XIAOMI RTCGQ01LM pas de remonté état
Plugin Zigbee (BETA)
Module Xiaomi RTCGQ01LM
intégration du module Xiaomi au Plugin Zigbee = Ok par contre aucune remonté de présence
la commande créée est 1::6::0
Une idée ?
Pouvez vous poster les infos brutes?
Dans la config du Plugin, le Log Zigbee est vide.
Ce n’est pas le log zigbee demandé @Furaxworld mais les infos brutes :wink:
puis
mdr @iPapy je screenais la même chose :slight_smile:
Désolé je n’avais pas compris…
    "ieee": "00:15:8d:00:01:3f:91:07",
    "nwk": 48500,
    "status": 2,
    "lqi": "255",
    "rssi": "-49",
    "last_seen": "1675348292.543048",
    "node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 263,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.sensor_motion",
            "output_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "BasicCluster",
                    "attributes": [
                            "id": 1,
                            "name": "app_version",
                            "value": 11
                            "id": 4,
                            "name": "manufacturer",
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.sensor_motion"
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 32,
                            "name": "battery_voltage",
                            "value": 29.9
                            "id": 33,
                            "name": "battery_percentage_remaining",
                            "value": 118
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1030,
                    "name": "Occupancy Sensing",
                    "attributes": [
                            "id": 0,
                            "name": "occupancy",
                            "value": 1
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 0,
                            "name": "zone_state",
                            "value": 0
                    "id": 65535,
                    "name": "Manufacturer Specific",
                    "attributes": []
    "signature": {
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4151,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 263,
                "input_clusters": [
                    0,
                    1,
                    3,
                    1030,
                    1280,
                    65535
                    0,
                    3,
                    4,
                    5,
                    25
    "class": "zhaquirks.xiaomi.mija.motion"
créez une info binaire
1::1030::0
Fonctionne pas par contre
1::1280::0 => Ok c’est good
merci
loupé l’ID lu trop vite :wink:
Bref ça fonctionne :ok_hand:
Ouaips merci :wink:
