Zigbee2MQTT problème endpoint 242, not supported
J’ ai un problème avec Zigbeemqtt j ai un défaut qui reviens très souvent ( Z2M à renvoyé une erreur : zh:zigate: source endpoint 242, not supported) tous fonctionne
> zigbee2mqtt@1.39.1 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2024-08-03 17:14:23] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
[2024-08-03 17:14:23] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-08-03 17:14:23] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-08-03 17:14:24] e[31merrore[39m: 	zh:zigate: [object Object]
[2024-08-03 17:14:24] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:19:34] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 10 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 17:19:44] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 10 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 17:20:25] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:21:55] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:26:11] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:27:29] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:27:47] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x2b7f Error: [object Object] after 10000ms
[2024-08-03 17:29:16] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 17:29:19] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 17:30:02] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 31 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 17:30:12] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 31 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 17:30:49] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:31:43] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:35:22] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 36 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 17:35:32] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 36 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 17:38:56] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:45:43] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 48 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 17:45:53] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 48 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 17:47:39] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0xde42 Error: [object Object] after 10000ms
[2024-08-03 17:48:02] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 38027 - 1 - 57 - 0 - 1 after 10000ms (0x0564cf22004b1200:38027,0)
[2024-08-03 17:48:12] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 38027 - 1 - 57 - 0 - 1 after 10000ms (0x0564cf22004b1200:38027,1)
[2024-08-03 17:48:22] e[31merrore[39m: 	z2m: Failed to configure 'Interrupteur alarme', attempt 1 (Error: Bind 0x0564cf22004b1200/1 genOnOff from '0x75a5ed01008d1500/1' failed ([object Object] after 10000ms)
    at Object.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23)
    at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/zigate/driver/zigate.ts:108:45
    at Array.forEach (<anonymous>)
    at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/zigate/driver/zigate.ts:105:51
    at Queue.execute (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/queue.ts:35:26)
    at ZiGate.sendCommand (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/zigate/driver/zigate.ts:86:33)
    at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:448:46
    at ZiGateAdapter.bind (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:434:27)
    at Endpoint.bind (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:509:34))
[2024-08-03 17:49:13] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:54:33] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:55:04] e[31merrore[39m: 	zh:zigate: RECEIVING SIMPLE_DESCRIPTOR FAILED - addr: 0x4a8d EP:1 Error: [object Object] after 10000ms
[2024-08-03 17:56:04] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 61 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 17:57:53] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:58:00] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 17:58:02] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 17:58:47] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 17:59:19] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 17:59:21] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 18:01:16] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 64 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 18:01:21] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'Capteur choc porte d'entrée haut' is already in use'
[2024-08-03 18:01:26] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 64 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 18:04:43] e[31merrore[39m: 	zh:zigate: RECEIVING SIMPLE_DESCRIPTOR FAILED - addr: 0x7dd0 EP:1 Error: [object Object] after 10000ms
[2024-08-03 18:06:36] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 66 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 18:08:23] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-03 19:37:44] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 86 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 19:37:54] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 86 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 19:43:04] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 87 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 19:43:14] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 87 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 20:03:36] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 91 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 20:03:46] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 91 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 20:24:09] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 95 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 20:24:19] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 95 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 21:04:39] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 103 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 21:04:49] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 103 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 21:15:00] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 105 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 21:15:10] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 105 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 21:20:20] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 106 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 21:20:30] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 106 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 21:25:40] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 107 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 21:25:50] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 107 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 21:31:00] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 108 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 21:31:10] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 108 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-03 22:01:38] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 114 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-03 22:01:48] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 114 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 00:28:54] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 143 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 00:29:04] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 143 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 00:34:14] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 144 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 00:34:24] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 144 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 00:44:38] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 146 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 00:44:48] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 146 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 03:36:37] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 180 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 03:41:48] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 181 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 03:41:58] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 181 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 05:13:31] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 200 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 05:13:41] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 200 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 05:18:51] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 201 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 05:19:01] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 201 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 05:24:11] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 202 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 05:24:21] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 202 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 07:00:44] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 222 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 07:00:54] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 222 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 07:02:44] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:05:13] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x948b Error: [object Object] after 10000ms
[2024-08-04 07:05:23] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x948b Error: [object Object] after 10000ms
[2024-08-04 07:05:33] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x948b Error: [object Object] after 10000ms
[2024-08-04 07:05:43] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x948b Error: [object Object] after 10000ms
[2024-08-04 07:05:53] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x948b Error: [object Object] after 10000ms
[2024-08-04 07:06:03] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x948b Error: [object Object] after 10000ms
[2024-08-04 07:06:04] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 6 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 07:06:05] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:06:13] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 38027 - 1 - 7 - 0 - 1 after 10000ms (0x0564cf22004b1200:38027,0)
[2024-08-04 07:06:23] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 38027 - 1 - 7 - 0 - 1 after 10000ms (0x0564cf22004b1200:38027,1)
[2024-08-04 07:06:33] e[31merrore[39m: 	zh:zigate: RECEIVING ActiveEndpoints FAILED, Error: [object Object] after 10000ms
[2024-08-04 07:06:43] e[31merrore[39m: 	zh:zigate: RECEIVING ActiveEndpoints FAILED, Error: [object Object] after 10000ms
[2024-08-04 07:06:43] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/interview' failed with error: 'interview of 'Interrupteur alarme' (0x0564cf22004b1200) failed: Error: Interview failed because can not get active endpoints ('0x0564cf22004b1200')'
[2024-08-04 07:06:58] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:46:23] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:46:47] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 18 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 07:46:57] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 18 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 07:47:17] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 56879 - 1 - 27 - 0 - 1 after 10000ms (0x8eb067fefff9e3b4:56879,0)
[2024-08-04 07:47:27] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 56879 - 1 - 27 - 0 - 1 after 10000ms (0x8eb067fefff9e3b4:56879,1)
[2024-08-04 07:47:47] e[31merrore[39m: 	z2m: Failed to configure '0x8eb067fefff9e3b4', attempt 1 (Error: Bind 0x8eb067fefff9e3b4/1 genOnOff from '0x75a5ed01008d1500/1' failed ([object Object] after 10000ms)
[2024-08-04 07:47:54] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'bouton sonnette' is already in use'
[2024-08-04 07:47:57] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'bouton sonnette' is already in use'
[2024-08-04 07:49:43] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:50:37] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:51:00] e[31merrore[39m: 	z2m: Exception while calling fromZigbee converter: Invalid version. Must be a string. Got type "undefined".}
[2024-08-04 07:51:29] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'bouton sonnette' is already in use'
[2024-08-04 07:51:32] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'bouton sonnette' is already in use'
[2024-08-04 07:52:07] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 32 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 07:52:18] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 32 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 07:53:54] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:54:21] e[31merrore[39m: 	zh:zigate: RECEIVING ActiveEndpoints FAILED, Error: [object Object] after 10000ms
[2024-08-04 07:54:30] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/device/rename' failed with error: 'friendly_name 'bouton sonnette' is already in use'
[2024-08-04 07:54:46] e[31merrore[39m: 	z2m: Failed to configure '0x8eb067fefff9e3b4', attempt 2 (Error: Bind 0x8eb067fefff9e3b4/1 genOnOff from '0x75a5ed01008d1500/1' failed ([object Object] after 10000ms)
[2024-08-04 07:56:56] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 07:57:28] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 36 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 07:57:38] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 36 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
[2024-08-04 07:57:59] e[31merrore[39m: 	z2m: Request 'zigbee2mqtt/bridge/request/group/remove' failed with error: 'Group '901' does not exist'
[2024-08-04 07:58:02] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
> node index.js
[2024-08-04 08:02:40] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
[2024-08-04 08:02:40] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-08-04 08:02:40] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-08-04 08:02:41] e[31merrore[39m: 	zh:zigate: [object Object]
[2024-08-04 08:02:41] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:03:03] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 3 - 0 - 1 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 08:04:08] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:04:44] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:04:44] e[31merrore[39m: 	z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
[2024-08-04 08:04:44] e[31merrore[39m: 	z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-08-04 08:04:44] e[31merrore[39m: 	z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-08-04 08:04:45] e[31merrore[39m: 	zh:zigate: [object Object]
[2024-08-04 08:04:45] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:05:48] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:08:22] e[31merrore[39m: 	zh:zigate: RECEIVING NODE_DESCRIPTOR FAILED - addr: 0x75cb Error: [object Object] after 10000ms
[2024-08-04 08:09:08] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:09:55] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 34 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,0)
[2024-08-04 08:10:03] e[31merrore[39m: 	zh:zigate: source endpoint 242, not supported
[2024-08-04 08:10:05] e[31merrore[39m: 	zh:zigate: Response error Error: Timeout - 45639 - 1 - 34 - 61184 - 11 after 10000ms (0xe7668afeffb6c67c:45639,1)
merci de votre aide
242 c’est l’endpoint du Green power que zigate ne doit pas supporter ou alors ton firmware n’est peut pas à jour d’où le soucis.
Par contre la a ta place je posterais plus sur le GitHub de aigbee2mqtt vu que c’est eux qui font le moteur c’est eux qui auront la réponse à ton soucis.
Merci de votre réponse a+
