Watervalve compatibility
Hi! I love this plugin but my watervalves are not supported yet, would that be possible to add?
I have the logs that I’ll try to post in the second comment since it doesn’t allow me to that as a new user.
(Google translate result)
Bonjour ! J’adore ce plugin, mais mes vannes ne sont pas encore prises en charge. Serait-il possible de l’ajouter ?
J’ai les logs que j’essaierai de publier dans le deuxième commentaire, car cela ne me permet pas de le faire en tant que nouvel utilisateur.
Information Jeedom
Core : 4.4.19 (master)
DNS Jeedom : No
Plugin : Ajax Systems
Version : 2024-09-08 01:20:30 (stable)
You can post log… but you cannot post file nor link to external site but that doesn’t matter because you should post your log within a Texte préformaté (</> button in the toolbar)
[2025-03-22 14:39:05][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Frefresh => {"userId":"16FD757B","refreshToken":"3fTrMUkum9Qwuo97F0yBa9YyKFc"}
[2025-03-22 14:39:05][DEBUG] : [refreshToken] {"sessionToken":"VXj5ICTYJSG8_b1Ttz6nE6OAeVg","userId":"16FD757B","refreshToken":"HqSB454CyVgqIDYK0UAEWlu5dv4"}
[2025-03-22 14:39:05][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:39:05][DEBUG] : [{"hubId":"002257A0","hubBindingRole":"MASTER"}]
[2025-03-22 14:39:05][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:39:06][DEBUG] : {"hubSubtype":"HUB_2","name":"Ajax Hub 2","id":"002257A0","state":"DISARMED","timeZone":"EUROPE_AMSTERDAM","color":"BLACK","capabilities":["DFU"],"tampered":false,"externallyPowered":true,"chargingMode":"CONTINUOUS","ledBrightnessLevel":10,"tamperSet":null,"limits":{"rooms":50,"groups":9,"cameras":25,"sensors":100,"users":50},"groupsEnabled":false,"firmware":{"version":"2.27.119","newVersionAvailable":false,"latestAvailableVersion":"","autoupdateEnabled":true},"ethernet":{"enabled":true,"dns":"192.168.1.10","ip":"192.168.1.107","gate":"192.168.1.1","dhcp":true,"mask":"255.255.255.0"},"armPreventionMode":"IGNORE_WARNINGS","panicSirenOnAnyTamper":false,"battery":{"chargeLevelPercentage":100,"state":"CHARGED"},"hardwareVersions":{"cpu":5,"wifi":0,"ethernet":1,"flash":3,"pcb":96,"rfm":10,"zwave":0,"modem":10},"warnings":{"hub":1,"allDevices":1},"fireAlarm":{"triggerOnAllSensors":false,"doubleImpulses":false,"alarmPropagationTimeoutSeconds":null,"alarmPropagationTimeoutExpirationTimestamp":0,"alarmPropagationState":"DISABLED","alarmPropagationDetails":{"multiApartmentBuildingModeEnabled":false}},"cms":{"address":"192.168.1.10","port":12312,"activeChannels":[],"pingPeriodSeconds":60,"gprsEnabled":false,"alarmRecoveryNotificationSettings":{"alarmRecoveryReportMode":"REPORT_IMMEDIATELY","additionalAlarmRecoveriesToReport":["PANIC"]},"addressReserve":"0.0.0.0","portReserve":0,"ethernetEnabled":true,"cmsProtocol":"SIA","cmsConnectionMode":"ALWAYS_UP","siaAccountNumber":"AAA","siaEncryptionKey":null,"siaEncryptionType":"OFF","sendPanicButtonLocation":false,"gprsAddress":"192.168.1.10","gprsPort":12312,"gprsAddressReserve":"0.0.0.0","gprsPortReserve":0},"imageUrls":null,"activeChannels":["ETHERNET"],"pingPeriodSeconds":60,"offlineAlarmSeconds":300,"ledIndicationMode":"HUB_SERVER_CONNECTION","jeweller":{"lostHeartbeatsThreshold":8,"detectorPingIntervalSeconds":36},"hubMalfunctions":[],"blockedByServiceProvider":false,"connectionLostAsMalfunction":true,"connectionTestInProgress":false,"alarmAsMalfunctionWhenArming":false,"hubAddress":null,"alarmVerification":{"verificationEnabled":false,"verificationTimeout":30},"alarmConfirmation":{"commonDevice":{"status":"DISABLED","timeoutMinutes":30,"confirmedAlarmOn":["DELAYED_DEVICES"]},"holdUpDevice":{"status":"DISABLED","timeoutMinutes":480}},"geoFence":null,"armPreventionConditions":["NO_EXTERNAL_POWER","HIGH_NOISE_LEVEL","LOW_BATTERY_CHARGE","TAMPERED","NO_SERVER_CONNECTION","NO_CMS_CONNECTION"],"restoreRequiredAfterAlarmCondition":[],"alarmCondition":[],"twoStageArming":{"enabled":false,"applicationTriggeredArming":{"countdownDurationSeconds":30,"state":"NOT_STARTED","expirationUnixTime":null},"deviceTriggeredArming":{"countdownDurationSeconds":60,"finalDoorBounceCountdownDurationSeconds":3,"state":"NOT_STARTED","expirationUnixTime":null}},"postAlarmIndicationRules":["UNCONFIRMED_ALARM","CONFIRMED_ALARM"],"connectivityNotificationSettings":{"channelOfflineAlarmDelaySeconds":300,"enabledChannelNotifications":["ETHERNET"]},"currentStandard":"EU","siaCpSettings":{"exitTimeRestart":false,"recentClosing":true,"alarmCancelWindow":true,"unvacatedPremises":false,"lastSecondsNotification":5,"silentExit":"DISABLED"},"batterySavingMode":{"batterySaveModeEnable":"DISABLED","batterySaveModeEnableV2":null,"batterySaveModeStatus":"NORMAL","batterySaveModeActiveTime":10,"batterySaveModePingPeriodMin":360,"batterySaveModeDisablingBySms":null,"batterySaveModeDisablingBySmsPassword":null},"gradeMode":"GRADE_2","eventDelayEnable":[],"jammingAsAlarm":"MALFUNCTION","interconnectWithoutHub":{"iwhNetworkTestState":"IWH_TEST_STOPPED","iwhNetworkTestEndTime":null,"iwhNetworkTestInitiatorId":"00000000","iwhEnabled":"DEACTIVATED","activeFireAlarms":[]},"modemImei":"","bukhoorMode":{"fpBukhoorEnabled":"DEACTIVATED","fpBukhoorState":"INACTIVE","fpBukhoorEndTime":null,"fpBukhoorForbidTimeStart":0,"fpBukhoorForbidTimeEnd":420},"externalPowerLossDelayTimer":0,"armPreventionsSystem":["BOLT_SWITCH_CONTACT"],"callSettings":null,"vdsLockingStatus":"NOT_STARTED","safeBatteryCharging":null,"photoOnDemandDetails":null,"batteryChargingFlags":null,"alarmWhenRingBreak":"ENABLED","sirenAlarmSoundRestart":"ENABLED","arcAlarmSettings":[],"eventLimit":0,"fwUpdateState":"EMPTY","devicePowerModes":["FP2_POWER_SAVE"],"noiseLevel":{"high":false,"avgValueChannel1":-101,"avgValueChannel2":-101,"avgValueDataChannel":-98},"panicSirenOnPanicButton":false,"debugLogState":"ETHERNET_ONLY","gsm":{"signalLevel":null,"gprsEnabled":false,"simCardState":"MISSING","networkStatus":null,"activeSimCard":0,"simCards":[{"number":"","trafficTxKb":0,"trafficRxKb":0,"lastTrafficResetTimestamp":0,"password":"","username":"","apn":"internet","balanceNumber":""},{"number":"","trafficTxKb":0,"trafficRxKb":0,"lastTrafficResetTimestamp":0,"password":"","username":"","apn":"internet","balanceNumber":""}],"disableIcmpBeforeConnecting":false,"virtualOperatorAllowed":false,"roamingEnabled":false},"passwordLength":0}
[2025-03-22 14:39:06][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:39:06][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0%2Fdevices&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:39:06][DEBUG] : [{"id":"302D4B3F","deviceType":"WaterStop","deviceName":"Water Valve Main","roomId":"00000001","groupId":null,"color":"WHITE","online":true}]
[2025-03-22 14:39:06][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0%2Fdevices%2F302D4B3F&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:39:06][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0%2Fgroups&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:39:06][DEBUG] : []
[2025-03-22 14:42:19][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:42:19][DEBUG] : [{"hubId":"002257A0","hubBindingRole":"MASTER"}]
[2025-03-22 14:42:19][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:42:19][DEBUG] : {"hubSubtype":"HUB_2","name":"Ajax Hub 2","id":"002257A0","state":"DISARMED","timeZone":"EUROPE_AMSTERDAM","color":"BLACK","capabilities":["DFU"],"tampered":false,"externallyPowered":true,"ledBrightnessLevel":10,"chargingMode":"CONTINUOUS","tamperSet":null,"noiseLevel":{"high":false,"avgValueChannel1":-101,"avgValueChannel2":-101,"avgValueDataChannel":-98},"debugLogState":"ETHERNET_ONLY","panicSirenOnPanicButton":false,"limits":{"rooms":50,"groups":9,"cameras":25,"sensors":100,"users":50},"groupsEnabled":false,"firmware":{"version":"2.27.119","newVersionAvailable":false,"latestAvailableVersion":"","autoupdateEnabled":true},"ethernet":{"enabled":true,"dns":"192.168.1.10","ip":"192.168.1.107","gate":"192.168.1.1","dhcp":true,"mask":"255.255.255.0"},"armPreventionMode":"IGNORE_WARNINGS","panicSirenOnAnyTamper":false,"battery":{"chargeLevelPercentage":100,"state":"CHARGED"},"hardwareVersions":{"cpu":5,"wifi":0,"ethernet":1,"flash":3,"pcb":96,"rfm":10,"zwave":0,"modem":10},"warnings":{"hub":1,"allDevices":1},"fireAlarm":{"triggerOnAllSensors":false,"doubleImpulses":false,"alarmPropagationTimeoutSeconds":null,"alarmPropagationTimeoutExpirationTimestamp":0,"alarmPropagationState":"DISABLED","alarmPropagationDetails":{"multiApartmentBuildingModeEnabled":false}},"cms":{"address":"192.168.1.10","port":12312,"addressReserve":"0.0.0.0","portReserve":0,"ethernetEnabled":true,"cmsProtocol":"SIA","cmsConnectionMode":"ALWAYS_UP","siaAccountNumber":"AAA","siaEncryptionKey":null,"siaEncryptionType":"OFF","sendPanicButtonLocation":false,"alarmRecoveryNotificationSettings":{"alarmRecoveryReportMode":"REPORT_IMMEDIATELY","additionalAlarmRecoveriesToReport":["PANIC"]},"gprsAddress":"192.168.1.10","gprsPort":12312,"gprsAddressReserve":"0.0.0.0","gprsPortReserve":0,"gprsEnabled":false,"activeChannels":[],"pingPeriodSeconds":60},"imageUrls":null,"activeChannels":["ETHERNET"],"pingPeriodSeconds":60,"offlineAlarmSeconds":300,"ledIndicationMode":"HUB_SERVER_CONNECTION","jeweller":{"lostHeartbeatsThreshold":8,"detectorPingIntervalSeconds":36},"connectionTestInProgress":false,"hubMalfunctions":[],"blockedByServiceProvider":false,"connectionLostAsMalfunction":true,"alarmAsMalfunctionWhenArming":false,"hubAddress":null,"alarmVerification":{"verificationEnabled":false,"verificationTimeout":30},"alarmConfirmation":{"commonDevice":{"status":"DISABLED","timeoutMinutes":30,"confirmedAlarmOn":["DELAYED_DEVICES"]},"holdUpDevice":{"status":"DISABLED","timeoutMinutes":480}},"geoFence":null,"armPreventionConditions":["LOW_BATTERY_CHARGE","TAMPERED","NO_CMS_CONNECTION","HIGH_NOISE_LEVEL","NO_EXTERNAL_POWER","NO_SERVER_CONNECTION"],"restoreRequiredAfterAlarmCondition":[],"alarmCondition":[],"twoStageArming":{"enabled":false,"applicationTriggeredArming":{"countdownDurationSeconds":30,"state":"NOT_STARTED","expirationUnixTime":null},"deviceTriggeredArming":{"countdownDurationSeconds":60,"finalDoorBounceCountdownDurationSeconds":3,"state":"NOT_STARTED","expirationUnixTime":null}},"postAlarmIndicationRules":["CONFIRMED_ALARM","UNCONFIRMED_ALARM"],"connectivityNotificationSettings":{"channelOfflineAlarmDelaySeconds":300,"enabledChannelNotifications":["ETHERNET"]},"currentStandard":"EU","siaCpSettings":{"exitTimeRestart":false,"recentClosing":true,"alarmCancelWindow":true,"unvacatedPremises":false,"lastSecondsNotification":5,"silentExit":"DISABLED"},"batterySavingMode":{"batterySaveModeEnable":"DISABLED","batterySaveModeEnableV2":null,"batterySaveModeStatus":"NORMAL","batterySaveModeActiveTime":10,"batterySaveModePingPeriodMin":360,"batterySaveModeDisablingBySms":null,"batterySaveModeDisablingBySmsPassword":null},"gradeMode":"GRADE_2","eventDelayEnable":[],"jammingAsAlarm":"MALFUNCTION","interconnectWithoutHub":{"iwhNetworkTestState":"IWH_TEST_STOPPED","iwhNetworkTestEndTime":null,"iwhNetworkTestInitiatorId":"00000000","iwhEnabled":"DEACTIVATED","activeFireAlarms":[]},"modemImei":"","bukhoorMode":{"fpBukhoorEnabled":"DEACTIVATED","fpBukhoorState":"INACTIVE","fpBukhoorEndTime":null,"fpBukhoorForbidTimeStart":0,"fpBukhoorForbidTimeEnd":420},"externalPowerLossDelayTimer":0,"armPreventionsSystem":["BOLT_SWITCH_CONTACT"],"callSettings":null,"vdsLockingStatus":"NOT_STARTED","safeBatteryCharging":null,"photoOnDemandDetails":null,"batteryChargingFlags":null,"alarmWhenRingBreak":"ENABLED","sirenAlarmSoundRestart":"ENABLED","arcAlarmSettings":[],"eventLimit":0,"fwUpdateState":"EMPTY","devicePowerModes":["FP2_POWER_SAVE"],"gsm":{"signalLevel":null,"gprsEnabled":false,"simCardState":"MISSING","networkStatus":null,"activeSimCard":0,"simCards":[{"number":"","trafficTxKb":0,"trafficRxKb":0,"lastTrafficResetTimestamp":0,"password":"","username":"","apn":"internet","balanceNumber":""},{"number":"","trafficTxKb":0,"trafficRxKb":0,"lastTrafficResetTimestamp":0,"password":"","username":"","apn":"internet","balanceNumber":""}],"disableIcmpBeforeConnecting":false,"virtualOperatorAllowed":false,"roamingEnabled":false},"passwordLength":0}
[2025-03-22 14:42:19][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0%2Fdevices&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:42:20][DEBUG] : [{"id":"302D4B3F","deviceType":"WaterStop","deviceName":"Water Valve Main","roomId":"00000001","groupId":null,"color":"WHITE","online":true}]
[2025-03-22 14:42:20][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0%2Fdevices%2F302D4B3F&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:42:20][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F16FD757B%2Fhubs%2F002257A0%2Fgroups&session_token=VXj5ICTYJSG8_b1Ttz6nE6OAeVg => null
[2025-03-22 14:42:20][DEBUG] : []
Thank you, posted!
Any updates on this request?
One more try to see if anyone can make this connection. Would be no problem for me to pay some to get this integration.
There is probably a misunderstanding: users here will try to help you in case of issue but this community forum is not a helpdesk or a place to submit request for support or for new feature.
You can contact the support directly by creating a ticket.
will do, thank you!
