Depuis 1 semaine, je n’arrive plus à inclure de module zwave (ni deconz)
Je viens d’essayer 1 Wall Plug de Fibaro (sachant que j’en ai deja 4 qui sont inclu depuis un moment). Mais rien ne se passe lorsque je lance le mode inclusion de Jeedom et que je passe en mose inclusion sur le module
Mes modules deja inclu fonctionne bien.
Je n’ai pas d’erreur dans les logs hormis ça pour openzwave quand je relance le server Zwave:
2021-03-28 22:00:12.491 Always, OpenZwave Version 1.4.0 Starting Up
2021-03-28 22:00:17.291 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:00:35.409 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:00:42.043 Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:00:46.317 Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:00:50.359 Error, Node008, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:00:54.635 Error, Node008, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:00:58.677 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:02.867 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:06.905 Error, Node011, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:11.182 Error, Node011, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:16.369 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:20.371 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:20.375 Error, Node015, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2021-03-28 22:01:24.374 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:28.376 Error, Node015, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:32.126 Error, Node015, ERROR: node presumed dead
2021-03-28 22:01:32.377 Error, Node015, ERROR: Dropping command because node is presumed dead
2021-03-28 22:01:32.379 Error, Node015, ERROR: Dropping command because node is presumed dead
2021-03-28 22:01:32.385 Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2021-03-28 22:01:36.384 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:41.900 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:53.090 Error, Node017, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:01:56.579 Error, Node015, WARNING: node revived
2021-03-28 22:01:59.490 Error, Node017, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:02:08.581 Error, Node017, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-03-28 22:02:27.698 Error, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Mais les modules fonctionnent :
La seule chose que j’ai faite mais je ne vois pas l’incidence vu que les modules deja inclus fonctionnent bien :
sudo systemctl stop serial-getty@ttyAMA0.service
sudo systemctl disable serial-getty@ttyAMA0.service
Auriez-vous une idée ?
Je suis sur un Rasberry Pi4 avec toutes les dernières mise à jour Jeedom et Plugin
Par avance merci
