Ma config: NUC proxmox 8, MV Jeedom (last) debian 11, MQTT et Zigbee2Mqtt dans un container.
Pour ma migration zigbee vers jeezigbee j’utilise 2 clés: combee2 (zigbee) et SONOFF Zigbee 3.0 USB Dongle Plus V2 (EFR32MG21) firmware 6.10.3.0 build 297.
J’ai basculé pas mal de capteurs et lampes sans trop de pb mais là je bloque sur les capteurs d’ouverture sonoff snzb-04 avec l’erreur « failed to interview ».
0017|[2023-10-02 10:05:18]DEBUG : {"device_joined":"00:12:4b:00:22:68:01:7b"}
0018|[2023-10-02 10:05:18]DEBUG : {"device_initialized":"00:12:4b:00:22:68:01:7b"}
0019|[2023-10-02 10:05:19]DEBUG : {"devices":{"00:12:4b:00:22:68:01:7b":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
0020|[2023-10-02 10:05:19]DEBUG : Search command for 00:12:4b:00:22:68:01:7b logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1 convert to 1
0021|[2023-10-02 10:05:19]DEBUG : Search command for 00:12:4b:00:22:68:01:7b logicalId : 1::1280::cmd::1.1 => bitmap8.0 convert to 0
0022|[2023-10-02 10:05:19]DEBUG : Search command for 00:12:4b:00:22:68:01:7b logicalId : 1::1280::cmd::1.2 => 0 convert to 0
0023|[2023-10-02 10:05:19]DEBUG : Search command for 00:12:4b:00:22:68:01:7b logicalId : 1::1280::cmd::1.3 => 0 convert to 0
0024|[2023-10-02 10:05:21]DEBUG : {"devices":{"04:cf:8c:df:3c:7f:1e:e6":{"1":{"1024":[{"value":"4772","cluster_name":"Illuminance Measurement"}]}},"00:12:4b:00:22:68:01:7b":{"1":{"1280":{"16":{"value":"00:21:2e:ff:ff:06:d3:27","cluster_name":"IAS Zone"}}}}}}
0026|[2023-10-02 10:05:21]DEBUG : Search attribut for 00:12:4b:00:22:68:01:7b logicalId : 1::1280::16 => 00:21:2e:ff:ff:06:d3:27 convert to 00:21:2e:ff:ff:06:d3:27
0110|[2023-10-02 10:07:35]DEBUG : {"devices":{"00:12:4b:00:22:68:01:7b":{"1":{"1":{"32":{"value":"28","cluster_name":"Power Configuration"},"33":{"value":"45","cluster_name":"Power Configuration"}}}}}}
0111|[2023-10-02 10:07:35]DEBUG : Search attribut for 00:12:4b:00:22:68:01:7b logicalId : 1::1::32 => 28 convert to 28
0112|[2023-10-02 10:07:35]DEBUG : Search attribut for 00:12:4b:00:22:68:01:7b logicalId : 1::1::33 => 45 convert to 45
J’ai tenté le changement de pile, un autre capteur, être près du dongle… mais toujours pas d’appairage.
CEPENDANT les essais d’appairage avec la combee2 (plugin zigbee) fonctionnent !!!
Une idée ?
le log z2m lors d’un autre essai :
z2m.txt (4,7 Mo)
