Quasiment un problème identique: Des commandes fonctionnent mais pas la remontée d’informations.
Voilà ce que j’ai dans les logs:
[2020-07-01 15:07:26][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-07-01 15:07:26][DEBUG] : Received command from jeedom : send
[2020-07-01 15:07:26][DEBUG] : Executing action on : fan
[2020-07-01 15:07:27][DEBUG] : {"id":58519,"method":"set_power","params":["on"]}
[2020-07-01 15:07:27][DEBUG] : __init__() takes at least 3 arguments (2 given)
ou encore
[2020-07-01 15:09:34][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-07-01 15:09:34][DEBUG] : Received command from jeedom : send
[2020-07-01 15:09:34][DEBUG] : Executing action on : fan
[2020-07-01 15:09:34][DEBUG] : {"id":12199,"method":"set_angle_enable","params":["off"]}
[2020-07-01 15:09:35][DEBUG] : __init__() takes at least 3 arguments (2 given)
Et lors d’une demande de refresh
[2020-07-01 15:10:46][DEBUG] : Client connected to [127.0.0.1:48822]
[2020-07-01 15:10:46][DEBUG] : Message read from socket: {"apikey":"XXXXXXXXXXXX","type":"wifi","cmd":"refresh","model":"fan","dest":"192.168.31.120","token":"d8c075656088ce090ac5cf1f3b5a3777","devtype":"0772","serial":"d66f"}
[2020-07-01 15:10:46][DEBUG] : Client disconnected from [127.0.0.1:48822]
[2020-07-01 15:10:47][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-07-01 15:10:47][DEBUG] : Received command from jeedom : refresh
[2020-07-01 15:10:47][DEBUG] : Refreshing : fan
[2020-07-01 15:10:47][DEBUG] : {"params": ["temp_dec", "humidity", "angle", "speed", "poweroff_time", "power", "ac_power", "battery", "angle_enable", "speed_level", "natural_level", "child_lock", "buzzer", "led_b"], "id": 41470, "method": "get_prop"}
[2020-07-01 15:10:47][DEBUG] : {"id":41470,"result":["null"],"exe_time":160}
[2020-07-01 15:10:47][ERROR] : Exception on socket : unsupported operand type(s) for /: 'unicode' and 'float'
Edit: précision, je suis sur le plugin en beta version 2020-03-22 02:28:30
