Nul node dans mon log…
Et j’ai bien coché la MàJ du core, hein !!
Attention : tu n’es pas en version stable pour ta part…
0000|[PROGRESS][100]
0001|[START UPDATE]
0002|[PROGRESS][1]
0003|****Update from 4.3.20 (2023-12-12 09:40:30)****
0004|Parameters : {"preUpdate":"0","backup::before":"1","plugins":"1","core":"1","force":"0","update::reapply":""}
0005|Send begin of update event...OK
0006|Check update...
0007|OK
0008|[PROGRESS][5]
0009|Check rights...
0010|OK
0011|[START BACKUP]
0012|***************Start of Jeedom backup at 2023-12-12 09:40:34***************
0013|Send begin backup event...OK
0014|Checking files rights...
0015|OK
0016|Checking database...
0017|OK
0018|Backing up database...
0019|OK
0020|Cache persistence:
0021|OK
0022|Creating archive...
0023|OK
0024|Cleaning old backup...OK
0025|Limiting backup size to 30000 Mb...
0026|OK
0027|Backup name: /var/www/html/core/php/../../backup/backup-Stilgar-4.3.20-2023-12-12-09h40.tar.gz
0028|Checking files rights...OK
0029|Send end backup event...OK
0030|Backup operation duration: 292s
0031|***************Jeedom backup end***************
0032|[END BACKUP SUCCESS]
0033|[PROGRESS][10]
0034|[PROGRESS][15]
0035|Download url : https://github.com/jeedom/core/archive/V4-stable.zip
0036|Download in progress...--2023-12-12 09:45:26-- https://github.com/jeedom/core/archive/V4-stable.zip
0037|Resolving github.com (github.com)... 140.82.121.4
0038|Connecting to github.com (github.com)|140.82.121.4|:443...
0039|HTTP request sent, awaiting response... 302 Found
0040|Location: https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable [following]
0041|--2023-12-12 09:45:27-- https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
0042|Resolving codeload.github.com (codeload.github.com)... 140.82.121.9
0043|Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443... connected.
0044|HTTP request sent, awaiting response... 200 OK
0045|Length: 82253145 (78M) [application/zip]
0046|Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0047|0K ........ ........ .
0048|....... ........ ........ ......
0049|.. 3% 758K 1m42s
0050|3072K ........
0051|........ ........ ........ ..
0052|...... ........ 7% 576K 1m53s
0053|6144K ........
0054|........ ........ ........ ........
0055|........ 11% 909K 98s
0056|9216K ........ ........ ........ .......
0057|. ........ ........ 15% 1.11M 86s
0058|12288K ........ ........ ........ ........ ....
0059|.... ........ 19% 984K 79s
0060|15360K ........ ........ ........ ........ ........ ........ 22% 1.17M 71s
0061|18432K ........
0062|........ ........ ........ ........ ........ 26% 1.13M 65s
0063|21504K ........ ........ ........ .....
0064|... ........ ........ 30% 924K 62s
0065|24576K ........ ........ ........ ........ ........ ....
0066|.... 34% 911K 58s
0067|27648K ........ ........ ........ ........ ........ ........ 38% 894K 55s
0068|30720K ........ ........ .
0069|....... ........ ........ ........ 42% 1.11M 51s
0070|33792K ........ ........ ........ ........ ......
0071|.. ........ 45% 1.14M 46s
0072|36864K ........ ........ ........ ........ ........ ........ 49% 1.13M 42s
0073|39936K ........ ........ ...
0074|..... ........ ........ ........ 53% 1.12M 39s
0075|43008K ........ ........ ........ ........ ......
0076|.. ........ 57% 1.19M 35s
0077|46080K ........ ........ ........ ........ ........ ........ 61% 1.23M 31s
0078|49152K ........ ...
0079|..... ........ ........ ........ ........ 65% 1.09M 28s
0080|52224K ........ ........ ........ ......
0081|.. ........ ........ 68% 1.06M 25s
0082|55296K ........ ........ ........ ........ ........ ........ 72% 1.05M 22s
0083|58368K ..
0084|...... ........ ........ ........ ........ ........ 76% 961K 19s
0085|61440K ........ ......
0086|.. ........ ........ ........ ........ 80% 920K 16s
0087|64512K ........ ......
0088|.. ........ ........
0089|........ ........ 84% 977K 13s
0090|67584K ........ ........ ........ ........ ........ ........ 87% 1.15M 10s
0091|70656K ...
0092|..... ........ ........ ........ ........ ........ 91% 987K 7s
0093|73728K ........ .....
0094|... ........ ........ ........ ........ 95% 1.18M 3s
0095|76800K ........ ........ ........ .
0096|....... ........ ........ 99% 1.25M 0s
0097|79872K ....... 100% 1.10M=79s
0098|2023-12-12 09:46:46 (1020 KB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [82253145/82253145]
0099|[PROGRESS][25]
0100|OK
0101|Cleaning folders...
0102|OK
0103|[PROGRESS][30]
0104|Create temporary folder...OK
0105|[PROGRESS][35]
0106|Unzip in progress...
0107|OK
0108|[PROGRESS][40]
0109|Clean temporary files (tmp)...OK
0110|Disable all task
0111|... OK
0112|Disable all scenario..............
0113|.................................
0114|...................................
0115|.... OK
0116|[PROGRESS][45]
0117|Moving files...
0118|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/de_DE/noteVersion.md because size is 0
0119|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/en_US/noteVersion.md because size is 0
0120|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/es_ES/noteVersion.md because size is 0
0121|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/fr_FR/noteVersion.md because size is 0
0122|Ignore file /tmp/jeedom_unzip/core-4-stable///docs/pt_PT/noteVersion.md because size is 0
0123|OK
0124|[PROGRESS][50]
0125|Remove temporary files...OK
0126|[PROGRESS][52]
0127|Remove useless files...
0128|Cleaning 3rdparty
0129|Cleaning desktop
0130|Cleaning mobile
0131|Cleaning core
0132|Cleaning docs
0133|Cleaning install
0134|Cleaning script
0135|find: '/var/www/html/install/../script/*': No such file or directory
0136|Cleaning vendor
0137|[PROGRESS][55]
0138|Check jeedom consistency...
0139|[START CONSISTENCY]
0140|[START CHECK AND FIX DB]
0141|[END CHECK AND FIX DB]
0142|Check jeedom package...
0143|OK
0144|Check jeedom database...OK
0145|Check crons...
0146|Check filesystem right...
0147|OK
0148|Flush cache widget...
0149|Check jeedom object...OK
0150|Check jeedom cmd...
0151|OK
0152|Set cache hour...OK
0153|[END CONSISTENCY]
0154|OK
0155|Check update...OK
0156|***************Jeedom is up to date in 4.3.20***************
0157|[PROGRESS][75]
0158|***************Update plugins***************
0159|***************Update plugin successfully***************
0160|[PROGRESS][90]
0161|Check update
0162|OK
0163|[PROGRESS][95]
0164|Enable scenario : OK
0165|Enable task : OK
0166|[PROGRESS][100]
0167|Launch cron dependancy plugins...OK
0168|Send end of update event...OK
0169|Update duration : 398s
0170|[END UPDATE SUCCESS]
