Impossible de mettre à jour pysmbc sur mon rpi.
pi@jeedomyb:~ $ sudo pip3 install --no-cache --force-reinstall --upgrade pysmbc
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting pysmbc
Downloading pysmbc-1.0.25.1.tar.gz (33 kB)
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [6 lines of output]
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: invalid command 'egg_info'
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Des idées ?
