j’utilise le compteur de @Bad :
<!-- WIDGET SPECIFIQUE widget "tps_restant"
Refs : https://community.jeedom.com/t/decompte-a-la-seconde-widgets-v4/10658
https://community.jeedom.com/t/plugin-compte-a-rebours/6659/
Update : 2021/01/10
Modification : Clean error on clearInterval()
<div class="tooltips cmd cmd-widget" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
<div class="title #hide_name#">
<span class="cmdName">#name_display#</span>
</div>
<div class="content-sm">
<div id="countdown_#id#_decompte" data-cmd_id="#id#"></div>
</div>
<script>
$('.cmd[data-cmd_id=#id#]').attr('title','Date de valeur : '+_options.valueDate+'<br/>Date de collecte : '+_options.collectDate)
if (interval#uid#) {
clearInterval(interval#uid#);
interval#uid# = false;
var timestamp = parseFloat(_options.display_value);
if (timestamp > 0) {
interval#uid# = setInterval(function () {
var dateLoc = new Date;
var tps_restant=timestamp*1000 - (dateLoc.getTime()+(dateLoc.getTimezoneOffset()+serverTZoffsetMin)*60000 + clientServerDiffDatetime);
// console.log("interval("+intervalId+")");
if (!$('#countdown_#id#_decompte').length || timestamp < 0 || tps_restant < 0) {
// console.log("clearInterval("+intervalId+")");
$('#countdown_#id#_decompte').text(' ');
} else {
//============ CONVERSIONS
var s_restantes = tps_restant / 1000; // Secondes restantes
var i_restantes = s_restantes / 60; // Minutes restantes
var H_restantes = i_restantes / 60; // Heures restantes
s_restantes = Math.floor(s_restantes % 60); // Secondes restantes
i_restantes = Math.floor(i_restantes % 60); // Minutes restantes
H_restantes = Math.floor(H_restantes); // Heures restantes
//============ FORMATTAGE
s_restantes = s_restantes < 10 ? "0"+ s_restantes : s_restantes;
i_restantes = i_restantes < 10 ? "0"+ i_restantes : i_restantes;
H_restantes = H_restantes < 10 ? "0"+ H_restantes : H_restantes;
if (H_restantes > 0) {
$('#countdown_#id#_decompte').text(H_restantes + ":" + i_restantes + ":" +s_restantes);
} else {
$('#countdown_#id#_decompte').text(i_restantes + ":" +s_restantes);
}, 1000);
} else {
jeedom.cmd.update['#id#']({display_value:'#state#',valueDate:'#valueDate#',collectDate:'#collectDate#',alertLevel:'#alertLevel#'});
</script>
</div>
Le widget fonctionne nickel par contre je n’ai pas trouvé le moyen d’arrêter le compteur une fois qu’il est lancé (arrêt du scénario lié à l’utilisation du compteur).
Pendant l’exécution du compteur, j’ai essayé de mettre ma variable qui contient le timestamp de fin à 0, j’ai même essayé de mettre la variable =#timestamp#…rien ne se passe, le compteur continue de tourner jusqu’à la fin.
un idée ?
merci
