Finalement, je suis allé faire un petit tour par chatgpt pour lui demander s’il pouvait prendre en compte la date de début de range pour la fonction public function calculOccurrence($_startDate, $_endDate, $_max = 9999999999, $_recurence = 0) (ligne 630 /plugins/calendar/core/class/calendar.class.php) et j’obtiens un résultat assez probant !
A tester en beta peut-etre
J’espère que ça pourra aider
public function calculOccurrence($_startDate, $_endDate, $_max = 9999999999, $_recurence = 0) {
if ($_recurence > 5) {
return [];
$_recurence++;
$startTime = $_startDate ? strtotime($_startDate) : strtotime('now - 2 year');
$endTime = $_endDate ? strtotime($_endDate) : strtotime('now + 2 year');
$_beginDate = $_startDate ? new DateTime($_startDate) : new DateTime($this->getStartDate());
$return = [];
$repeat = $this->getRepeat();
if ($repeat['enable'] != 1) {
return $this->handleNonRepeatingEvent($startTime, $endTime);
$excludeDate = $this->getExcludedDates($repeat, $_startDate, $_endDate, $_max, $_recurence);
$currentDate = $_beginDate;
$initStartTime = $this->getTimePart($this->getStartDate());
$initEndTime = $this->getTimePart($this->getEndDate());
while ($this->shouldContinue($currentDate, $startTime, $endTime, $repeat)) {
$formattedDate = $currentDate->format('Y-m-d');
if ($this->isDateIncluded($formattedDate, $repeat, $excludeDate) && $this->matchesNationalDayCriteria($formattedDate, $repeat)) {
$return[] = [
'start' => $currentDate->format('Y-m-d') . ' ' . $initStartTime,
'end' => $currentDate->format('Y-m-d') . ' ' . $initEndTime,
if (count($return) >= $_max) {
return $return;
$currentDate = $this->calculateNextOccurrence($currentDate, $repeat, $initStartTime, $initEndTime);
return $this->mergeIncludeDates($return, $repeat, $startTime, $endTime, $initStartTime, $initEndTime);
private function matchesNationalDayCriteria($date, $repeat) {
$nationalDays = self::getNationalDay(date('Y', strtotime($date)));
switch ($repeat['nationalDay']) {
case 'exeptNationalDay':
return !in_array($date, $nationalDays);
case 'onlyNationalDay':
return in_array($date, $nationalDays);
case 'onlyEven':
return (date('W', strtotime($date)) % 2) == 0;
case 'onlyOdd':
return (date('W', strtotime($date)) % 2) == 1;
case 'all': // 'all' means no filter on national day
default:
return true;
private function handleNonRepeatingEvent($startTime, $endTime) {
if ($this->isEventWithinBounds($startTime, $endTime)) {
return [[
'start' => $this->getStartDate(),
'end' => $this->getEndDate(),
return [];
private function getExcludedDates($repeat, $_startDate, $_endDate, $_max, $_recurence) {
$excludeDate = [];
if (!empty($repeat['excludeDate'])) {
$excludeDate = array_merge($excludeDate, $this->parseExcludeDates($repeat['excludeDate']));
if (!empty($repeat['excludeDateFromCalendar'])) {
$excludeDate = array_merge($excludeDate, $this->getExcludeDatesFromCalendar($repeat, $_startDate, $_endDate, $_max, $_recurence));
return $excludeDate;
private function parseExcludeDates($excludeDateString) {
$excludeDate = [];
foreach (explode(',', $excludeDateString) as $date) {
$dateRange = explode(':', $date);
if (count($dateRange) === 2) {
$excludeDate = array_merge($excludeDate, $this->generateDateRange($dateRange[0], $dateRange[1]));
} else {
$excludeDate[] = date('Y-m-d', strtotime($date));
private function getExcludeDatesFromCalendar($repeat, $_startDate, $_endDate, $_max, $_recurence) {
$excludeDates = [];
$calendar = calendar::byId($repeat['excludeDateFromCalendar']);
if (is_object($calendar)) {
$events = $this->getEventsFromCalendar($calendar, $repeat);
foreach ($events as $event) {
$occurrences = $event->calculOccurrence($_startDate, $_endDate, $_max, $_recurence);
foreach ($occurrences as $occurrence) {
$excludeDates = array_merge($excludeDates, $this->generateDateRange($occurrence['start'], $occurrence['end']));
return $excludeDates;
private function generateDateRange($start, $end) {
$dates = [];
$startDate = new DateTime($start);
$endDate = new DateTime($end);
while ($startDate <= $endDate) {
$dates[] = $startDate->format('Y-m-d');
$startDate->modify('+1 day');
return $dates;
private function shouldContinue($currentDate, $startTime, $endTime, $repeat) {
$until = strtotime($this->getUntil());
return ($until === false || $currentDate->getTimestamp() < $until) && $currentDate->getTimestamp() <= $endTime;
private function isDateIncluded($date, $repeat, $excludeDate) {
return !in_array($date, $excludeDate) && $repeat['excludeDay'][date('N', strtotime($date))] == 1;
private function calculateNextOccurrence($currentDate, $repeat, $initStartTime, $initEndTime) {
if (isset($repeat['mode']) && $repeat['mode'] === 'advance') {
// Calculate next occurrence based on "advance" rules.
$nextMonth = date('F', strtotime('+1 month ' . $currentDate->format('Y-m-d')));
$year = date('Y', strtotime('+1 month ' . $currentDate->format('Y-m-d')));
$nextDate = date('Y-m-d', strtotime($repeat['positionAt'] . ' ' . $repeat['day'] . ' of ' . $nextMonth . ' ' . $year));
if ($nextDate === '1970-01-01') {
return $currentDate; // Prevent infinite loop if an invalid date is calculated.
return new DateTime($nextDate . ' ' . $initStartTime);
// Regular recurrence based on frequency and unit.
$freq = $repeat['freq'];
$unit = $repeat['unite'];
return $currentDate->modify("+$freq $unit");
private function mergeIncludeDates($occurrences, $repeat, $startTime, $endTime, $initStartTime, $initEndTime) {
$includeDates = $this->getIncludeDates($repeat, $startTime, $endTime);
foreach ($includeDates as $includeDate) {
$includeStart = $includeDate . ' ' . $initStartTime;
$includeEnd = $includeDate . ' ' . $initEndTime;
$isDuplicate = false;
if ($occurrence['start'] === $includeStart && $occurrence['end'] === $includeEnd) {
$isDuplicate = true;
break;
if (!$isDuplicate) {
$occurrences[] = [
'start' => $includeStart,
'end' => $includeEnd,
usort($occurrences, function ($a, $b) {
return strtotime($a['start']) - strtotime($b['start']);
return $occurrences;
private function getIncludeDates($repeat, $startTime, $endTime) {
$includeDates = [];
// Directly specified include dates
if (!empty($repeat['includeDate'])) {
$rawIncludeDates = explode(',', trim($repeat['includeDate'], ','));
foreach ($rawIncludeDates as $rawDate) {
if (strpos($rawDate, ':') !== false) {
list($rangeStart, $rangeEnd) = explode(':', $rawDate);
$this->addDateRange($rangeStart, $rangeEnd, $includeDates, $startTime, $endTime);
} else {
$this->addSingleDate($rawDate, $includeDates, $startTime, $endTime);
// Include dates from calendar events
if (!empty($repeat['includeDateFromCalendar'])) {
$calendar = calendar::byId($repeat['includeDateFromCalendar']);
$events = $repeat['includeDateFromEvent'] === 'all'
? self::getEventsByEqLogic($calendar->getId())
: [self::byId($repeat['includeDateFromEvent'])];
if (is_object($event) && $event->getId() !== $this->getId()) {
$eventOccurrences = $event->calculOccurrence(null, null);
foreach ($eventOccurrences as $occurrence) {
$this->addDateRange($occurrence['start'], $occurrence['end'], $includeDates, $startTime, $endTime);
return $includeDates;
private function addDateRange($start, $end, &$dates, $startTime, $endTime) {
$startDate = strtotime($start);
$endDate = strtotime($end);
if ($startDate >= $startTime && $startDate <= $endTime) {
$dates[] = date('Y-m-d', $startDate);
$startDate = strtotime('+1 day', $startDate);
private function addSingleDate($date, &$dates, $startTime, $endTime) {
$timestamp = strtotime($date);
if ($timestamp >= $startTime && $timestamp <= $endTime) {
$dates[] = date('Y-m-d', $timestamp);
private function getTimePart($dateTime) {
return date('H:i:s', strtotime($dateTime));
private function isEventWithinBounds($startTime, $endTime) {
return strtotime($this->getStartDate()) <= $endTime && strtotime($this->getEndDate()) >= $startTime;
