> zigbee2mqtt@2.14.2 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2026-10-28 10:36:42] e[34mdebuge[39m: z2m: Removing old log directory '/var/www/html/plugins/z2m/data/log/2026-10-28.01-35-15'
[2026-10-28 10:36:42] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2026-10-28 10:36:42] e[34mdebuge[39m: z2m: Loaded state from file /var/www/html/plugins/z2m/data/state.json
[2026-10-28 10:36:42] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.14.2 (commit #5c0c1c60)
[2026-10-28 10:36:42] e[32minfoe[39m: z2m: Starting zigbee-herdsman (10.10.0)
[2026-10-28 10:36:42] e[34mdebuge[39m: z2m: Using zigbee-herdsman with settings: '{"adapter":{"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[15,184,110,118,65,205,68,201],"networkKey":"HIDDEN","panID":57680},"serialPort":{"adapter":"deconz","baudRate":115200,"path":"/dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03111372-if00-port0"}}'
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyACM0","manufacturer":"Zooz","serialNumber":"533D004242","pnpId":"usb-Zooz_800_Z-Wave_Stick_533D004242-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyUSB0","manufacturer":"RFXCOM","serialNumber":"DO5QYHT4","pnpId":"usb-RFXCOM_RFXtrx433XL_DO5QYHT4-if00-port0","vendorId":"0403","productId":"6015"},{"path":"/dev/ttyUSB1","manufacturer":"dresden elektronik","serialNumber":"DE03111372","pnpId":"usb-dresden_elektronik_ConBee_III_DE03111372-if00-port0","vendorId":"0403","productId":"6015"}]
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:adapter:discovery: Unable to match USB adapter: deconz | /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03111372-if00-port0
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","extendedPanID":[15,184,110,118,65,205,68,201],"panID":57680,"channelList":[11]},"serialPort":{"baudRate":115200,"path":"/dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03111372-if00-port0","adapter":"deconz"},"adapter":{"disableLED":false},"databasePath":"/var/www/html/plugins/z2m/data/database.db","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json"}'
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Opening serial port: /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03111372-if00-port0
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Serialport opened
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Query firmware parameters
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Reset firmware watchdog
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Send write parameter request from queue. seq: 1 parameter: DEV_WATCHDOG_TTL
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:frameparser: Write parameter response parameter: DEV_WATCHDOG_TTL, status: Unsupported
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Reset firmware watchdog failed
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: Send read firmware version request from queue. seq: 2
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:frameparser: read firmware version response - version: 0x26450900
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: MAC_ADDRESS seq: 4
[2026-10-28 10:36:42] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for MAC_ADDRESS, seq: 4, status: 0, parameter: 0x00212effff0500f1
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: APS_TRUST_CENTER_ADDRESS seq: 5
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for APS_TRUST_CENTER_ADDRESS, seq: 5, status: 0, parameter: 0x00212effff0500f1
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: NWK_PANID seq: 6
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for NWK_PANID, seq: 6, status: 0, parameter: 57680
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: APS_USE_EXTENDED_PANID seq: 7
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for APS_USE_EXTENDED_PANID, seq: 7, status: 0, parameter: 0x0fb86e7641cd44c9
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_CURRENT_CHANNEL seq: 8
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_CURRENT_CHANNEL, seq: 8, status: 0, parameter: 11
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_NETWORK_KEY seq: 9
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_NETWORK_KEY, seq: 9, status: 0, parameter: <hidden>
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_NWK_UPDATE_ID seq: 10
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_NWK_UPDATE_ID, seq: 10, status: 0, parameter: 1
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: APS_CHANNEL_MASK seq: 11
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for APS_CHANNEL_MASK, seq: 11, status: 0, parameter: 2048
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_PROTOCOL_VERSION seq: 12
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_PROTOCOL_VERSION, seq: 12, status: 0, parameter: 268
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_FRAME_COUNTER seq: 13
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_FRAME_COUNTER, seq: 13, status: 0, parameter: 194093210
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_ENDPOINT seq: 14
[2026-10-28 10:36:43] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_ENDPOINT, seq: 14, status: 0, parameter:
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:deconz:driver: send read parameter request from queue. parameter: STK_ENDPOINT seq: 15
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:deconz:frameparser: Received read parameter response for STK_ENDPOINT, seq: 15, status: 0, parameter: ��d!
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:deconz:driver: Configuration matches backup
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:deconz:driver: Zigbee configuration valid
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller: Started with result 'resumed'
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller: Injected database: true, adapter: true
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:deconz: -------- z2m:getCoordinatorIEEE() ----------------
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0x00212effff0500f1): default expiration timeout set to 0
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0x286847fffe8a9c34): default expiration timeout set to 7200000
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0xf84477fffee31ec2): default expiration timeout set to 7200000
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0x7cb03eaa0a081a0a): default expiration timeout set to 0
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0x7cb03eaa0a0499bf): default expiration timeout set to 0
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0x7cb03eaa0a04b1a8): default expiration timeout set to 0
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0xf0d1b8be240ba71d): default expiration timeout set to 0
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0xf0d1b8be240ba4a5): default expiration timeout set to 0
[2026-10-28 10:36:44] e[34mdebuge[39m: zh:controller:device: Request Queue (0x54ef4410007f2b6b): default expiration timeout set to 3600000
