J’ai fait l’acquisition d’un pack pour avoir un accès VPN et impossible de le faire fonctionner !
Il a eu fonctionné tant que je n’ai pas changer le nom du dns, puis plus rien maintenant.
pourtant, le VPN est bien up :
les logs m’indiquent bien que la sequence d’initialisaiton est complete :
0000|2023-09-19 20:33:09 WARNING Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
0001|2023-09-19 20:33:09 --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
0002|2023-09-19 20:33:09 WARNING file '/tmp/jeedom/openvpn/openvpn_auth_dmkhOAHHlsceH1gZGEaYa6uC1dsjGg.conf' is group or others accessible
0003|2023-09-19 20:33:09 OpenVPN 2.5.1 aarch64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2021
0004|2023-09-19 20:33:09 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10
0005|2023-09-19 20:33:09 WARNING No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
0006|2023-09-19 20:33:09 TCP/UDP: Preserving recently used remote address: [AF_INET]51.159.140.130:1197
0007|2023-09-19 20:33:09 UDP link local: (not bound)
0008|2023-09-19 20:33:09 UDP link remote: [AF_INET]51.159.140.130:1197
0009|2023-09-19 20:33:10 VERIFY OK: depth=1, C=FR, ST=IDF, L=Paris, O=jeedom.com, OU=jeedom.com, CN=jeedom.com CA, name=jeedom, emailAddress=postmaster@jeedom.com
0010|2023-09-19 20:33:10 VERIFY OK: depth=0, C=FR, ST=IDF, L=Paris, O=jeedom.com, OU=jeedom.com, CN=server, name=jeedom, emailAddress=postmaster@jeedom.com
0011|2023-09-19 20:33:10 WARNING 'link-mtu' is used inconsistently, local='link-mtu 1542', remote='link-mtu 1342'
0012|2023-09-19 20:33:10 WARNING 'tun-mtu' is used inconsistently, local='tun-mtu 1500', remote='tun-mtu 1300'
0013|2023-09-19 20:33:10 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 1024 bit RSA
0014|2023-09-19 20:33:10 [server] Peer Connection Initiated with [AF_INET]51.159.140.130:1197
0015|2023-09-19 20:33:10 Data Channel: using negotiated cipher 'AES-256-GCM'
0016|2023-09-19 20:33:10 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
0017|2023-09-19 20:33:10 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
0018|2023-09-19 20:33:10 TUN/TAP device tun0 opened
0019|2023-09-19 20:33:10 net_iface_mtu_set: mtu 1500 for tun0
0020|2023-09-19 20:33:10 net_iface_up: set tun0 up
0021|2023-09-19 20:33:10 net_addr_ptp_v4_add: 10.12.34.134 peer 10.12.34.133 dev tun0
0022|2023-09-19 20:33:10 WARNING this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
0023|2023-09-19 20:33:10 Initialization Sequence Completed
et coté market, c’est aussi le bon DNS qui m’est porposé
J’ai redémarré le vpn, rebooter le Jeedom, mais rien n’y fait
Norbert
