J’ai un module zigbee (vanne d’arrosage WOOX) qui a un attribut « off_wait_time » dans le json brut :
"ieee": "50:32:5f:ff:fe:36:1f:e3",
"nwk": 8312,
"status": 2,
"lqi": "104",
"rssi": "-74",
"last_seen": "1664710413.761698",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZ3210_eymunffl",
"model": "TS0101",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 69
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3210_eymunffl"
"id": 5,
"name": "model",
"value": "TS0101"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"name": "off_wait_time",
"value": 0
"id": 61184,
"name": "Cluster",
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": []
"signature": {
"model": "TS0101",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
4,
5,
6,
61184,
1
25,
10
"class": "zigpy.device"
Je conclue du nom (peut-être à tord) que je peux envoyer à ce module un ordre d’allumage avec un temps d’allumage, ce qui m’évitera d’avoir à envoyer l’ordre d’extinction (et au passage, m’évitera l’inondation en cas de coupure de courant pendant l’allumage).
Mais je n’arrive pas à comprendre comment utiliser ce paramètre.
Quelqu’un aurait une idée ?
Merci d’avance !
