J’adorerais pourvoir utiliser ce plugin, mais pour ma part j’ai droit à un 500 : Internal Server Error…
J’ai visiblement un problème sur la valeur attendu du SSID :
[2020-10-04 11:45:39][INFO] : Evènement sur la commande [Divers Média][FlyBox (Routeur Orange)][SSID] valeur : [{"WifiMac":"44:59:E3:E5:EC:70","WifiWep128Key3":null,"WifiWpaencryptionmodes":"MIX","WifiWepKey1":null,"MixWifiWpapsk":null,"WifiWpapsk":null,"wifiguestofftime":"0","WifiWep128Key1":null,"WifiWep128Key2":null,"WifiBroadcast":"0","WifiSsid":"Orange-EC70","WifiWep128Key4":null,"WifiAuthmode":"WPA\/WPA2-PSK","WifiRadiusKey":null,"WifiEnable":"1","Index":"0","WifiWepKey4":null,"WifiWepKeyIndex":"1","ID":"InternetGatewayDevice.X_Config.Wifi.Radio.1.Ssid.1.","WifiWepKey2":null,"wifiisguestnetwork":"0","WifiWepKey3":null},{"WifiMac":"44:59:E3:E5:EC:71","WifiWep128Key3":null,"WifiWpaencryptionmodes":"MIX","WifiWepKey1":null,"MixWifiWpapsk":null,"WifiWpapsk":null,"wifiguestofftime":"0","WifiWep128Key1":null,"WifiWep128Key2":null,"WifiBroadcast":"0","WifiSsid":"Orange-Guest-EC70","WifiWep128Key4":null,"WifiAuthmode":"WPA\/WPA2-PSK","WifiRadiusKey":null,"WifiEnable":"0","Index":"1","WifiWepKey4":null,"WifiWepKeyIndex":"1","ID":"InternetGatewayDevice.X_Config.Wifi.Radio.1.Ssid.2.","WifiWepKey2":null,"wifiisguestnetwork":"1","WifiWepKey3":null},{"WifiMac":"44:59:E3:E5:EC:72","WifiWep128Key3":null,"WifiWpaencryptionmodes":"MIX","WifiWepKey1":null,"MixWifiWpapsk":null,"WifiWpapsk":null,"wifiguestofftime":"0","WifiWep128Key1":null,"WifiWep128Key2":null,"WifiBroadcast":"0","WifiSsid":"Orange-EC70","WifiWep128Key4":null,"WifiAuthmode":"WPA\/WPA2-PSK","WifiRadiusKey":null,"WifiEnable":"1","Index":"2","WifiWepKey4":null,"WifiWepKeyIndex":"1","ID":"InternetGatewayDevice.X_Config.Wifi.Radio.2.Ssid.1.","WifiWepKey2":null,"wifiisguestnetwork":"0","WifiWepKey3":null},{"WifiMac":"44:59:E3:E5:EC:73","WifiWep128Key3":null,"WifiWpaencryptionmodes":"MIX","WifiWepKey1":null,"MixWifiWpapsk":null,"WifiWpapsk":null,"wifiguestofftime":"0","WifiWep128Key1":null,"WifiWep128Key2":null,"WifiBroadcast":"0","WifiSsid":"Orange-Guest-EC70","WifiWep128Key4":null,"WifiAuthmode":"WPA\/WPA2-PSK","WifiRadiusKey":null,"WifiEnable":"0","Index":"3","WifiWepKey4":null,"WifiWepKeyIndex":"1","ID":"InternetGatewayDevice.X_Config.Wifi.Radio.2.Ssid.2.","WifiWepKey2":null,"wifiisguestnetwork":"1","WifiWepKey3":null}]
Une idée de ce que je pourrais faire ?
