Zwave + v4.0.9 : compil dépendances KO
Hello
Sous Debian 10 (vm, full updated)
Jeedom V4.0.9 (Stable v4 choisit dans configuration)
Plugin Zwave stable dernière version
Impossible de compiler les dépendances :
Lancement de l’installation/mise à jour des dépendances openzwave
Hit:1 Index of /debian-security buster/updates InRelease
Hit:2 Index of /node_12.x/ buster InRelease
Hit:3 Index of /debian buster InRelease
Hit:4 Index of /debian buster-updates InRelease
Reading package lists…
Installation des dependances
Building dependency tree…
Reading state information…
build-essential is already the newest version (12.6).
g++ is already the newest version (4:8.3.0-1).
gcc is already the newest version (4:8.3.0-1).
git is already the newest version (1:2.20.1-2).
libjpeg-dev is already the newest version (1:1.5.2-2).
python-louie is already the newest version (1.1-4).
python-lxml is already the newest version (4.3.2-1).
make is already the newest version (4.2.1-1.2).
python-serial is already the newest version (3.4-4).
python-dev is already the newest version (2.7.16-1).
python-pip is already the newest version (18.1-5).
python-setuptools is already the newest version (40.8.0-1).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
libudev-dev is already the newest version (241-5).
unzip is already the newest version (6.0-23).
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
Installation des dependances Python
Requirement already satisfied: urwid in /usr/local/lib/python2.7/dist-packages (2.0.1)
Requirement already satisfied: louie in /usr/lib/python2.7/dist-packages (1.1)
Requirement already satisfied: six in /usr/local/lib/python2.7/dist-packages (1.12.0)
Requirement already satisfied: tornado in /usr/local/lib/python2.7/dist-packages (5.1.1)
Requirement already satisfied: backports-abc>=0.4 in /usr/local/lib/python2.7/dist-packages (from tornado) (0.5)
Requirement already satisfied: singledispatch in /usr/local/lib/python2.7/dist-packages (from tornado) (3.4.0.3)
Requirement already satisfied: futures in /usr/local/lib/python2.7/dist-packages (from tornado) (3.3.0)
Requirement already satisfied: six in /usr/local/lib/python2.7/dist-packages (from singledispatch->tornado) (1.12.0)
mkdir: cannot create directory ‹ /opt ›: File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
Not uninstalling cython at /usr/lib/python2.7/dist-packages, outside environment /usr
Can’t uninstall ‹ Cython ›. No files were found to uninstall.
apt-get install --force-yes -y cython
cython is already the newest version (0.29.2-2).
W: --force-yes is deprecated, use one of the options starting with --allow instead.
Installing dependencies for python : 2 7 16
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
python-docutils is already the newest version (0.14+dfsg-4).
apt-get install --force-yes -y build-essential libudev-dev g++
pip install nose-html
Requirement already satisfied: nose-html in /usr/local/lib/python2.7/dist-packages (1.1)
Requirement already satisfied: nose>=0.11.1 in /usr/lib/python2.7/dist-packages (from nose-html) (1.3.7)
pip install nose-progressive
Requirement already satisfied: nose-progressive in /usr/local/lib/python2.7/dist-packages (1.5.2)
Requirement already satisfied: blessings<2.0,>=1.3 in /usr/local/lib/python2.7/dist-packages (from nose-progressive) (1.7)
Requirement already satisfied: nose>=1.2.1 in /usr/lib/python2.7/dist-packages (from nose-progressive) (1.3.7)
Requirement already satisfied: six in /usr/local/lib/python2.7/dist-packages (from blessings<2.0,>=1.3->nose-progressive) (1.12.0)
pip install coverage
Requirement already satisfied: coverage in /usr/local/lib/python2.7/dist-packages (4.5.4)
pip install nose
Requirement already satisfied: nose in /usr/lib/python2.7/dist-packages (1.3.7)
pip install pylint
Requirement already satisfied: pylint in /usr/local/lib/python2.7/dist-packages (1.9.5)
Requirement already satisfied: singledispatch; python_version < « 3.4 » in /usr/local/lib/python2.7/dist-packages (from pylint) (3.4.0.3)
Requirement already satisfied: mccabe in /usr/local/lib/python2.7/dist-packages (from pylint) (0.6.1)
Requirement already satisfied: configparser; python_version == « 2.7 » in /usr/lib/python2.7/dist-packages (from pylint) (3.5.0b2)
Requirement already satisfied: isort>=4.2.5 in /usr/local/lib/python2.7/dist-packages (from pylint) (4.3.21)
Requirement already satisfied: six in /usr/local/lib/python2.7/dist-packages (from pylint) (1.12.0)
Requirement already satisfied: astroid<2.0,>=1.6 in /usr/local/lib/python2.7/dist-packages (from pylint) (1.6.6)
Requirement already satisfied: backports.functools-lru-cache; python_version == « 2.7 » in /usr/lib/python2.7/dist-packages (from pylint) (1.5)
Requirement already satisfied: futures; python_version < « 3.2 » in /usr/local/lib/python2.7/dist-packages (from isort>=4.2.5->pylint) (3.3.0)
Requirement already satisfied: wrapt in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.11.2)
Requirement already satisfied: enum34>=1.1.3; python_version < « 3.4 » in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.1.6)
Requirement already satisfied: lazy-object-proxy in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.4.2)
#pip install docutils
#pip install setuptools
#The following line crashes with a core dump
#pip install « Cython==0.22 »
Dependencies for users installed (python 2 7 16)
sed -i -e ‹ 253s/.//’ openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory ‹ /opt/python-openzwave/openzwave ›
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory ‹ /opt/python-openzwave/openzwave/cpp/build ›
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building SensorAlarm.o
Building Proprietary.o
Building Color.o
Building SwitchToggleMultilevel.o
Building Version.o
Building Language.o
Building CRC16Encap.o
Building ZWavePlusInfo.o
Building Indicator.o
Building MultiInstance.o
Building SensorBinary.o
Building ThermostatFanMode.o
Building MeterPulse.o
Building ClimateControlSchedule.o
Building Configuration.o
Building Battery.o
Building CommandClass.o
Building Hail.o
Building SwitchToggleBinary.o
Building SensorMultilevel.o
Building UserCode.o
Building CentralScene.o
Building TimeParameters.o
Building BarrierOperator.o
Building DoorLock.o
Building SwitchMultilevel.o
Building ApplicationStatus.o
Building NodeNaming.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function 'virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8
, uint32, uint32) ›:
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: error: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Werror=restrict]
snprintf(usercode, sizeof(usercode), « %s %d », usercode, (int)_data[12+i]);
cc1plus: all warnings being treated as errors
make[2]: *** [/opt/python-openzwave/openzwave/cpp/build/support.mk:136: /opt/python-openzwave/openzwave/.lib/DoorLockLogging.o] Error 1
make[2]: Leaving directory ‹ /opt/python-openzwave/openzwave/cpp/build ›
make[1]: *** [Makefile:20: all] Error 2
make[1]: Leaving directory ‹ /opt/python-openzwave/openzwave ›
make: *** [Makefile:273: openzwave/.lib/] Error 2
Everything is successfully installed!
En buster il faut mettre le plugin en beta
OK je n’avais pas compris cela. désolé
