Bonjour @iPapy @Loic
j ai le même souci depuis les dernières mises à jour
Erreur exécution de la commande [SALON][PRISE AQUARIUM][On 1] : Erreur lors de la requete : http://127.0.0.1:57600/device/command(PUT), data : {« ieee »:« bc:33:ac:ff:fe:59:16:aa »,« cmd »:[{« endpoint »:1,« cluster »:« on_off »,« command »:« on »,« await »:1}],« allowQueue »:false} erreur : {« state »:« error »,« result »:"[0x622d:1:0x0006]: Message send failure",« code »:0}
"ieee": "bc:33:ac:ff:fe:59:16:aa",
"nwk": 25133,
"status": 2,
"lqi": "168",
"rssi": "-58",
"last_seen": "1620215201.2491102",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": "_TZ3000_vzopcetz",
"model": "TS011F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 69
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_vzopcetz"
"id": 5,
"name": "model",
"value": "TS011F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 2,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 3,
"status": 1,
"device_type": 266,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "TS011F",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
0,
3,
4,
5,
6
25,
10
"2": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
3,
4,
5,
6
"3": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
3,
4,
5,
6
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
La seul solution débranché et re branché la prise mais le lendemain plus rien
Plugin zigbee officiel Gateway Lidl hack
Par avance merci pour votre aide
Philippe``
