Hier j’ai du faire une copie de mon SSD vers un autre SSD.
J’ai terminé l’opération vers 2h00 du matin du coup ce matin j’ai toujours la courbe de Production du 4 janvier !
Petit surprise aussi le plugin n’apparait plus dans la catégorie Energie de mon Jeedom.
0926|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 16:00:00 -> 856 W
0927|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 17:00:00 -> 36 W
0928|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 18:00:00 -> 0 W
0929|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 19:00:00 -> 0 W
0930|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 20:00:00 -> 0 W
0931|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 21:00:00 -> 0 W
0932|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 22:00:00 -> 0 W
0933|[2024-01-05 08:45:06]DEBUG : d0_fullday_prev 2024-01-05 23:00:00 -> 0 W
0934|[2024-01-05 08:45:06]DEBUG : Total : d1 --> 3796 W
0935|[2024-01-05 08:45:06]DEBUG : Total10 : d1 --> 854 W
0936|[2024-01-05 08:45:06]DEBUG : Total90 : d1 --> 9968 W
0937|[2024-01-05 08:45:06]DEBUG : Total : d2 --> 3236 W
0938|[2024-01-05 08:45:06]DEBUG : Total10 : d2 --> 470 W
0939|[2024-01-05 08:45:06]DEBUG : Total90 : d2 --> 9584 W
0940|[2024-01-05 08:45:06]DEBUG : Stockage des données "pv" : [{"estimate":{"5":0,"6":0,"7":0,"8":0,"9":15,"10":205,"11":1069,"12":1674,"13":2069,"14":2050,"15":1727,"16":856,"17":36,"18":0,"19":0,"20":0,"21":0,"22":0},"estimate10":{"5":0,"6":0,"7":0,"8":0,"9":15,"10":195,"11":1030,"12":983,"13":830,"14":696,"15":443,"16":135,"17":10,"18":0,"19":0,"20":0,"21":0,"22":0},"estimate90":{"5":0,"6":0,"7":0,"8":0,"9":15,"10":215,"11":1132,"12":2093,"13":2714,"14":2964,"15":2786,"16":1964,"17":161,"18":0,"19":0,"20":0,"21":0,"22":0}},{"estimate":{"5":0,"6":0,"7":0,"8":0,"9":11,"10":202,"11":522,"12":735,"13":769,"14":727,"15":556,"16":248,"17":26,"18":0,"19":0,"20":0,"21":0,"22":0},"estimate10":{"5":0,"6":0,"7":0,"8":0,"9":5,"10":57,"11":124,"12":150,"13":140,"14":145,"15":140,"16":83,"17":10,"18":0,"19":0,"20":0,"21":0,"22":0},"estimate90":{"5":0,"6":0,"7":0,"8":0,"9":16,"10":224,"11":964,"12":1565,"13":1889,"14":1981,"15":1727,"16":1500,"17":102,"18":0,"19":0,"20":0,"21":0,"22":0}},{"estimate":{"5":0,"6":0,"7":0,"8":0,"9":11,"10":182,"11":438,"12":620,"13":646,"14":620,"15":473,"16":219,"17":27,"18":0,"19":0,"20":0,"21":0,"22":0},"estimate10":{"5":0,"6":0,"7":0,"8":0,"9":0,"10":53,"11":102,"12":91,"13":64,"14":53,"15":59,"16":43,"17":5,"18":0,"19":0,"20":0,"21":0,"22":0},"estimate90":{"5":0,"6":0,"7":0,"8":0,"9":16,"10":279,"11":925,"12":1448,"13":1745,"14":1827,"15":1678,"16":1520,"17":146,"18":0,"19":0,"20":0,"21":0,"22":0}}]
0941|[2024-01-05 08:45:06]DEBUG : Stockage des données "pv_reliability" : [{"5":{"ecart":0,"percent":100},"6":{"ecart":0,"percent":100},"7":{"ecart":0,"percent":100},"8":{"ecart":0,"percent":100},"9":{"ecart":0,"percent":100},"10":{"ecart":20,"percent":50},"11":{"ecart":102,"percent":38},"12":{"ecart":1110,"percent":62},"13":{"ecart":1884,"percent":66},"14":{"ecart":2268,"percent":60},"15":{"ecart":2343,"percent":55},"16":{"ecart":1829,"percent":39},"17":{"ecart":151,"percent":17},"18":{"ecart":0,"percent":100},"19":{"ecart":0,"percent":100},"20":{"ecart":0,"percent":100},"21":{"ecart":0,"percent":100},"22":{"ecart":0,"percent":100}}]
0942|[2024-01-05 08:45:06]DEBUG : --- Création ou mise à jour des commandes pour PV witry les Reims---
0943|[2024-01-05 08:45:06]INFO : // Fin du traitement du site PV witry les Reims //
0944|[2024-01-05 08:59:45]DEBUG : #####---------------------------------------------------------#####
0945|[2024-01-05 08:59:45]INFO : [template] Affichage du template pour PV witry les Reims [START]
0946|[2024-01-05 08:59:45]DEBUG : [template] Heures ajustées : 9 17
0947|[2024-01-05 08:59:45]DEBUG : [template] json_array_pv_reliability : [{"5":{"ecart":0,"percent":100},"6":{"ecart":0,"percent":100},"7":{"ecart":0,"percent":100},"8":{"ecart":0,"percent":100},"9":{"ecart":0,"percent":100},"10":{"ecart":20,"percent":50},"11":{"ecart":102,"percent":38},"12":{"ecart":1110,"percent":62},"13":{"ecart":1884,"percent":66},"14":{"ecart":2268,"percent":60},"15":{"ecart":2343,"percent":55},"16":{"ecart":1829,"percent":39},"17":{"ecart":151,"percent":17},"18":{"ecart":0,"percent":100},"19":{"ecart":0,"percent":100},"20":{"ecart":0,"percent":100},"21":{"ecart":0,"percent":100},"22":{"ecart":0,"percent":100}}]
0948|[2024-01-05 08:59:45]DEBUG : [template] Fiabilité de la prévision à J+0 : 55%
0949|[2024-01-05 08:59:45]DEBUG : [template] Indice de fiabilité de la prévision à J+0 : 1/4
0950|[2024-01-05 08:59:45]DEBUG : [template] d0_percent_number_prod_forecast : 0
0951|[2024-01-05 08:59:45]DEBUG : [template] Fiabilité de la prévision à J+1 : 32%
0952|[2024-01-05 08:59:45]DEBUG : [template] json_array_prod_watt_hours : {"lastvalue":0,"00":0,"01":0,"02":-6166,"03":0,"04":0,"05":0,"06":0,"07":0,"08":0,"09":3,"10":279,"11":1135,"12":1060,"13":1512,"14":1165,"15":622,"16":305,"17":85}
0953|[2024-01-05 08:59:45]DEBUG : [template] json_array_forecast_6h : {"6":0,"7":0,"8":0,"9":15,"10":284,"11":939,"12":1612,"13":2069,"14":2050,"15":1727,"16":856,"17":36,"18":0,"19":0,"20":0,"21":0,"22":0}
0954|[2024-01-05 08:59:45]DEBUG : [template] dataForecast : 0, 15, 205, 1069, 1674, 2069, 2050, 1727, 856, 36
0955|[2024-01-05 08:59:45]DEBUG : [template] dataForecast6h : 0, 15, 284, 939, 1612, 2069, 2050, 1727, 856, 36
0956|[2024-01-05 08:59:45]DEBUG : [template] json_array_watt_month : {"prev":{"01":5030,"02":1781,"03":4447},"prev6h":{"01":5771,"02":2412,"03":5213},"prod":{"01":5627,"02":663,"03":7396}}
0957|[2024-01-05 08:59:45]DEBUG : [template] json_array_watt_year : {"prev":{"06":"500000","07":698449,"08":994916,"09":895280,"10":543113,"11":262423,"12":153176,"01":11258},"prev6h":{"06":0,"07":690935,"08":1071865,"09":919736,"10":561674,"11":257663,"12":172863,"01":13396},"prod":{"06":"438000","07":618241,"08":921394,"09":868060,"10":"512000","11":236033,"12":"152000","01":13686}}
0958|[2024-01-05 08:59:45]INFO : [template] Affichage du template pour PV witry les Reims [END]
0959|[2024-01-05 08:59:45]DEBUG : #####---------------------------------------------------------#####
0960|[2024-01-05 09:01:40]DEBUG : --- Création ou mise à jour des commandes pour PV witry les Reims---
0961|[2024-01-05 09:01:40]DEBUG : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=solcast function=remove callInstallFunction=1
0962|[2024-01-05 09:01:53]INFO : Début d'activation du plugin
0963|[2024-01-05 09:01:54]INFO : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
0964|[2024-01-05 09:01:54]DEBUG : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=solcast function=install callInstallFunction=1
0965|[2024-01-05 09:02:03]DEBUG : PV witry les Reims ->
0966|[2024-01-05 09:02:03]DEBUG : cfg_isGlobalEquipement : 0
0967|[2024-01-05 09:02:03]DEBUG : cfg_GlobalEquipement : 0
0968|[2024-01-05 09:02:03]INFO : // Début du traitement du site PV witry les Reims //
0969|[2024-01-05 09:02:03]DEBUG : getInformations cfg_resource_id : 197d-d439-ff5b-4301
0970|[2024-01-05 09:02:03]DEBUG : getInformations cfg_api_key (length) : 32
0971|[2024-01-05 09:02:03]DEBUG : getInformations cfg_bypassAPI : 0
0972|[2024-01-05 09:02:03]DEBUG : getInformations cfg_email (length) : 0
0973|[2024-01-05 09:02:03]DEBUG : getInformations cfg_password (length) : 0
0974|[2024-01-05 09:02:03]DEBUG : getInformations cfg_selectNBJourPrevision : 3
0975|[2024-01-05 09:02:03]DEBUG : getInformations cfg_selectStartPrevision : 5
0976|[2024-01-05 09:02:03]DEBUG : getInformations cfg_selectEndPrevision : 22
0977|[2024-01-05 09:02:03]DEBUG : getInformations cfg_CmdRefreshDataFrequency 2
0978|[2024-01-05 09:02:03]DEBUG : getInformations cfg_isGlobalEquipement 0
0979|[2024-01-05 09:02:03]DEBUG : target_day : 2
0980|[2024-01-05 09:02:03]DEBUG : limit_target_day : 0
0981|[2024-01-05 09:02:03]DEBUG : UTC offset : 1
0982|[2024-01-05 09:02:03]INFO : // Fin du traitement du site PV witry les Reims //
Je pense qu’il faille attendre 24 heures !
