Je viens de recevoir ma clé EZSP (Silicon Labs), j’utilise une zigate avec abeille pour le zigbee jusqu’à aujourd’hui.
J’ai testé quelques équipements et j’ai eu un souci avec le capteur de témperature et humidité de chez xiaomin le rond.
Il est apparue comme inconnue, j’ai trouvé dans la liste le MIJIA (LYWSDCGQ/01ZM) j’ai voulu tenter de recréer les commandes avec, ca m’a basculé sur le AQARA (WSDCGQ11LM), celui SANS pression.
Est ce normale ? si non, est il possible d’ajouter le rond ?
J’ai pas vraiment trouvé d’info la dessus à part des message sur le sujet beta qui date de 2021.
Merci beaucoup
modèle WSDCGQ01LM « Mijia » (rond)
https://zigbee.blakadder.com/assets/images/devices/Xiaomi_WSDCGQ01LM.jpg
"ieee": "00:15:8d:00:02:00:a5:40",
"nwk": 41623,
"status": 2,
"lqi": "240",
"rssi": "-40",
"last_seen": "1662040324.09814",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 24322,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.sensor_ht",
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 65535,
"name": "Manufacturer Specific",
"attributes": []
"id": 18,
"name": "MultistateInput",
"attributes": []
"input_clusters": [
"id": 0,
"name": "BasicCluster",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 2
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 30
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.sensor_ht"
"id": 6,
"name": "date_code",
"value": "20160516"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "3000-0001"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 30.4
"id": 33,
"name": "battery_percentage_remaining",
"value": 154
"id": 3,
"name": "Identify",
"attributes": []
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 2755
"id": 1029,
"name": "Relative Humidity Measurement",
"attributes": [
"id": 0,
"value": 4302
"id": 65535,
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 2,
"status": 1,
"profile_id": 260,
"manufacturer": null,
"model": null,
"id": 4,
"name": "Groups",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 18,
"attributes": []
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 3,
"status": 1,
"device_type": 24323,
"profile_id": 260,
"model": null,
"id": 4,
"name": "Groups",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 12,
"name": "AnalogInput",
"attributes": []
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"signature": {
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
1026,
1029,
65535,
25
0,
4,
3,
5,
25,
65535,
18
"2": {
"profile_id": 260,
"input_clusters": [
3
4,
3,
5,
18
"3": {
"profile_id": 260,
"input_clusters": [
3
4,
3,
5,
12
"class": "zhaquirks.xiaomi.mija.sensor_ht"
zigbee.log (29,9 Ko)
