# Bug Report
## What happened
Paired Hue remote to network with deCONZ coordin…ator. Pairing is successful, configuration is successful. Pressing a button produces Zigbee messages. However, trying to unbind the remote from the coordinator always fails:
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:45:36: Received MQTT message on 'zigbee2mqtt/bridge/unbind/0x0017880104ad2466' with data 'coordinator'
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:45:36: unbinding cluster 'genScenes' from '0x0017880104ad2466' to 'Coordinator'
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:error 2020-08-23 22:45:36: Failed to unbind cluster 'genScenes' from '0x0017880104ad2466' to 'Coordinator' (TypeError: Cannot read property 'message' of undefined)
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:45:36: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"cluster":"genScenes","from":"0x0017880104ad2466","to":"Coordinator"},"type":"device_unbind_failed"}'
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:45:36: unbinding cluster 'genOnOff' from '0x0017880104ad2466' to 'Coordinator'
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:error 2020-08-23 22:45:36: Failed to unbind cluster 'genOnOff' from '0x0017880104ad2466' to 'Coordinator' (TypeError: Cannot read property 'message' of undefined)
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:45:36: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"cluster":"genOnOff","from":"0x0017880104ad2466","to":"Coordinator"},"type":"device_unbind_failed"}'
Aug 23 22:45:36 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:45:36: unbinding cluster 'genLevelCtrl' from '0x0017880104ad2466' to 'Coordinator'
Aug 23 22:45:37 zacate npm[1323974]: Zigbee2MQTT:error 2020-08-23 22:45:37: Failed to unbind cluster 'genLevelCtrl' from '0x0017880104ad2466' to 'Coordinator' (TypeError: Cannot read property 'message' of undefined)
Aug 23 22:45:37 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:45:37: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"cluster":"genLevelCtrl","from":"0x0017880104ad2466","to":"Coordinator"},"type":"device_unbind_failed"}'
Binding the remote to the lamp is successful, though:
Aug 23 22:46:19 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:19: Received MQTT message on 'zigbee2mqtt/bridge/bind/0x0017880104ad2466' with data '0x00178801083b7407'
Aug 23 22:46:19 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:19: binding cluster 'genScenes' from '0x0017880104ad2466' to '0x00178801083b7407'
Aug 23 22:46:21 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:21: Received Zigbee message from '0x0017880104ad2466', type 'commandHueNotification', cluster 'manuSpecificPhilips', data '{"button":4,"time":0,"type":0,"unknown1":3145728,"unknown2":0}' from endpoint 2 with groupID null
Aug 23 22:46:21 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:21: Received Zigbee message from '0x0017880104ad2466', type 'commandOffWithEffect', cluster 'genOnOff', data '{"effectid":0,"effectvariant":0}' from endpoint 1 with groupID null
Aug 23 22:46:22 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:22: Received Zigbee message from '0x0017880104ad2466', type 'commandHueNotification', cluster 'manuSpecificPhilips', data '{"button":4,"time":1,"type":2,"unknown1":3145728,"unknown2":0}' from endpoint 2 with groupID null
Aug 23 22:46:22 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:22: MQTT publish: topic 'zigbee2mqtt/0x0017880104ad2466', payload '{"action":"off-press","battery":87.5,"counter":1,"duration":0,"linkquality":130,"update_available":false}'
Aug 23 22:46:22 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:22: MQTT publish: topic 'zigbee2mqtt/0x0017880104ad2466', payload '{"action":"","battery":87.5,"counter":1,"linkquality":130,"update_available":false}'
Aug 23 22:46:22 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:22: MQTT publish: topic 'zigbee2mqtt/0x0017880104ad2466/action', payload 'off-press'
Aug 23 22:46:24 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:24: Successfully bound cluster 'genScenes' from '0x0017880104ad2466' to '0x00178801083b7407'
Aug 23 22:46:24 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:24: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"cluster":"genScenes","from":"0x0017880104ad2466","to":"0x00178801083b7407"},"type":"device_bind"}'
Aug 23 22:46:24 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:24: binding cluster 'genOnOff' from '0x0017880104ad2466' to '0x00178801083b7407'
Aug 23 22:46:25 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:25: Successfully bound cluster 'genOnOff' from '0x0017880104ad2466' to '0x00178801083b7407'
Aug 23 22:46:25 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:25: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"cluster":"genOnOff","from":"0x0017880104ad2466","to":"0x00178801083b7407"},"type":"device_bind"}'
Aug 23 22:46:25 zacate npm[1323974]: Zigbee2MQTT:debug 2020-08-23 22:46:25: binding cluster 'genLevelCtrl' from '0x0017880104ad2466' to '0x00178801083b7407'
Aug 23 22:46:25 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:25: Successfully bound cluster 'genLevelCtrl' from '0x0017880104ad2466' to '0x00178801083b7407'
Aug 23 22:46:25 zacate npm[1323974]: Zigbee2MQTT:info 2020-08-23 22:46:25: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"cluster":"genLevelCtrl","from":"0x0017880104ad2466","to":"0x00178801083b7407"},"type":"device_bind"}'
The lamp cannot be controlled directly from the remote, presumably because it was not previously unbound from the coordinator.
## What did you expect to happen
Unbind successful. Subsequent bind leading to lamp controllable by remote. Using the CC2531, this procedure worked.
## Debug Info
MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"410f6a0","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":88,"product":0,"revision":"0x26580700","transportrev":0},"type":"ConBee2"},"log_level":"debug","network":{"channel":15,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":true,"version":"1.14.3-dev"}'
Zigbee2MQTT version:
Adapter hardware:
Adapter firmware version:
