Bonjour @Loic
Merci pour integration du périphérique
pour info :
"ieee": "00:12:4b:00:22:6d:4d:95",
"nwk": 26802,
"status": 2,
"lqi": "132",
"rssi": "-62",
"last_seen": "1613314740.741065",
"node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 528,
"profile_id": 49246,
"manufacturer": "JunYu",
"model": "ZB-RGBCW",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 13
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "JunYu"
"id": 5,
"name": "model",
"value": "ZB-RGBCW"
"id": 6,
"name": "date_code",
"value": "20201216"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.0.1"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 254
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 24939
"id": 4,
"name": "current_y",
"value": 24701
"id": 7,
"name": "color_temperature",
"value": 333
"id": 13,
"status": 1,
"device_type": 57694,
"manufacturer": null,
"model": null,
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 4096,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 0,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"1": {
"device_type": 528,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768
"13": {
"input_clusters": [
4096
4096
"class": "zigpy.device"
Malheureusement, je n’arrive pas à avoir le retour des états des commandes, intensité, couleur,et valeur on/off.
Les commandes elles, fonctionnent.
Je supprimé puis refait une association, essayé de recréer les commandes, sans succès.
Pas de messages d’erreur dans les logs
Si t’as une idée ?
