en fait quanf on attach le périphérique sur le client.
On dirait que coté host, ca le déconnecte comme si on retirait le périphérique USB
4282.569885] usbip-host 2-1: usbip-host: register new device (bus 2 dev 11)
[ 4329.462678] usbip-host 2-1: stub up
[ 4329.844965] usbip-host 2-1: endpoint 0 is stalled
[ 4329.845433] usbip-host 2-1: endpoint 0 is stalled
[ 4329.845927] usbip-host 2-1: endpoint 0 is stalled
[ 4333.572846] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.572949] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573070] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573196] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573283] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573391] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573480] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573555] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573640] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573788] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.573907] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.574027] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.574148] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.574266] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.574386] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.574505] usbip-host 2-1: urb completion with non-zero status -71
[ 4333.741254] usbip-host 2-1: USB disconnect, device number 11
[ 4333.741623] usbip-host 2-1: device removed?
[ 4333.742125] usbip-host 2-1: recv a header, 0
[ 4334.019559] usb 2-1: new full-speed USB device number 12 using xhci_hcd
[ 4334.156146] usb 2-1: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 4334.156155] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4334.157774] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
[ 4366.929133] usbip-host 2-1: usbip-host: register new device (bus 2 dev 12)
[ 4374.607384] usbip-host 2-1: stub up
[ 4374.993009] usbip-host 2-1: endpoint 0 is stalled
[ 4374.993508] usbip-host 2-1: endpoint 0 is stalled
[ 4374.993918] usbip-host 2-1: endpoint 0 is stalled
Bon j’avance.
Quand le périphérique USB est une clé de stockage ca à l’air de tenir
Mais si c’est ma clé Zwave, elle se déconnecte dès qu’on l’attache
