J’ai un ZiPulses de chez lixee
J’ai pu faire l’inclusion avec le plugin zigbeeLinker mais le problème est que j’ai un message
« L’équipement n’a pas pu être complètement intégré » il me dit de contacter le développeur du plugin.
Merci d’avance.
Modèle : ZiPulses
Fabricant : LiXee
### Property inconnue : "multiplier. Commande : {"access":3,"description":"It is necessary to press the link button to update","name":"multiplier","property":"multiplier","type":"numeric","value_max":1000,"value_min":1}
### Property inconnue : "divisor. Commande : {"access":3,"description":"It is necessary to press the link button to update","name":"divisor","property":"divisor","type":"numeric","value_max":1000,"value_min":1}
### Property inconnue : "unitOfMeasure. Commande : {"access":3,"description":"It is necessary to press the link button to update","name":"unitOfMeasure","property":"unitOfMeasure","type":"enum","values":["kWh","m3","ft3","ccf","US gl","IMP gl","BTUs","L (litre)","kPA (jauge)","kPA (absolu)","kPA (absolu)","sans unit\u00e9","MJ","kVar"]}
#### Last Payload :
{"device":{"applicationVersion":1,"dateCode":"20230222","friendlyName":"0x00158d000952015f","hardwareVersion":1,"ieeeAddr":"0x00158d000952015f","manufacturerID":4151,"manufacturerName":"LiXee","model":"ZiPulses","networkAddress":36266,"powerSource":"Battery","softwareBuildID":"4000-0003","stackVersion":2,"type":"EndDevice","zclVersion":3},"divisor":1,"linkquality":255,"multiplier":1,"unitOfMeasure":"kWh"}
