Bon, grosse correction sur mes dire,
oui la box Lidl est un coordinateur qui reconnait les trames GPD
donc j’ai dit de la me…
[2021-02-15 15:22:38][DEBUG] : Data frame: b'22e2b15754ef6a69fd947a37fa54a25bcc4f28a9ecce672ffdc663ab7af404cd14cd94e67e'
[2021-02-15 15:22:38][DEBUG] : Sending: b'83401b7e'
[2021-02-15 15:22:38][DEBUG] : Application frame 197 (gpepIncomingMessageHandler) received: b'7fdba40030125001301250010f02010000a400000022868a3b6aff00'
[2021-02-15 15:22:38][ERROR] : Exception in callback ThreadsafeProxy.__getattr__.<locals>.func_wrapper.<locals>.check_result_wrapper() at /usr/local/lib/python3.7/dist-packages/bellows/thread.py:97
handle: <Handle ThreadsafeProxy.__getattr__.<locals>.func_wrapper.<locals>.check_result_wrapper() at /usr/local/lib/python3.7/dist-packages/bellows/thread.py:97>
File "/usr/lib/python3.7/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.7/dist-packages/bellows/thread.py", line 98, in check_result_wrapper
result = call()
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/__init__.py", line 230, in frame_received
self._protocol(data)
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/protocol.py", line 124, in __call__
result, data = self.types.deserialize(data, schema)
File "/usr/local/lib/python3.7/dist-packages/bellows/types/__init__.py", line 9, in deserialize
value, data = type_.deserialize(data)
File "/usr/local/lib/python3.7/dist-packages/bellows/types/struct.py", line 199, in deserialize
kwargs[field.name], data = field.concrete_type.deserialize(data)
File "/usr/local/lib/python3.7/dist-packages/zigpy/types/basic.py", line 480, in deserialize
item, data = cls._item_type.deserialize(data)
File "/usr/local/lib/python3.7/dist-packages/zigpy/types/basic.py", line 53, in deserialize
raise ValueError(f"Data is too short to contain {cls._size} bytes")
ValueError: Data is too short to contain 1 bytes
[2021-02-15 15:22:39][DEBUG] : Data frame: b'32e2b15754ef6a52fc947a37fa54a25bcc4f28a9ecce672efdc663aa4f050bad14cde3807e'
[2021-02-15 15:22:39][DEBUG] : Sending: b'8430fc7e'
[2021-02-15 15:22:39][DEBUG] : Application frame 197 (gpepIncomingMessageHandler) received: b'7fe0a50030125001301250010f02010000a500000023b37b340aff00'
[2021-02-15 15:22:39][ERROR] : Exception in callback ThreadsafeProxy.__getattr__.<locals>.func_wrapper.<locals>.check_result_wrapper() at /usr/local/lib/python3.7/dist-packages/bellows/thread.py:97
result = call()
[2021-02-15 15:22:39][DEBUG] : Send command nop: ()
[2021-02-15 15:22:39][DEBUG] : Sending: b'24e32157542f65357e'
[2021-02-15 15:22:39][DEBUG] : Data frame: b'43e3a157542f2f547e'
[2021-02-15 15:22:39][DEBUG] : Sending: b'8520dd7e'
[2021-02-15 15:22:39][DEBUG] : Application frame 5 (nop) received: b''
voici les log du demon
