2 PHP Notices relative à Airzone dans le log cron_execution
Le plugin fonctionne mais j’ai toujours ces 2 messages dans le log cron_execution
0000|PHP Notice:  Undefined variable: typeCmd in /var/www/html/plugins/airzone/core/class/airzone.class.php on line 707
0001|PHP Notice:  Undefined variable: typeCmd in /var/www/html/plugins/airzone/core/class/airzone.class.php on line 707
0003|PHP Notice:  Array to string conversion in /var/www/html/plugins/airzone/core/class/airzone.class.php on line 735
0004|PHP Notice:  Undefined variable: typeCmd in /var/www/html/plugins/airzone/core/class/airzone.class.php on line 707
0005|PHP Notice:  Array to string conversion in /var/www/html/plugins/airzone/core/class/airzone.class.php on line 735
Une idée du pb ?
le log aizone en debug tout semble ok
0613|}
0614|[2026-01-11 17:50:05] INFO  Requete demandée :  info  1  3
0615|[2026-01-11 17:50:05] INFO  ||┌── Rafraichissement des commandes pour Climatisation Aizone AC10 ──
0616|[2026-01-11 17:50:05] INFO  ||┌── Données recues {"data":[{"systemID":1,"zoneID":3,"name":"Bureau","thermos_type":2,"thermos_firmware":"3.68","thermos_radio":0,"on":1,"double_sp":0,"coolsetpoint":21,"coolmaxtemp":30,"coolmintemp":15,"heatsetpoint":21,"heatmaxtemp":30,"heatmintemp":15,"maxTemp":30,"minTemp":15,"setpoint":21,"roomTemp":19.6,"sleep":0,"temp_step":0.5,"mode":3,"speed":0,"coldStage":1,"heatStage":1,"coldStages":1,"heatStages":1,"humidity":41,"units":0,"errors":[],"air_demand":1,"floor_demand":0,"cold_demand":0,"heat_demand":1,"aq_mode":2,"aq_quality":2,"aq_thrlow":12,"aq_thrhigh":50,"heatangle":0,"coldangle":0,"master_zoneID":1,"eco_adapt":"off","antifreeze":0,"window_external_source":0}]} ──
0617|[2026-01-11 17:50:05] INFO  ||┌── UPDATE DATA ACTION ──
0618|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : on  VALEUR 1 ──
0619|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : setpoint  VALEUR 21 ──
0620|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : roomTemp  VALEUR 19.6 ──
0621|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : mode  VALEUR 3 ──
0622|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : coldStage  VALEUR 1 ──
0623|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : heatStage  VALEUR 1 ──
0624|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : humidity  VALEUR 41 ──
0625|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : errors  VALEUR Array ──
0626|[2026-01-11 17:50:05] INFO  ||┌── Données rafraichies sur  Climatisation Aizone AC10 :   CMD : air_demand  VALEUR 1 ──
0627|[2026-01-11 17:50:05] DEBUG  REPONSE REQUETE : SUCCESS :  {
0628|"data":	[{
0629|"systemID":	1,
0630|"zoneID":	3,
0631|"name":	"Bureau",
0632|"thermos_type":	2,
0633|"thermos_firmware":	"3.68",
0634|"thermos_radio":	0,
0635|"on":	1,
0636|"double_sp":	0,
0637|"coolsetpoint":	21,
0638|"coolmaxtemp":	30,
0639|"coolmintemp":	15,
0640|"heatsetpoint":	21,
0641|"heatmaxtemp":	30,
0642|"heatmintemp":	15,
0643|"maxTemp":	30,
0644|"minTemp":	15,
0645|"setpoint":	21,
0646|"roomTemp":	19.6,
0647|"sleep":	0,
0648|"temp_step":	0.5,
0649|"mode":	3,
0650|"speed":	0,
0651|"coldStage":	1,
0652|"heatStage":	1,
0653|"coldStages":	1,
0654|"heatStages":	1,
0655|"humidity":	41,
0656|"units":	0,
0657|"errors":	[],
0658|"air_demand":	1,
0659|"floor_demand":	0,
0660|"cold_demand":	0,
0661|"heat_demand":	1,
0662|"aq_mode":	2,
0663|"aq_quality":	2,
0664|"aq_thrlow":	12,
0665|"aq_thrhigh":	50,
0666|"heatangle":	0,
0667|"coldangle":	0,
0668|"master_zoneID":	1,
0669|"eco_adapt":	"off",
0670|"antifreeze":	0,
0671|"window_external_source":	0
0672|}]
0673|}
Ca c’est le bug que j’ai fixé dans la dernière beta (qui n’a pas suffit à ce que le refresh des commandes fonctionne)
