Bonjour, je me permets de remonter le sujet
J’ai ce capteur qui est intégré dans le plugin j’ai bien la commande présence mais pas la luminosité alors qu’il le fait.
J’ai créé la commande via l’auto découverte. j’ai une remonté de valeur mais complètement incohérente.
Il doit falloir que je mette une formule de calcul dans la config de commande mais laquelle?
"ieee": "a4:c1:38:18:b7:79:db:fa",
"nwk": 55827,
"status": 2,
"lqi": "255",
"rssi": "-43",
"last_seen": "1697492248.140856",
"node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "_TZE200_3towulqd",
"model": "TS0601",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 130
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_3towulqd"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 16384,
"name": "sw_build_id",
"value": "0122052017"
"id": 3,
"name": "Identify",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 16,
"name": "cie_addr",
"value": [
7,
158,
5,
255,
255,
46,
33,
0
"id": 57346,
"name": "Cluster",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"id": 60928,
"name": "Cluster",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 1024,
"name": "Illuminance Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 33598
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
3,
1280,
57346,
61184,
60928,
57344,
1,
1024
"class": "zigpy.device"
"name": "TZE200_3towulqd.TS0601",
"configuration": {
"last_seen::check_mode": "disable"
"commands": [
"logicalId": "1::1024::0",
"generic_type": "BRIGHTNESS",
"name": "Luminosité",
"type": "info",
"subType": "numeric",
"isHistorized": "0",
"unite": "Lux",
"configuration": {
"repeatEventManagement": "always",
"alert::messageReturnBack": "0"
"template": {
"dashboard": "default",
"mobile": "default"
"isVisible": "1"
"logicalId": "1::1280::cmd::1",
"generic_type": "PRESENCE",
"name": "Présence",
"type": "info",
"subType": "binary",
"isHistorized": "1",
"configuration": {
"template": {
"dashboard": "core::presence",
"mobile": "core::presence"
"isVisible": "1"
"ref": "TZE200_3towulqd.TS0601"
