J’espère que ne louperai pas une info pour mon premier message ![]()
Serait-il possible d’ajouter ce module svp ? J’ai acheté un contrôleur RBGCCT et il n’y a que le RGBCW dans la liste. Merci par avance
Image (la même que le module EWeLink > Controleur LED intelligente RGBCW MR16 [ZB-CL01]
Lien d’achat : Aliexpress https://fr.aliexpress.com/item/1005002295847611.html
Modèle : RGBCCT Controller
D’après le (petit) manuel livré :
Model: YSR-mini-Z-01
Infos brutes :
"ieee": "a4:c1:38:db:3e:37:00:5d",
"nwk": 13301,
"status": 2,
"lqi": "255",
"rssi": "-28",
"last_seen": "1672167517.220729",
"node_descriptor": "01:40:8e:0b:10:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 269,
"profile_id": 260,
"manufacturer": "eWeLight",
"model": "ZB-CL01",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 6
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 0
"id": 4,
"name": "manufacturer",
"value": "eWeLight"
"id": 5,
"name": "model",
"value": "ZB-CL01"
"id": 6,
"name": "date_code",
"value": "20221027"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.0.1"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 228
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 24939
"id": 4,
"name": "current_y",
"value": 24701
"id": 7,
"name": "color_temperature",
"value": 153
"id": 4096,
"name": "LightLink",
"attributes": []
"signature": {
"model": "ZB-CL01",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4107,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 269,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096
"class": "zigpy.device"
DEBUG (il y a un seul bouton dessus, après j’ai utilisé les commandes du modules actuel sur le plugin)
[2022-12-27 20:09:19]DEBUG : {"devices":{"a4:c1:38:db:3e:37:00:5d":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-12-27 20:09:20]DEBUG : Search attribut for a4:c1:38:db:3e:37:00:5d logicalId : 1::6::0 => Bool.true convert to 1
[2022-12-27 20:09:27]DEBUG : {"devices":{"a4:c1:38:db:3e:37:00:5d":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-12-27 20:09:27]DEBUG : Search attribut for a4:c1:38:db:3e:37:00:5d logicalId : 1::6::0 => Bool.false convert to 0
[2022-12-27 20:09:37]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-12-27 20:09:37]DEBUG : {"ieee":"a4:c1:38:db:3e:37:00:5d","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-12-27 20:09:37]DEBUG : {"devices":{"a4:c1:38:db:3e:37:00:5d":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-12-27 20:09:37]DEBUG : Search attribut for a4:c1:38:db:3e:37:00:5d logicalId : 1::6::0 => Bool.true convert to 1
[2022-12-27 20:09:46]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-12-27 20:09:46]DEBUG : {"ieee":"a4:c1:38:db:3e:37:00:5d","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color","await":1,"args":[8970,4326,0]}],"allowQueue":false}
[2022-12-27 20:09:53]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-12-27 20:09:53]DEBUG : {"ieee":"a4:c1:38:db:3e:37:00:5d","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[119,0]}],"allowQueue":false}
[2022-12-27 20:09:54]DEBUG : {"devices":{"a4:c1:38:db:3e:37:00:5d":{"1":{"8":[{"value":"119","cluster_name":"Level control"}]}}}}
[2022-12-27 20:09:54]DEBUG : Search attribut for a4:c1:38:db:3e:37:00:5d logicalId : 1::8::0 => 119 convert to 119
[2022-12-27 20:09:59]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-12-27 20:09:59]DEBUG : {"ieee":"a4:c1:38:db:3e:37:00:5d","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[24,0]}],"allowQueue":false}
[2022-12-27 20:10:03]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-12-27 20:10:03]DEBUG : {"ieee":"a4:c1:38:db:3e:37:00:5d","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[68,0]}],"allowQueue":false}
[2022-12-27 20:10:03]DEBUG : http://127.0.0.1:8089/device/attributes type : POST
[2022-12-27 20:10:25]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-12-27 20:10:25]DEBUG : {"ieee":"a4:c1:38:db:3e:37:00:5d","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[27,0]}],"allowQueue":false}
