TTScast pas de remontée des enceinte
Bonjour, bizarement je n’ai pas de remonté de mes enceintes google, elle sont toutes en ligne mais en busy off. Alors que de la musique est en cours de diffusion. voici une partie des logs du TTScast daemon et cela depuis plusieurs jours. J’ai relancé le daemon mais cela n’a rien changé.
0029|[2026-02-01 14:33:19] ERROR  : [Enceinte gauche(192.168.1.53):8009] Failed to connect to service MDNSServiceInfo(name='Google-Home-Mini-8d432874d9ea0dcb24b255a736bd3d49._googlecast._tcp.local.'), retrying in 5.0s
0030|[2026-02-01 14:33:49] ERROR  : [Menuiserie (192.168.1.90):32000] Failed to connect to service HostServiceInfo(host='192.168.1.90', port=32000), retrying in 5.0s
0031|[2026-02-01 14:33:49] ERROR  : [Menuiserie(192.168.1.90):8009] Failed to connect to service HostServiceInfo(host='192.168.1.90', port=8009), retrying in 5.0s
0032|[2026-02-01 14:34:20] ERROR  : [Atelier menuiserie 2(192.168.1.70):8009] Failed to connect to service MDNSServiceInfo(name='Nest-Audio-7e2343768974a0e81500d5a3a1414cdd._googlecast._tcp.local.'), retrying in 5.0s
0033|[2026-02-01 14:34:29] ERROR  : [Enceinte droite(192.168.1.74):8009] Failed to connect to service MDNSServiceInfo(name='Google-Home-Mini-e4770438cabc4c661ce2d4a737892176._googlecast._tcp.local.'), retrying in 5.0s
0034|[2026-02-01 14:34:29] ERROR  : [Paire Bureau([::ffff:c0a8:135]):32000] Failed to connect to service HostServiceInfo(host='[::ffff:c0a8:135]', port=32000), retrying in 5.0s
0035|[2026-02-01 14:35:09] ERROR  : [Boutique(192.168.1.53):32027] Error reading from socket: socket connection broken
0036|[2026-02-01 14:35:09] ERROR  : [Boutique(192.168.1.53):32027] Failed to connect to service HostServiceInfo(host='192.168.1.53', port=32027), retrying in 5.0s
0037|[2026-02-01 14:35:29] ERROR  : [Sous-sol([::ffff:c0a8:14a]):32080] Failed to connect to service HostServiceInfo(host='[::ffff:c0a8:14a]', port=32080), retrying in 5.0s
0038|[2026-02-01 18:37:06] ERROR  : [DAEMON][mediaActions] Exception on mediaActions (2f679668-e340-43fd-bd33-1eb70cfc63e6) :: Execution of queue next timed out after 10.0 s.
0039|[2026-02-01 18:37:08] ERROR  : [DAEMON][mediaActions] Exception on mediaActions (2f679668-e340-43fd-bd33-1eb70cfc63e6) :: Execution of queue next timed out after 10.0 s.
0040|[2026-02-02 02:11:10] ERROR  : [Paire Bureau(192.168.1.53):32000] Error reading from socket: socket connection broken
0041|[2026-02-02 02:11:10] ERROR  : [Paire Bureau(192.168.1.53):32000] Failed to connect to service HostServiceInfo(host='192.168.1.53', port=32000), retrying in 5.0s
0042|[2026-02-02 02:11:40] ERROR  : [Enceinte gauche([::ffff:c0a8:135]):8009] Failed to connect to service HostServiceInfo(host='[::ffff:c0a8:135]', port=8009), retrying in 5.0s
0043|[2026-02-02 02:27:28] ERROR  : [Cuisine(192.168.1.69):8009] Failed to connect to service HostServiceInfo(host='192.168.1.69', port=8009), retrying in 5.0s
0044|[2026-02-02 03:09:43] ERROR  : [Boutique(192.168.1.74):32027] Error reading from socket: socket connection broken
0045|[2026-02-02 03:09:43] ERROR  : [Boutique(192.168.1.74):32027] Failed to connect to service HostServiceInfo(host='192.168.1.74', port=32027), retrying in 5.0s
0046|[2026-02-02 03:09:43] ERROR  : [Sous-sol(192.168.1.74):32080] Error reading from socket: socket connection broken
0047|[2026-02-02 03:09:43] ERROR  : [Sous-sol([::ffff:c0a8:14a]):32080] Failed to connect to service HostServiceInfo(host='[::ffff:c0a8:14a]', port=32080), retrying in 5.0s
0048|[2026-02-02 03:10:13] ERROR  : [Enceinte droite([::ffff:c0a8:14a]):8009] Failed to connect to service HostServiceInfo(host='[::ffff:c0a8:14a]', port=8009), retrying in 5.0s
0049|[2026-02-02 03:10:42] ERROR  : [Sous-sol(192.168.1.53):32080] Error reading from socket: socket connection broken
0050|[2026-02-02 03:10:42] ERROR  : [Sous-sol(192.168.1.53):32080] Failed to connect to service MDNSServiceInfo(name='Google-Cast-Group-2f679668e34043fdbd331eb70cfc63e6._googlecast._tcp.local.'), retrying in 5.0s
0051|[2026-02-02 03:10:42] ERROR  : [Boutique(192.168.1.53):32027] Error reading from socket: socket connection broken
0052|[2026-02-02 03:10:42] ERROR  : [Boutique(192.168.1.53):32027] Failed to connect to service HostServiceInfo(host='192.168.1.53', port=32027), retrying in 5.0s
0053|[2026-02-02 03:26:02] ERROR  : [Buanderie(192.168.1.31):8009] Failed to connect to service HostServiceInfo(host='192.168.1.31', port=8009), retrying in 5.0s
0054|[2026-02-02 03:41:49] ERROR  : [Salon(192.168.1.79):8009] Failed to connect to service HostServiceInfo(host='192.168.1.79', port=8009), retrying in 5.0s
0055|[2026-02-02 03:45:27] ERROR  : [Maison(192.168.1.68):32116] Error reading from socket: socket connection broken
0056|[2026-02-02 03:45:27] ERROR  : [Maison(192.168.1.68):32116] Failed to connect to service HostServiceInfo(host='192.168.1.68', port=32116), retrying in 5.0s
0057|[2026-02-02 03:46:03] ERROR  : [Chambre(192.168.1.68):8009] Failed to connect to service HostServiceInfo(host='192.168.1.68', port=8009), retrying in 5.0s
0058|[2026-02-02 04:18:34] ERROR  : [Menuiserie (192.168.1.90):32000] Error reading from socket: socket connection broken
0059|[2026-02-02 04:18:34] ERROR  : [Menuiserie (192.168.1.90):32000] Failed to connect to service HostServiceInfo(host='192.168.1.90', port=32000), retrying in 5.0s
0060|[2026-02-02 04:19:12] ERROR  : [Menuiserie(192.168.1.90):8009] Failed to connect to service HostServiceInfo(host='192.168.1.90', port=8009), retrying in 5.0s
0061|[2026-02-02 04:30:22] ERROR  : [Atelier menuiserie 2(192.168.1.70):8009] Failed to connect to service HostServiceInfo(host='192.168.1.70', port=8009), retrying in 5.0s
0062|[2026-02-02 04:38:06] ERROR  : [Maison(192.168.1.41):32116] Error reading from socket: socket connection broken
0063|[2026-02-02 04:38:06] ERROR  : [Maison(192.168.1.41):32116] Failed to connect to service HostServiceInfo(host='192.168.1.41', port=32116), retrying in 5.0s
0064|[2026-02-02 04:38:48] ERROR  : [Salle de bain(192.168.1.41):8009] Failed to connect to service HostServiceInfo(host='192.168.1.41', port=8009), retrying in 5.0s
Je vois que Jeedom n’arrive pas (via le plugin) à se connecter aux équipements Google : aucun changement dans la config réseau ? Adresse IP changées par exemple ? Autre ?
Peut-être essayer de refaire un scan (à partir de la page de configuration du plugin) : cela mettra les infos des équipements à jour.
Sinon redémarrer une enceinte Google pour voir si cela change quelque chose, et reboot de Jeedom pour écarter cette piste aussi.
Voir déjà ce que cela donne et ensuite on verra plus en détails, car là comme ça, je n’ai jamais vu ce cas de figure encore :face_with_raised_eyebrow:
TiTidom.
Bonjour TiTidom, désolé de n’avoir pas répondu plus tôt? Il n’y a eu aucun changement de configuration réseau. J’ai refait un scan et redémarré les enceintes Google. Mais j’ai toujours les mêmes logs d’erreurs.
Après, au niveau de mon fonctionnement il est le suivant et le plugin ne réagit pas comme espéré, désolé j’ai des anciennes habitudes avec le plugin GoogleCast, peut être que ça ne fonctionne pas pareil :
En utilisation normale, lorsque je demande de mettre de la musique sur deezer directement sur un groupe d’enceintes, au niveau du fonctionnement tout est OK, j’ai l’affichage de l’album, le titre et la musique joué, c’est nickel.
Par contre lorsque je transfère la musique d’une autre enceinte vers ce même groupe d’enceinte, alors là je n’ai aucune info qui remonte et j’ai souvent la musique en saccadé, mais je ne pense pas que ce soit vraiment lié au plugin.
En fait, je fais le transfert de musique très souvent, j’écoute ma musique pendant que je fais mon sport dans une pièce et je demande à google de transférer le contenu de la musique sur mon groupe d’enceinte sous-sol. Tout ça, pour une seule raison, par ce biais lorsque je demande par la suite à ce groupe d’enceinte de passer au morceau de musique suivant, je n’ai pas le retour de google qui me dit « compris je lance le média suivant sur sous-sol » qui est très pénible.
Après, est-il possible de créer un scénario avec ton plugin pour mettre de la musique depuis deezer? Je n’ai rien vu dans la doc je ne suis pas sûr que ce soit possible.
