Warning cache pip dans http.error
Je rencontre ce message sur « analyse logs »
JEEDOM ATLAS 4.5.1 : The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user.
The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Puis-je avoir de l’aide, merci
RAY23
Il manque la page santé de.votre jeedom.
Pour les logs:
On gagne en lisibilité et ainsi ils ne sont pas tronqués.
Auriez-vous rebooté depuis la mise à jour?
Si oui, tester de restaurer les droits.
Re bonjour,
Je ne suis pas très habile avec Jeedom ATLAS et l’informatique en général.
Windows a été réinitialisé sur mon PC
J’ai fait toutes les vérifications système dans OS/DB
Voici la copie de http.error (2.4 Ko)
0000|WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
0001|WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
0002|WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
0003|WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
0004|WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
0005|[Fri Dec 19 14:11:34.270960 2025] [mpm_prefork:notice] [pid 910512] AH00170: caught SIGWINCH, shutting down gracefully
0006|[Fri Dec 19 14:11:34.283447 2025] [php7:error] [pid 778325] [client 192.168.1.115:60587] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] No such file or directory in /var/www/html/core/class/DB.class.php:48\nStack trace:\n#0 /var/www/html/core/class/DB.class.php(48): PDO->__construct()\n#1 /var/www/html/core/class/DB.class.php(68): DB::initConnection()\n#2 /var/www/html/core/class/DB.class.php(91): DB::getConnection()\n#3 /var/www/html/core/class/config.class.php(285): DB::Prepare()\n#4 /var/www/html/core/class/log.class.php(62): config::getLogLevelPlugin()\n#5 /var/www/html/core/class/log.class.php(512): log::getConfig()\n#6 /var/www/html/core/php/utils.inc.php(253): log::exception()\n#7 /var/www/html/core/ajax/event.ajax.php(36): displayException()\n#8 {main}\n  thrown in /var/www/html/core/class/DB.class.php on line 48
0007|[Fri Dec 19 14:12:31.524031 2025] [mpm_prefork:notice] [pid 1212] AH00163: Apache/2.4.56 (Debian) configured -- resuming normal operations
0008|[Fri Dec 19 14:12:31.524763 2025] [core:notice] [pid 1212] AH00094: Command line: '/usr/sbin/apache2'
En espérant que cela vous convienne
RAY23
Voici les pages
Compte tenu du message je suggère déjà de faire :
Réglages / Système / Configuration / _OS/DB → « Rétablissement des droits des dossiers et fichiers » :
Ca peut pas faire de mal et au mieux ca corrige le problème de droits :wink:
Edit : Ooops vous avez déjà fait la manip… Désolé :face_with_open_eyes_and_hand_over_mouth:
Ce n’est qu’un avertissement sans impact ni conséquence, aucune inquiétude à avoir.
Bonsoir, merci Aurélien pour votre information.
bonne soirée et merci aussi à ceux qui ont participés.
RAY23
