### What happened?
Other people having this issue at the bottom of https://gith…ub.com/Koenkk/zigbee2mqtt/issues/19169
I have 3 `SIN-4-FP-21` from Nodon. Two works perfectly, but with the third I had timeout error when trying to change the pilot wire mode. I don't have the exact error anymore, but similar to `{"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 32138 - 242 - 165 - 6 - 11 after 10000ms)'` (taken from that other issue).
I had a look at the `database.db` file (third device is the broken one):
{"id":32,"type":"Router","ieeeAddr":"0xf4b3b1fffee51b9f","nwkAddr":34985,"manufId":4747,"manufName":"NodOn","powerSource":"Mains (single phase)","modelId":"SIN-4-FP-21","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,3,4,5,6,1794,4096,64512],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"SIN-4-FP-21","manufacturerName":"NodOn","powerSource":1,"zclVersion":8,"appVersion":3,"stackVersion":103,"hwVersion":52,"dateCode":"2021","swBuildId":"3.0.0-1.4.4"}},"seMetering":{"attributes":{"multiplier":1,"divisor":1000,"instantaneousDemand":1,"currentSummDelivered":[0,186577]}},"genIdentify":{"attributes":{"identifyTime":0}},"manuSpecificUbisysDeviceSetup":{"attributes":{"mode":5}},"genOnOff":{"attributes":{"onOff":1}}},"binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":3,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":64512,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":1,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null},{"cluster":1794,"attrId":1024,"minRepIntval":5,"maxRepIntval":3600,"repChange":1,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":102,"inClusterList":[33],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":3,"stackVersion":103,"hwVersion":52,"dateCode":"2021","swBuildId":"3.0.0-1.4.4","zclVersion":8,"interviewCompleted":true,"meta":{"configured":1520543266},"lastSeen":1712177167846}
{"id":33,"type":"Router","ieeeAddr":"0xf082c0fffe2071e4","nwkAddr":38222,"manufId":4747,"manufName":"NodOn","powerSource":"Mains (single phase)","modelId":"SIN-4-FP-21","epList":[242,1],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,3,4,5,6,1794,4096,64512],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"SIN-4-FP-21","manufacturerName":"NodOn","powerSource":1,"zclVersion":8,"appVersion":3,"stackVersion":103,"hwVersion":52,"dateCode":"2021","swBuildId":"3.0.0-1.4.4"}},"seMetering":{"attributes":{"multiplier":1,"divisor":1000,"instantaneousDemand":1,"currentSummDelivered":[0,411]}},"manuSpecificUbisysDeviceSetup":{"attributes":{"mode":3}},"genIdentify":{"attributes":{"identifyTime":0}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":3,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":64512,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":1,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null},{"cluster":1794,"attrId":1024,"minRepIntval":5,"maxRepIntval":3600,"repChange":1,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":102,"inClusterList":[33],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":3,"stackVersion":103,"hwVersion":52,"dateCode":"2021","swBuildId":"3.0.0-1.4.4","zclVersion":8,"interviewCompleted":true,"meta":{"configured":1520543266},"lastSeen":1712177165864}
{"id":34,"type":"Router","ieeeAddr":"0xf082c0fffe180179","nwkAddr":45975,"manufId":4747,"manufName":"NodOn","powerSource":"Mains (single phase)","modelId":"SIN-4-FP-21","epList":[242,1],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[0,3,4,5,6,1794,4096,64512],"outClusterList":[25],"clusters":{"genIdentify":{"attributes":{"identifyTime":0}},"seMetering":{"attributes":{"multiplier":1,"divisor":1000,"currentSummDelivered":[0,39415],"instantaneousDemand":0}},"manuSpecificUbisysDeviceSetup":{"attributes":{"mode":3}},"genOnOff":{"attributes":{"onOff":0}}},"binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":3,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1},{"cluster":64512,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa8446","endpointID":1}],"configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":1,"maxRepIntval":3600,"repChange":0,"manufacturerCode":null},{"cluster":1794,"attrId":1024,"minRepIntval":5,"maxRepIntval":3600,"repChange":1,"manufacturerCode":null},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":[1,1],"manufacturerCode":null}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":102,"inClusterList":[33],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":3,"stackVersion":103,"hwVersion":52,"dateCode":"2021","swBuildId":"3.0.0-1.4.4","zclVersion":8,"interviewCompleted":true,"meta":{"configured":1520543266},"lastSeen":1712177141699}
As you can see, `genBasic` is missing in the third device. After copying that section from other and restarting Zigbee2MQTT, the device worked flawlessly.
I've no idea what let to that misconfiguration.
### What did you expect to happen?
All three device fully working.
### How to reproduce it (minimal and precise)
_No response_
### Zigbee2MQTT version
1.36.0 commit: 86ed71c
### Adapter firmware version
20220219
### Adapter
zzh!
### Setup
docker on a sinology nas
### Debug log
_No response_
