J’ai un problème de timeout avec un module ZXT-120 . Quand j’essaye de lancer une commande OFF, j’ai pratiquement que des timeouts :
2021-10-27 13:58:11.492 Info, Node057, Value::Set - COMMAND_CLASS_THERMOSTAT_MODE - Mode - 0 - 1 - Off
2021-10-27 13:58:11.492 Detail, Node057, Queuing (Send) ThermostatModeCmd_Set (Node=57): 0x01, 0x0a, 0x00, 0x13, 0x39, 0x03, 0x40, 0x01, 0x00, 0x25, 0x0a, 0xb2
2021-10-27 13:58:11.492 Detail, Node057, Queuing (Refresh) ThermostatModeCmd_Get (Node=57): 0x01, 0x09, 0x00, 0x13, 0x39, 0x02, 0x40, 0x02, 0x25, 0x0b, 0xb2
2021-10-27 13:58:11.492 Info, Node057, Sending (Send) message (Callback ID=0x0a, Expected Reply=0x13) - ThermostatModeCmd_Set (Node=57): 0x01, 0x0a, 0x00, 0x13, 0x39, 0x03, 0x40, 0x01, 0x00, 0x25, 0x0a, 0xb2
2021-10-27 13:58:11.503 Detail, Node057, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2021-10-27 13:58:11.503 Detail, Node057, ZW_SEND_DATA delivered to Z-Wave stack
2021-10-27 13:58:11.520 Detail, Node057, Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x00, 0x00, 0x02, 0xe3
2021-10-27 13:58:11.520 Detail, Node057, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2021-10-27 13:58:11.520 Info, Node057, Request RTT 27 Average Request RTT 27
2021-10-27 13:58:11.520 Detail, Expected callbackId was received
2021-10-27 13:58:11.520 Detail, Expected reply was received
2021-10-27 13:58:11.520 Detail, Message transaction complete
2021-10-27 13:58:11.520 Detail, Node057, Removing current message
2021-10-27 13:58:11.520 Info, Node057, Sending (Refresh) message (Callback ID=0x0b, Expected Reply=0x04) - ThermostatModeCmd_Get (Node=57): 0x01, 0x09, 0x00, 0x13, 0x39, 0x02, 0x40, 0x02, 0x25, 0x0b, 0xb2
2021-10-27 13:58:11.530 Detail, Node057, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2021-10-27 13:58:11.530 Detail, Node057, ZW_SEND_DATA delivered to Z-Wave stack
2021-10-27 13:58:11.548 Detail, Node057, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x00, 0x00, 0x02, 0xe2
2021-10-27 13:58:11.548 Detail, Node057, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2021-10-27 13:58:11.548 Info, Node057, Request RTT 27 Average Request RTT 27
2021-10-27 13:58:11.548 Detail, Expected callbackId was received
2021-10-27 13:58:15.521 Error, Node057, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-10-27 13:58:15.521 Detail, Node057, Removing current message
2021-10-27 13:58:15.521 Detail, Node057, Notification: Notification - TimeOut
2021-10-27 13:58:17.673 Detail, Node057, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x39, 0x03, 0x80, 0x03, 0x64, 0x2f
2021-10-27 13:58:17.673 Info, Node057, Received Battery report from node 57: level=100
2021-10-27 13:58:17.673 Detail, Node057, Refreshed Value: old value=100, new value=100, type=byte
2021-10-27 13:58:17.673 Detail, Node057, Changes to this value are not verified
2021-10-27 13:58:17.673 Detail, Node057, Notification: ValueChanged
Le module semble remonter la valeur de la batterie à chaque fois que je lance la commande OFF.
Merci pour votre aide.
