Unable to obtain driver for chrome using Selenium Manager
ce que je peux tester c’est de créer la fameuse clé pour voir si cette colonne disparait et si ça règle le problème?
Tu peux mais a mon avis ca risque de changer la colonne en autre chose.
J aimerai surtout trouver comment cette colonne arrive
Sinon attendre demain (ou mardi) que le traitement de renouvellement passe chez @Nemeraud si la correction est ok et quil ny a pas de nouveau element alors je publierai une nouvelle beta
@tomitomas
j’ai de nouveau une erreur qui apparait
(Session info: headless chrome=89.0.4389.114)
Stacktrace:
#0 0xaaaab694cd48
#1 0xaaaab68ef6cc
#2 0xaaaab6682d84
#3 0xaaaab66b4898
#4 0xaaaab66b323c
#5 0xaaaab66b1844
#6 0xaaaab66b0cc4
#7 0xaaaab66a8cb0
#8 0xaaaab66a8ae0
#9 0xaaaab66ddac8
#10 0xaaaab66a6f50
#11 0xaaaab66a83d4
#12 0xaaaab691aec8
#13 0xaaaab6928aa0
#14 0xaaaab6928804
#15 0xaaaab692ccbc
#16 0xaaaab6929240
#17 0xaaaab691116c
#18 0xaaaab693fb3c
#19 0xaaaab6957398
#20 0xffff9ad3f7e4 start_thread
#21 0xffff9a3f7adc
[2023-12-10 22:25:31]ERROR : [Multimédia][NoIP] error while executing Python script: Message: element click intercepted: Element  is not clickable at point (1096, 416). Other element would receive the click:
   (Session info: headless chrome=89.0.4389.114) Stacktrace: #0 0xaaaab694cd48  #1 0xaaaab68ef6cc  #2 0xaaaab6682d84  #3 0xaaaab66b4898  #4 0xaaaab66b323c  #5 0xaaaab66b1844  #6 0xaaaab66b0cc4  #7 0xaaaab66a8cb0  #8 0xaaaab66a8ae0  #9 0xaaaab66ddac8  #10 0xaaaab66a6f50  #11 0xaaaab66a83d4  #12 0xaaaab691aec8  #13 0xaaaab6928aa0  #14 0xaaaab6928804  #15 0xaaaab692ccbc  #16 0xaaaab6929240  #17 0xaaaab691116c  #18 0xaaaab693fb3c  #19 0xaaaab6957398  #20 0xffff9ad3f7e4 start_thread #21 0xffff9a3f7adc
[2023-12-10 22:25:31]DEBUG : Set a new refresh in 5min
[2023-12-10 22:25:31]DEBUG : Task 'refreshInfoEq' scheduled at 2023-12-10 22:30:31
[2023-12-10 22:30:08]INFO : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user xxxxxxxx --pwd "***********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2023-12-10 22:30:09]INFO : Log level : info
[2023-12-10 22:30:09]INFO : User : xxxxxxxxxxxxx
[2023-12-10 22:30:09]INFO : Threshold : 7
[2023-12-10 22:30:09]INFO : Renew : 1
[2023-12-10 22:30:09]INFO : ForcePath : 1
[2023-12-10 22:30:23]DEBUG : Pas de mise à jour d'IP à réaliser
Bonjour Tomitomas,
je viens de vérifier et j’ai cette colonne aussi de présente sur mon compte.
Ce qui m interesse surtout c est comment cette colonne arrive, plutot que combien d utilisateurs sont concernés :slight_smile:
Alors la tu me pose la question du siècle, je n’ai pas souvenir d’une quelconque manipulation pour l’avoir. Par contre, quand je clique comme si je voulais créé la clé j’obtiens l’image ci dessous
Peut etre que cela peux t’aider
pas trop, mais merci !
la correction que j’ai mise chez @Nemeraud semble fonctionner aussi bien pour les controles que pour le renouvellement mensuel
→ les modif sont en beta du jour !
Bonjour Tomas,
Je viens de faire la mise a jour et j’obtiens un message d’erreur.
Voici les logs
[2023-12-13 03:48:05][DEBUG] : [Informatique][Maison] file content:
[2023-12-13 03:48:05][ERROR] : [Informatique][Maison] file content empty
[2023-12-13 03:48:05][DEBUG] : Set a new refresh in 5min
[2023-12-13 03:48:05][DEBUG] : Task 'refreshInfoEq' scheduled at 2023-12-13 03:53:05
[2023-12-13 03:53:04][INFO] : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user frs051 --pwd "**********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 0<<
[2023-12-13 03:53:05][INFO] : Log level : info
[2023-12-13 03:53:05][INFO] : User : frs051
[2023-12-13 03:53:05][INFO] : Threshold : 7
[2023-12-13 03:53:05][INFO] : Renew : 1
[2023-12-13 03:53:05][INFO] : ForcePath : 0
[2023-12-13 03:53:05][ERROR] : Exception has been thrown. Message: Unable to obtain driver for chrome using Selenium Manager.; For documentation on this error, please visit: https://www.selenium.dev/documentation/webdriver/troubleshooting/errors/driver_location
[2023-12-13 03:53:05][DEBUG] : [Informatique][Maison] file content:
[2023-12-13 03:53:05][ERROR] : [Informatique][Maison] file content empty
[2023-12-13 03:53:05][DEBUG] : Set a new refresh in 5min
[2023-12-13 03:53:05][DEBUG] : Task 'refreshInfoEq' scheduled at 2023-12-13 03:58:05
[2023-12-13 03:53:46][DEBUG] : Execution de la commande refresh
[2023-12-13 03:53:46][INFO] : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user frs051 --pwd "**********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2023-12-13 03:53:47][INFO] : Log level : info
[2023-12-13 03:53:47][INFO] : User : frs051
[2023-12-13 03:53:47][INFO] : Threshold : 7
[2023-12-13 03:53:47][INFO] : Renew : 1
[2023-12-13 03:53:47][INFO] : ForcePath : 1
[2023-12-13 03:58:04][INFO] : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user frs051 --pwd "**********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2023-12-13 03:58:05][INFO] : Log level : info
[2023-12-13 03:58:05][INFO] : User : frs051
[2023-12-13 03:58:05][INFO] : Threshold : 7
[2023-12-13 03:58:05][INFO] : Renew : 1
[2023-12-13 03:58:05][INFO] : ForcePath : 1
[2023-12-13 04:00:19][DEBUG] : Pas de mise à jour d'IP à réaliser
[2023-12-13 04:01:01][DEBUG] : Execution de la commande refresh
[2023-12-13 04:01:01][INFO] : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel info --user frs051 --pwd "**********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2023-12-13 04:01:08][INFO] : Log level : info
[2023-12-13 04:01:08][INFO] : User : frs051
[2023-12-13 04:01:08][INFO] : Threshold : 7
[2023-12-13 04:01:08][INFO] : Renew : 1
[2023-12-13 04:01:08][INFO] : ForcePath : 1
[2023-12-13 04:01:25][INFO] : Start running process
[2023-12-13 04:01:25][INFO] : Opening https://www.noip.com/login...
[2023-12-13 04:01:43][INFO] : Logging in...
[2023-12-13 04:02:45][INFO] : Opening https://my.noip.com/dynamic-dns...
[2023-12-13 04:03:33][INFO] : anderigwesha.ddns.net expires in 17 days
[2023-12-13 04:03:34][INFO] : chrisisaestemel.ddns.net expires in 29 days
[2023-12-13 04:03:35][INFO] : Confirmed hosts: 0
[2023-12-13 04:03:36][DEBUG] : [Informatique][Maison] file content: [{"hostname": "***********.ddns.net", "expirationdays": 17, "renewed": "ok", "ip": "***.***.***.**"}, {"hostname": "***********.ddns.net", "expirationdays": 29, "renewed": "ok", "ip": "***.***.***.**"}]
[2023-12-13 04:03:36][DEBUG] : will update domain with following data : {"hostname":"***********.ddns.net","expirationdays":17,"renewed":"ok","ip":"***.***.***.**"}
[2023-12-13 04:03:36][DEBUG] : cmd creation => Hostname [hostname]
[2023-12-13 04:03:36][DEBUG] : cmd creation => Days before expiration [expiration]
[2023-12-13 04:03:36][DEBUG] : cmd creation => Renew status [renew]
[2023-12-13 04:03:36][DEBUG] : cmd creation => linked IP [iplinked]
[2023-12-13 04:03:36][DEBUG] : cmd creation => Expiration date [endDate]
[2023-12-13 04:03:36][INFO] : Domaine créé : ***********.ddns.net
[2023-12-13 04:03:37][DEBUG] : will update domain with following data : {"hostname":"***********.ddns.net","expirationdays":29,"renewed":"ok","ip":"***.***.***.**"}
[2023-12-13 04:03:37][DEBUG] : cmd creation => Hostname [hostname]
[2023-12-13 04:03:37][DEBUG] : cmd creation => Days before expiration [expiration]
[2023-12-13 04:03:37][DEBUG] : cmd creation => Renew status [renew]
[2023-12-13 04:03:37][DEBUG] : cmd creation => linked IP [iplinked]
[2023-12-13 04:03:37][DEBUG] : cmd creation => Expiration date [endDate]
[2023-12-13 04:03:37][INFO] : Domaine créé : ***********.ddns.net
[2023-12-13 04:03:49][ERROR] : Exception has been thrown. Message: session not created
from timeout: Timed out receiving message from renderer: 600.000
  (Session info: headless chrome=90.0.4430.212)
Stacktrace:
#0 0x000000b7e648 <unknown>
#1 0x000000b3bcf8 <unknown>
#2 0x000000975d5e <unknown>
#3 0x000000967cb8 <unknown>
#4 0x0000009671b2 <unknown>
#5 0x0000009674ac <unknown>
#6 0x000000966e6a <unknown>
#7 0x00000096fd98 <unknown>
#8 0x000000966e2e <unknown>
#9 0x0000009679f2 <unknown>
#10 0x0000009671b2 <unknown>
#11 0x0000009674ac <unknown>
#12 0x000000966e6a <unknown>
#13 0x00000096c3aa <unknown>
#14 0x00000096c3f4 <unknown>
#15 0x000000966e2e <unknown>
#16 0x0000009679f2 <unknown>
#17 0x0000009671b2 <unknown>
#18 0x0000009674ac <unknown>
#19 0x000000966e6a <unknown>
#20 0x00000096e5cc <unknown>
#21 0x000000966e2e <unknown>
#22 0x0000009679f2 <unknown>
#23 0x0000009671b2 <unknown>
#24 0x0000009674ac <unknown>
#25 0x000000966e6a <unknown>
#26 0x00000096c9f2 <unknown>
#27 0x000000966e2e <unknown>
#28 0x0000009679f2 <unknown>
#29 0x0000009671b2 <unknown>
#30 0x0000009674ac <unknown>
#31 0x000000966e6a <unknown>
#32 0x00000096bb44 <unknown>
#33 0x000000966e2e <unknown>
#34 0x0000009679f2 <unknown>
#35 0x0000009671b2 <unknown>
#36 0x0000009674ac <unknown>
#37 0x000000966e6a <unknown>
#38 0x0000009639ee <unknown>
#39 0x000000966e2e <unknown>
#40 0x000000966dc8 <unknown>
#41 0x000000966a78 <unknown>
#42 0x000000976e9c <unknown>
#43 0x0000009b1502 <unknown>
#44 0x0000009ad6a4 <unknown>
#45 0x00000098fc8e <unknown>
#46 0x000000990c12 <unknown>
#47 0x000000b59f9a <unknown>
#48 0x000000b643d0 <unknown>
#49 0x000000b640f8 <unknown>
#50 0x000000b647be <unknown>
#51 0x000000b676d8 <unknown>
#52 0x000000b64a60 <unknown>
#53 0x000000b536e4 <unknown>
#54 0x000000b74d02 <unknown>
#55 0x000000b74e36 <unknown>
#56 0x000000b85bb4 <unknown>
[2023-12-13 04:03:49][DEBUG] : [Informatique][Maison] file content: [{"hostname": "***********.ddns.net", "expirationdays": 17, "renewed": "ok", "ip": "***.***.***.**"}, {"hostname": "***********.ddns.net", "expirationdays": 29, "renewed": "ok", "ip": "***.***.***.**"}]
[2023-12-13 04:03:49][DEBUG] : will update domain with following data : {"hostname":"***********.ddns.net","expirationdays":17,"renewed":"ok","ip":"***.***.***.**"}
[2023-12-13 04:03:49][DEBUG] : will update domain with following data : {"hostname":"***********.ddns.net","expirationdays":29,"renewed":"ok","ip":"***.***.***.**"}
tes 2 domaines sont créés et tu récupères les infos les concernant, donc on est bon ! :wink:
@maxnumberone sujet à cloturer, merci
J’ai un soucis avec le plugin. Comme beaucoup, mon Jeedom principale est en Debian 10. En attendant de migrer, pas grave, j’ai des raspberry esclave en Debian 11. Du coup j’ai installé le plugin dessus, mais ça ne fontionne pas, avec une erreur assez similaire.
Elle est donc en Debian 11, python 3.9.2, Jeedom en 4.3.21 et plugin No-ip sur la dernière beta. Par contre c’est une fresh install du plugin du coup (peut etre ce qui diffère des autres dans ce topic ^^)
Launch install of noip dependencies
-- Current OS version :
Description:	Debian GNU/Linux 11 (bullseye)
-- Updating repo...
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
-- Installation of python3 and dependencies
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
python-dev-is-python2 is already the newest version (2.7.18-9).
0 upgraded, 0 newly installed, 0 to remove and 35 not upgraded.
-- Installed version of Python :
Python 3.9.2
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
Package python-requests is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python-requests' has no installation candidate
-- Installation of chromium
chromium is already the newest version (120.0.6099.129-1~deb11u1).
-- Installed version of pip :
pip 20.3.4 from /usr/lib/python3/dist-packages/pip (python 3.9)
-- Installation of python library 'selenium' with command pip3
cat: /tmp/jeedom/noip/dependancy_noip: No such file or directory
-- Installation of dependencies is done !
[2024-01-01 19:31:16]DEBUG : Execution de la commande refresh
[2024-01-01 19:31:16]INFO : Starting daemon with cmd >>sudo python3 /var/www/html/plugins/noip/core/class/../../resources/noip-renew.py  --loglevel debug --user ****@*****.com --pwd "********" --threshold 7 --renew 1 --noip_path /var/www/html/plugins/noip/core/class/../.. --force_path 1<<
[2024-01-01 19:31:17]INFO : Log level : debug
[2024-01-01 19:31:17]INFO : User : *****@****.com
[2024-01-01 19:31:17]INFO : Threshold : 7
[2024-01-01 19:31:17]INFO : Renew : 1
[2024-01-01 19:31:17]INFO : ForcePath : 1
[2024-01-01 19:31:17]ERROR : Exception has been thrown. Message: Unable to locate or obtain driver for chrome; For documentation on this error, please visit: https://www.selenium.dev/documentation/webdriver/troubleshooting/errors/driver_location
[2024-01-01 19:31:17]DEBUG : [Aucun][Domaines] file content:
[2024-01-01 19:31:17]ERROR : [Aucun][Domaines] file content empty
Si tu as une idée :slight_smile:
je n’avais pas vu ta demande @tomitomas mais comme j’ai mis plus haut j’ai migré en bullseye (et python 3.9) et le problème est toujours la et je ne suis pas le seul, me semble qu’on avait pensé a un souci sur raspbian mais j’ai pas plus suivi que ca.
donc la solution serait peut etre d’installer une debian a la place…
je vais clôturer le sujet vu que j’ai désinstallé (j’ai réinstallé à l’instant pour tester mais le souci est toujours présent).
