DC/AC 7V-32V
  • Max current : 2200W/10A
  • Lien vers site d’achat : amazon
  • Informations brutes :
    "ieee": "00:12:4b:00:22:6b:af:df",
    "nwk": 25455,
    "status": 2,
    "lqi": "255",
    "rssi": "-44",
    "last_seen": "1635271501.1918657",
    "node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "eWeLink",
            "model": "ZB-SW01",
            "output_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 1
                            "id": 1,
                            "name": "app_version",
                            "value": 4
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "eWeLink"
                            "id": 5,
                            "name": "model",
                            "value": "ZB-SW01"
                            "id": 6,
                            "name": "date_code",
                            "value": "20201026"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "1.0.3"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
    "signature": {
        "model": "ZB-SW01",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 0,
            "maximum_buffer_size": 80,
            "maximum_incoming_transfer_size": 160,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 160,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6
                    0
    "class": "zigpy.device"
  • Log DEBUG :
[2021-10-26 20:19:32][DEBUG] : {"devices":{"00:12:4b:00:22:6b:af:df":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-10-26 20:19:32][DEBUG] : Search attribut for 00:12:4b:00:22:6b:af:df logicalId : 1::6::0 => Bool.true convert to 1
[2021-10-26 20:19:32][DEBUG] : {"devices":{"00:12:4b:00:22:6b:af:df":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-10-26 20:19:32][DEBUG] : Search attribut for 00:12:4b:00:22:6b:af:df logicalId : 1::6::0 => Bool.false convert to 0
Merci !
:slight_smile:
Je me permet un petit up! sur ce sujet.
Je scrute régulièrement les MAJ du plugin-zigbee, et il y a chaque semaine des intégration de nouvelles équipements mais celui décrit ci-dessus ?.
Du coup je me demande si j’ai bien fait les choses, si il ne manque pas des infos, ou peut-être dois-je adresse ma demande a l’équipe JEEDOM via un autre biais ?
En // , je me demande si je ne pourrais pas utiliser la conf d’un autre modèle un peu similaire en attendant l’intégration … par exemple celui la :
Merci de vos lumières & bon Week !
Bonjour @Loic,
Peux-tu m’indiquer si ce module sera pris en charge un jour par le plugin #plugin-zigbee.
N’hésites pas a demander si il manque des informations.
Merci de ton aide & bonne Année !
Désolé j’étais passé a coté de la demande, ca sera bon dans la beta de demain
