Upgrade de 4.6.1 en 4.6.2 : blocage à 60% sur mes 2 jeedom
J’ai lancé l’upgrade de mes 2 jeedom et l’upgrade est stoppée à 60% :
\[START UPDATE\]
\*\*\*\*Update from 4.6.1 (2026-10-21 21:42:09)\*\*\*\*
Parameters : {"preUpdate":"0","backup::before":"1","core":"1","force":"0","plugins":"1","update::reapply":""}
Send begin of update event | OK
Check update | OK
Check rights | OK
\[START BACKUP\]
\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*Start of Jeedom backup at 2026-10-21 21:42:11\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*
Send begin backup event | OK
Checking files rights | OK
Backing up plugin deconz | OK
Checking  table cache | OK
Checking  table cmd | OK
Checking  table config | OK
Checking  table cron | OK
Checking  table dataStore | OK
Checking  table eqLogic | OK
Checking  table history | OK
Checking  table historyArch | OK
Checking  table interactDef | OK
Checking  table interactQuery | OK
Checking  table jeelink_master | OK
Checking  table listener | OK
Checking  table message | OK
Checking  table note | OK
Checking  table object | OK
Checking  table plan | OK
Checking  table plan3d | OK
Checking  table plan3dHeader | OK
Checking  table planHeader | OK
Checking  table queue | OK
Checking  table scenario | OK
Checking  table scenarioElement | OK
Checking  table scenarioExpression | OK
Checking  table scenarioSubElement | OK
Checking  table timeline | OK
Checking  table update | OK
Checking  table user | OK
Checking  table view | OK
Checking  table viewData | OK
Checking  table viewZone | OK
Checking  table widgets | OK
Backing up database | OK
Cache persistence: | OK
Creating archive | OK
Cleaning old backup | OK
Limiting backup size to 500 Mb | OK
Backup name: /var/www/html/core/php///backup/backup-JeedomSensors-4.6.1-2026-10-21-21h42.tar.gz
Send end backup event | OK
Backup operation duration: 42s
\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*Jeedom backup end\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*
\[END BACKUP SUCCESS\]
Download url : https://github.com/jeedom/core/archive/master.zip
Download in progress--2026-10-21 20:42:53--  https://github.com/jeedom/core/archive/master.zip
Resolving github.com (github.com) 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443 connected.
HTTP request sent, awaiting response 302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/master \[following\]
--2026-10-21 20:42:54--  https://codeload.github.com/jeedom/core/zip/refs/heads/master
Resolving codeload.github.com (codeload.github.com) 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: 83841940 (80M) \[application/zip\]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K        3% 9.59M 8s
3072K        7% 11.0M 7s
6144K       11% 11.0M 7s
9216K       15% 11.0M 6s
12288K       18% 11.0M 6s
15360K       22% 11.0M 6s
18432K       26% 10.3M 6s
21504K       30% 11.8M 5s
24576K       33% 11.0M 5s
27648K       37% 11.0M 5s
30720K       41% 11.0M 4s
33792K       45% 11.0M 4s
36864K       48% 11.0M 4s
39936K       52% 11.0M 3s
43008K       56% 11.0M 3s
46080K       60% 11.0M 3s
49152K       63% 11.0M 3s
52224K       67% 11.0M 2s
55296K       71% 11.0M 2s
58368K       75% 11.0M 2s
61440K       78% 11.0M 2s
64512K       82% 11.0M 1s
67584K       86% 11.0M 1s
70656K       90% 10.1M 1s
73728K       93% 12.0M 0s
76800K       97% 11.0M 0s
79872K                       100% 10.7M=7.3s
2026-10-21 20:43:01 (11.0 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved \[83841940/83841940\] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task | OK
Disable all scenario | OK
Remove vendor folder (not use anymore) | OK
Update modification date of unzip file | OK
Moving filesIgnore file /tmp/jeedom_unzip/core-master///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-master///docs/pt_PT/noteVersion.md because size is 0 | OK
Remove temporary files | OK
Remove useless files
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
find: '/var/www/html/install//script/\*': No such file or directory | OK
Update composer file | OK
Update jeedom information date | OK
Upgrading from: 4.6.1 to 4.6.2
Update system into : 4.6.2warning: commands will be executed using /bin/sh
job 4 at Wed Oct 21 20:43:00 2026
Module headers already enabled | OK
Check jeedom consistency
\[START CONSISTENCY\]
\[START CHECK AND FIX DB\]
\[END CHECK AND FIX DB\]
Check jeedom package
que puise-je faire ?
Bonsoir, c’est normal, relance la mise a jour du core :wink:
Merci !
j’avais vu qu’il fallait faire l’installation 2 fois. Mais pas compris que la première installation ne se finissait pas…
Bonjour. Merci pour la solution. Pourquoi est-ce que c’est normal ? Est-ce que cette « normalité » a déjà été documentée quelque part ?
Bonjour.
Ce qui est normal, c’est que cela est attendu et l’explication a été donnée aussi : comme le moteur de mise à jour doit aussi se mettre à jour.
Une fois pour Jeedom et ensuite une fois pour lui.
Je suis passé en Jeedom 4.6.2 sur ma Luna Debian 11, mais la procédure de maj s’est arrêtée à 60% sur la ligne CheckJeedomPackage; sur le Desktop j’ai constaté une erreur Javascript (icone ! en haut à droite) : j’ai une ligne avec « Uncaught TypeError jeeP.getJeedomLog is not a function ».
Sur l’écran des maj, j’ai cliqué sur « Verifier les Maj » : le signal de l’erreur Javascript a disparu et la 4.6.2 a l’air d’être installée.
Je vérifie ma version PHP je suis en 7.4.33 avec Debian 11.11.
=> la page Santé indique des erreurs sur les plugins Camera (démon configuration NOK arrêté) , Ecodevice (démon configuration NOK arrêté) , JeeZigbee (Démon:configuration NOK) , MQTTMAnager (Démon:configuration NOK), ZwaveJS (Démon:configuration NOK) . Avec message « les crons et démons sont desactivés ».
Que dois-je faire?
Est-ce que la maj 4.6.2 s’est bien installée?
Bonsoir.
Comme dit quelques messages au dessus, il faut exécuter 2 fois la mise à jour de Jeedom 4.6.2
