J’ai acheté une nouvelle lampe Play Hue de chez philips hue et elle n’est pas reconnue par le plugin. Cette nouvelle lampe Hue a un nouveau numéro de série 440400982841 (et non LCT024 comme les anciennes).
L’image de fond PNG est la meme que celle du Hue Play LCT024.png du plugin Hue.
Le log avec les attributs
2022-01-19 22:57:56]DEBUG : Found light model : 440400982841
[2022-01-19 22:57:56]DEBUG : No configuration found for light : 440400982841 => {"id":54,"attributes":{"state":{"on":true,"bri":253,"hue":51281,"sat":254,"effect":"none","xy":[0.2752,0.1066],"ct":153,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"readytoinstall","lastinstall":"2022-01-19T08:06:18"},"type":"Extended color light","name":"Hue Play 2 salon","modelid":"440400982841","manufacturername":"Signify Netherlands B.V.","productname":"Hue Play","capabilities":{"certified":true,"control":{"mindimlevel":100,"maxlumen":560,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"hueplay","function":"decorative","direction":"upwards","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:09:ec:27:c7-0b","swversion":"1.93.3","swconfigid":"EFC4F45E","productid":"3241-3127-7871_HC04_PSG03"},"client":{}}
Je l’ai intégre en dupliquant l’autre modele mais si tu peux la mettre officiellement ca m’évites de gerer des fichiers à mettre à jour
EDIT DU POST : Merci
