Ajout Door/Window sensor ZM-CG205
Je n’ai pas trouvé l’équipement compatible à ce module ZM-CG205 lors de l’intégration dans Zigbee.
Capteur d’ouverture ZM-CG205
ZM-GC205
Pourriez-vous svp ajouter ce module dans la liste des équipements du plugin ?
Dans tous les cas merci.
Informations brutes
    "ieee": "a4:c1:38:31:50:ef:b9:f3",
    "nwk": 45006,
    "status": 2,
    "lqi": "84",
    "rssi": "-79",
    "last_seen": "1644421358.022655",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1026,
            "profile_id": 260,
            "manufacturer": "_TZ3000_26fmupbb",
            "model": "TS0203",
            "output_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": []
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 16,
                            "name": "cie_addr",
                            "value": [
                                247,
                                156,
                                119,
                                254,
                                255,
                                80,
                                75,
                                128
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 69
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_26fmupbb"
                            "id": 5,
                            "name": "model",
                            "value": "TS0203"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
    "signature": {
        "model": "TS0203",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    1,
                    3,
                    1280,
                    0
                    3,
                    4,
                    5,
                    6,
                    8,
                    4096,
                    25,
                    10
    "class": "zigpy.device"
Log Debug
[2022-02-09 17:04:44][DEBUG] : {"devices":{"a4:c1:38:31:50:ef:b9:f3":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2022-02-09 17:04:44][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1 convert to 1
[2022-02-09 17:04:44][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2022-02-09 17:04:44][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2022-02-09 17:04:44][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
[2022-02-09 17:04:47][DEBUG] : {"devices":{"a4:c1:38:31:50:ef:b9:f3":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.0","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2022-02-09 17:04:47][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1 => ZoneStatus.0 convert to 0
[2022-02-09 17:04:47][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
[2022-02-09 17:04:47][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1.2 => 0 convert to 0
[2022-02-09 17:04:47][DEBUG] : Search command for a4:c1:38:31:50:ef:b9:f3 logicalId : 1::1280::cmd::1.3 => 0 convert to 0
Intégration possible après plusieurs tentatives avec TS0203 (il y a 2 possibilités de TS0203) dans la liste.
Merci au plugin Zigbee !
