Teleinfo déporté debian 12
tu pourrais tester ça:
`#!/usr/bin/python3
# -*- coding: utf-8 -*-
""" Teleinfo reader
License
teleinfo_2_cpt.py is Copyright:
- (C) 2010-2012 Samuel <samuel DOT buffet AT gmail DOT com>
- (C) 2012-2017 Frédéric <fma38 AT gbiloba DOT org>
- (C) 2017 Samuel <samuel DOT buffet AT gmail DOT com>
- (C) 2015-2018 Cédric Guiné <cedric DOT guine AT gmail DOT com>
This software is governed by the CeCILL license under French law and
abiding by the rules of distribution of free software.  You can  use,
modify and/or redistribute the software under the terms of the CeCILL
license as circulated by CEA, CNRS and INRIA at the following URL
http://www.cecill.info.
As a counterpart to the access to the source code and  rights to copy,
modify and redistribute granted by the license, users are provided only
with a limited warranty  and the software's author,  the holder of the
economic rights,  and the successive licensors  have only  limited
liability.
In this respect, the user's attention is drawn to the risks associated
with loading,  using,  modifying and/or developing or reproducing the
software by the user in light of its specific status of free software,
that may mean  that it is complicated to manipulate,  and  that  also
therefore means  that it is reserved for developers  and  experienced
professionals having in-depth computer knowledge. Users are therefore
encouraged to load and test the software's suitability as regards their
requirements in conditions enabling the security of their systems and/or
data to be ensured and,  more generally, to use and operate it in the
same conditions as regards security.
The fact that you are presently reading this means that you have had
knowledge of the CeCILL license and that you accept its terms.
import time
#import optparse
#import urllib2
import sys
import os
import traceback
import logging
import signal
import globals
import argparse
import _thread
import json
try:
    import ftdi
    ftdi_type = 0
except ImportError:
    import ftdi1 as ftdi
    ftdi_type = 1
    #raise ImportError('Erreur de librairie ftdi')
try:
    from jeedom.jeedom import *
except ImportError as ex:
    logging.error("MODEM_2cpt------Error: importing module from jeedom folder %s" % str(ex))
    sys.exit(1)
# USB settings
usb_vendor = 0x0403
usb_product = 0x6001
usb_port = [0x00, 0x11, 0x22]
baud_rate = 1200
# Misc
stx = 0x02  # start of text
etx = 0x03  # end of text
eot = 0x04  # end of transmission
# Datas
global_external_ip = ''
global_cle_api = ''
global_debug = ''
global_real_path = ''
class FtdiError(Exception):
    """ Ftdi related errors
class Ftdi(object):
    """ Class for handling ftdi communication
    def __init__(self):
        logging.info("Try to open Teleinfo modem")
        super(Ftdi, self).__init__()
        self.__ftdic = None
    def init(self):
        """ Init ftdi com.
        # Create ftdi context
        logging.info("Try to Create ftdi context")
        self.__ftdic = ftdi.ftdi_context()
        if self.__ftdic is None:
            logging.error("MODEM_2cpt------Can't create ftdi context")
            raise FtdiError("Can't create ftdi context")
        # Init ftdi context
        err = ftdi.ftdi_init(self.__ftdic)
        if err < 0:
            logging.error("MODEM_2cpt------Can't init ftdi context (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't init ftdi context (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
        # Open port
        logging.info("Try to open ftdi port")
        err = ftdi.ftdi_usb_open(self.__ftdic, usb_vendor, usb_product)
        if err < 0:
            logging.error("MODEM_2cpt------Can't open usb (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't open usb (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
        err = ftdi.ftdi_set_baudrate(self.__ftdic, int(globals.vitesse))
        if err < 0:
            logging.error("MODEM_2cpt------Can't set baudrate (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't set baudrate (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
        # Because of the usb interface, must use 8 bits transmission data, instead of 7 bits
        err = ftdi.ftdi_set_line_property(self.__ftdic, ftdi.BITS_8, ftdi.EVEN, ftdi.STOP_BIT_1)
        if err < 0:
            logging.error("MODEM_2cpt------Can't set line property (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't set line property (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
    def shutdown(self):
        """ Shutdown ftdi com.
        logging.info("Try to close ftdi port")
        err = ftdi.ftdi_usb_close(self.__ftdic)
        if err < 0:
            logging.error("MODEM_2cpt------Can't close ftdi com. (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't close ftdi com. (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
        ftdi.ftdi_deinit(self.__ftdic)
    def selectPort(self, port):
        """ Select the giver port
        err = ftdi.ftdi_set_bitmode(self.__ftdic, port, ftdi.BITMODE_CBUS)
        if err < 0:
            logging.error("MODEM_2cpt------Can't set bitmode (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't set bitmode (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
        time.sleep(0.1)
    def purgeBuffers(self):
        """ Purge ftdi buffers
        err = ftdi.ftdi_usb_purge_buffers(self.__ftdic)
        if err < 0:
            logging.error("MODEM_2cpt------Can't purge buffers (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            raise FtdiError("Can't purge buffers (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
    def readOne(self):
        """ read 1 char from usb
        buf = ' '
        err = ftdi.ftdi_read_data(self.__ftdic, buf, 1)
        if err < 0:
            logging.error("MODEM_2cpt------Can't read data (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
            self.shutdown()
            raise FtdiError("Can't read data (%d, %s)" % (err, ftdi.ftdi_get_error_string(self.__ftdic)))
        if err:
            c_error = chr(ord(buf) % 0x80)  # Clear bit 7
            return c_error
        else:
            return None
    def read(self, size):
        """ read several chars
        # Purge buffers
        self.purgeBuffers()
        raw = u""
        while len(raw) < globals.frame_length:
            c = self.readOne()
            if c is not None and c != '\x00':
                raw += c
        return raw
class Teleinfo(object):
    import globals
    """ Class for handling teleinfo stuff
    def __init__(self, ftdi_):
        logging.info("MODEM_2cpt------Initialisation de la teleinfo")
        logging.info("MODEM_2cpt------MODEM_2cpt------FTDI TYPE : " + str(ftdi_type))
        if ftdi_type == 0:
            globals.ftdi_context = ""
            super(Teleinfo, self).__init__()
            self.__ftdi = ftdi_
        else:
            globals.ftdi_context = ftdi.new()
            err = ftdi.usb_open(globals.ftdi_context, 0x0403, 0x6001)
            if err < 0:
                logging.error("MODEM_2cpt------Can't open usb (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
            ftdi.set_baudrate(globals.ftdi_context, int(globals.vitesse))
        if globals.mode == "historique":
            globals.frame_length = 500
            #ftdi.set_line_property(globals.ftdi_context, ftdi.BITS_8, ftdi.EVEN, ftdi.STOP_BIT_1)
    def __selectMeter(self, num):
        """ Select giver meter
        if ftdi_type == 0:
            self.__ftdi.selectPort(usb_port[num])
        else:
            err = ftdi.ftdi_set_baudrate(globals.ftdi_context, int(globals.vitesse))
            if err < 0:
                logging.error("MODEM_2cpt------Can't set baudrate (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
                raise FtdiError("Can't set baudrate (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
            err = ftdi.set_bitmode(globals.ftdi_context, usb_port[num], ftdi.BITMODE_CBUS)
            if err < 0:
                logging.error("MODEM_2cpt------Can't set bitmode (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
                raise FtdiError("Can't set bitmode (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
            time.sleep(0.1)
    def __readOne(self):
        err, buf = ftdi.read_data(globals.ftdi_context, 0x1)
        if err < 0:
            logging.error("MODEM_2cpt------Can't read data (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
            self.close()
            raise FtdiError("Can't read data (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
        if err:
            #c = unichr(ord(buf) % 0x80)  # Clear bit 7
            c = chr(ord(buf) & 0x07f)
            return err, c
        else:
            return err, None
    def __readRawFrame(self):
        """ Read raw frame
        # As the data are sent asynchronously by the USB interface, we probably don't start
        # to read at the start of a frame. So, we read enough chars to retreive a complete frame
        logging.debug("Lecture des donnees")
        if ftdi_type == 0:
            raw = self.__ftdi.read(globals.frame_length)
        else:
            logging.debug("MODEM_2cpt------trace 7")
            logging.debug("MODEM_2cpt------trace 8")
            err = ftdi.usb_purge_buffers(globals.ftdi_context)
            logging.debug("MODEM_2cpt------trace 9")
            if err < 0:
                logging.debug("MODEM_2cpt------trace 10")
                logging.error("MODEM_2cpt------Can't purge buffers (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
                logging.debug("MODEM_2cpt------trace 11")
                raise FtdiError("Can't purge buffers (%d, %s)" % (err, ftdi.get_error_string(globals.ftdi_context)))
            raw = u""
                err, c = self.__readOne()
                    raw += c
                    #logging.debug(c)
        return raw
    def __frameToDatas(self, frame):
        """ Split frame in datas
        #essai indent
        Content = {}
        lines = frame.split('\r')
        for line in lines:
            try:
                checksum = line[-1]
                #logging.debug('chechsum : ' + checksum)
                header, value = line[:-2].split()
                #data = {'header': header.encode(), 'value': value.encode(), 'checksum': checksum}
                #logging.debug('TELEINFO------name : ' + header.encode() + ' value : ' + value.encode() + ' checksum : ' + checksum)
                logging.debug('TELEINFO------name : ' + header + ' value : ' + value + ' chechsum : ' + checksum)
                if self.__checkData(line):
                    #logging.debug('retour vrai du checksum')
                    #Content[header.encode()] = value.encode()
                    Content[header] = value
                    #logging.debug('retour 2 ')
            except:
                pass
                #datas.append(data)
        return Content
    def __checkData(self, data):
        """ Check if data is ok (checksum)
        if globals.mode == "standard":
            #Gestion des champs horodates
            #logging.debug('calcul du checksum 1')
            if len(data.split('\x09')) == 4:
                datas = '\x09'.join(data.split('\x09')[0:3])
                #logging.debug('calcul du checksum 2' + datas)
            else:
                datas = '\x09'.join(data.split('\x09')[0:2])
                #logging.debug('calcul du checksum 3' + datas)
            my_sum = 0
            for cks in datas:
                my_sum = my_sum + ord(cks)
            #logging.debug('my_sum : ' + str(my_sum))
            computed_checksum = ((my_sum - 0x01) & int("111111", 2)) + 0x20
            #computed_checksum = ((my_sum + 0x09) & int("111111", 2)) + 0x20
            #logging.debug('computed checksum : ' + chr(computed_checksum) + ' compare a checksum : ' + data[-1])
        else:
            #print "Check checksum : f = %s, chk = %s" % (frame, checksum)
            datas = ' '.join(data.split()[0:2])
            my_sum = 0
            for cks in datas:
            computed_checksum = (my_sum & int("111111", 2)) + 0x20
            #print "computed_checksum = %s" % chr(computed_checksum)
        return chr(computed_checksum) == data[-1]
    def extractDatas(self, raw):
        """ Extract datas from raw frame
        end = raw.rfind(chr(etx)) + 1
        start = raw[:end].rfind(chr(etx)+chr(stx))
        frame = raw[start+2:end-2]
        #logging.debug('end : ' + str(end) + ' start : ' + str(start) + ' frame : ' + frame)
        # Check if there is a eot, cancel frame
        if frame.find(chr(eot)) != -1:
            return {'Message':'eot'}
            #raise TeleinfoError("eot found")
        # Convert frame back to ERDF standard
        #frame = frame.replace('\n', '')     # Remove new line
        # Extract data
        datas = self.__frameToDatas(frame)
        return datas
    def readMeter(self):
        """ Read raw frame for giver meter
        logging.debug("MODEM_2cpt------trace 5")
        num_compteur = 1
        cpt1_data = {}
        cpt2_data = {}
        cpt1_data_temp = {}
        cpt2_data_temp = {}
        raz_time = 600
        separateur = " "
        send_data = {}
        #for cle, valeur in Donnees.items():
        #            Donnees.pop(cle)
        #            _Donnees.pop(cle)
        while(1):
            if raz_time > 1:
                raz_time = raz_time - 1
            else:
                logging.info("MODEM_2cpt------HEARTBEAT")
                raz_time = 600
                for cle, valeur in list(cpt1_data.items()):
                    cpt1_data.pop(cle)
                    cpt1_data_temp.pop(cle)
                for cle, valeur in list(cpt2_data.items()):
                    cpt2_data.pop(cle)
                    cpt2_data_temp.pop(cle)
            send_data = {}
            self.__selectMeter(num_compteur)
            raw = self.__readRawFrame()
            self.__selectMeter(0)
            datas = self.extractDatas(raw)
            #logging.debug(raw)
            if num_compteur == 1:
                for cle, valeur in datas.items():
                    if cle == 'PTEC':
                        valeur = valeur.replace(".", "")
                        valeur = valeur.replace(")", "")
                        cpt1_data[cle] = valeur
                    else:
            elif num_compteur == 2:
                    if cle == 'PTEC':
                        cpt2_data[cle] = valeur
                    else:
            PENDING_CHANGES = False
                for cle, valeur in cpt1_data.items():
                    if cle in cpt1_data_temp:
                        if cpt1_data[cle] != cpt1_data_temp[cle]:
                            send_data[cle] = valeur
                            cpt1_data_temp[cle] = valeur
                            PENDING_CHANGES = True
                    else:
                for cle, valeur in cpt2_data.items():
                    if cle in cpt2_data_temp:
                        if cpt2_data[cle] != cpt2_data_temp[cle]:
                            cpt2_data_temp[cle] = valeur
                    else:
            try:
                logging.debug("MODEM_2cpt------trace 6")
                if PENDING_CHANGES :
                        if globals.mode == "standard": # Zone linky standard
                            if not cpt1_data_temp["ADSC"] == '':
                                send_data["device"] = cpt1_data_temp["ADSC"]
                                globals.JEEDOM_COM.add_changes('device::'+cpt1_data_temp["ADSC"],send_data)
                        else:
                            if not cpt1_data_temp["ADCO"] == '':
                                send_data["device"] = cpt1_data_temp["ADCO"]
                                globals.JEEDOM_COM.add_changes('device::'+cpt1_data_temp["ADCO"],send_data)
                            if not cpt2_data_temp["ADSC"] == '':
                                send_data["device"] = cpt2_data_temp["ADSC"]
                                globals.JEEDOM_COM.add_changes('device::'+cpt2_data_temp["ADSC"],send_data)
                        else:
                            if not cpt2_data_temp["ADCO"] == '':
                                send_data["device"] = cpt2_data_temp["ADCO"]
                                globals.JEEDOM_COM.add_changes('device::'+cpt2_data_temp["ADCO"],send_data)
            except Exception:
                logging.debug("MODEM_2cpt------trace 14")
                errorCom = "Connection error"
                logging.error(errorCom)
            #logging.debug("MODEM_2cpt------START SLEEPING " + str(globals.cycle_sommeil) + " seconds")
            time.sleep(globals.cycle_sommeil)
            #logging.debug("MODEM_2cpt------WAITING : " + str(globals.TELEINFO_SERIAL.inWaiting()) + " octets dans la file apres sleep ")
            #if globals.TELEINFO_SERIAL.inWaiting() > 1500:
            #    globals.TELEINFO_SERIAL.flushInput()
            #    logging.info("MODEM_2cpt------BUFFER OVERFLOW => FLUSH")
            #    logging.debug(str(globals.TELEINFO_SERIAL.inWaiting()) + "octets dans la file apres flush ")
                num_compteur = 2
            else:
                num_compteur = 1
        logging.debug("MODEM_2cpt------trace 15")
        self.terminate()
    def exit_handler(self, *args):
        self.terminate()
        logging.info("[exit_handler]")
    def close(self):
        if ftdi_type == 0:
            self.__ftdi.shutdown()
        else:
            ftdi.close()
    def terminate(self):
        logging.debug("MODEM_2cpt------Terminating...")
        self.close()
        #sys.close(gOutput)
        #sys.exit()
def read_socket(cycle):
    while True:
        try:
            global JEEDOM_SOCKET_MESSAGE
            if not JEEDOM_SOCKET_MESSAGE.empty():
                logging.debug("SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE")
                message = json.loads(JEEDOM_SOCKET_MESSAGE.get())
                logging.debug("SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE " + message['cmd'])
                if message['apikey'] != globals.apikey:
                    logging.error("SOCKET-READ------Invalid apikey from socket : " + str(message))
                    return
                logging.debug('SOCKET-READ------Received command from jeedom : ' + str(message['cmd']))
                if message['cmd'] == 'action':
                    logging.debug('SOCKET-READ------Attempt an action on a device')
                    _thread.start_new_thread(action_handler, (message,))
                    logging.debug('SOCKET-READ------Action Thread Launched')
                elif message['cmd'] == 'changelog':
                    jeedom_utils.set_log_level('info')
                    logging.info('SOCKET-READ------Passage du demon en mode ' + message['level'])
                    log = logging.getLogger()
                    for hdlr in log.handlers[:]:
                        log.removeHandler(hdlr)
                    logging.info("SOCKET-READ------------ C'est parti ;)")
                    jeedom_utils.set_log_level(message['level'])
        except Exception as e:
            logging.error("SOCKET-READ------Exception on socket : %s" % str(e))
            logging.debug(traceback.format_exc())
        time.sleep(cycle)
def action_handler(message):
    logging.debug("MODEM_2cpt-----Nouvelle action lancee")
    #je laisse au cas ou...
def listen():
    globals.PENDING_ACTION=False
    jeedom_socket.open()
    logging.info("MODEM_2cpt------Start listening...")
    #globals.TELEINFO = Teleinfo()
    logging.info("MODEM_2cpt------Preparing Teleinfo...")
    _thread.start_new_thread( read_socket, (globals.cycle,))
    logging.debug('MODEM_2cpt------Read Socket Thread Launched')
    while 1:
        try:
            if ftdi_type == 0:
                ftdi_ = Ftdi()
                ftdi_.init()
                globals.TELEINFO = Teleinfo(ftdi_)
            else:
                logging.debug("MODEM_2cpt------trace 1")
                globals.TELEINFO = Teleinfo("")
                logging.debug("MODEM_2cpt------trace 2")
            logging.debug("MODEM_2cpt------trace 3")
            globals.TELEINFO.readMeter()
            logging.debug("MODEM_2cpt------trace 4")
            logging.debug("MODEM_2cpt------trace 13")
            logging.error("MODEM_2cpt------fonction listen => %s" % str(e))
            shutdown()
def handler(signum=None, frame=None):
    logging.debug("MODEM_2cpt------trace 12")
    logging.debug("Signal %i caught, exiting..." % int(signum))
    shutdown()
def shutdown():
    logging.debug("MODEM_2cpt------Shutdown")
    #if ftdi_type == 0:
        #ftdi_.shutdown()
    #globals.TELEINFO.close()
    #logging.debug("Shutdown")
    logging.debug("Removing PID file " + str(globals.pidfile))
    try:
        os.remove(globals.pidfile)
    except:
        pass
    try:
        jeedom_socket.close()
    except:
        pass
    logging.debug("Exit 0")
    #sys.stdout.flush()
    os._exit(0)
# MAIN
globals.log_level = "info"
globals.socketport = 55062
globals.sockethost = '127.0.0.1'
globals.apikey = ''
globals.callback = ''
globals.cycle = 1
parser = argparse.ArgumentParser(description='Teleinfo Daemon for Jeedom plugin')
parser.add_argument("--apikey", help="Value to write", type=str)
parser.add_argument("--loglevel", help="Log Level for the daemon", type=str)
parser.add_argument("--callback", help="Value to write", type=str)
parser.add_argument("--socketport", help="Socket Port", type=str)
parser.add_argument("--sockethost", help="Socket Host", type=str)
parser.add_argument("--cycle", help="Cycle to send event", type=str)
parser.add_argument("--port", help="Port du modem", type=str)
parser.add_argument("--vitesse", help="Vitesse du modem", type=str)
parser.add_argument("--mode", help="Model mode", type=str)
parser.add_argument("--cyclesommeil", help="Wait time between 2 readline", type=str)
parser.add_argument("--pidfile", help="pidfile", type=str)
args = parser.parse_args()
if args.apikey:
    globals.apikey = args.apikey
if args.loglevel:
    globals.log_level = args.loglevel
if args.callback:
    globals.callback = args.callback
if args.socketport:
    globals.socketport = args.socketport
if args.sockethost:
    globals.sockethost = args.sockethost
if args.cycle:
    globals.cycle = float(args.cycle)
if args.port:
    globals.port = args.port
if args.vitesse:
    globals.vitesse = args.vitesse
if args.mode:
    globals.mode = args.mode
if args.cyclesommeil:
    globals.cycle_sommeil = float(args.cyclesommeil)
if args.pidfile:
    globals.pidfile = args.pidfile
globals.socketport = int(globals.socketport)
globals.cycle = float(globals.cycle)
jeedom_utils.set_log_level(globals.log_level)
logging.info('MODEM_2cpt------Start teleinfod')
logging.info('MODEM_2cpt------Cycle Sommeil : '+str(globals.cycle_sommeil))
logging.info('MODEM_2cpt------Socket port : '+str(globals.socketport))
logging.info('MODEM_2cpt------Socket host : '+str(globals.sockethost))
logging.info('MODEM_2cpt------Log level : '+str(globals.log_level))
logging.info('MODEM_2cpt------Callback : '+str(globals.callback))
logging.info('MODEM_2cpt------Vitesse : '+str(globals.vitesse))
logging.info('MODEM_2cpt------Apikey : '+str(globals.apikey))
logging.info('MODEM_2cpt------Cycle : '+str(globals.cycle))
logging.info('MODEM_2cpt------Port : '+str(globals.port))
logging.info('MODEM_2cpt------Mode : '+str(globals.mode))
signal.signal(signal.SIGINT, handler)
signal.signal(signal.SIGTERM, handler)
globals.pidfile = globals.pidfile + "2cpt.pid"
jeedom_utils.write_pid(str(globals.pidfile))
globals.JEEDOM_COM = jeedom_com(apikey = globals.apikey,url = globals.callback,cycle=globals.cycle)
if not globals.JEEDOM_COM.test():
    logging.error('MODEM_2cpt------Network communication issues. Please fix your Jeedom network configuration.')
    shutdown()
jeedom_socket = jeedom_socket(port=globals.socketport,address=globals.sockethost)
listen()
sys.exit()
On avance …
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Start teleinfod
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Cycle Sommeil : 30.0
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Socket port : 55062
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Socket host : 192.168.20.173
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Log level : debug
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Callback : http://192.168.20.190/plugins/teleinfo/core/php/jeeTeleinfo.php
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Vitesse : 1200
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Apikey : VytD2R7hyraVeRsU5gStuYjwnOYa2sWX2340iUtv6CBphpwB8dhmTPlb7JAwLKfk
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Cycle : 1.0
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Port : /dev/ttyUSB0
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Mode : historique
[2024-11-04 11:09:05][DEBUG] : Writing PID 3820 to /tmp/jeedom/teleinfo/teleinfo2cpt.pid
[2024-11-04 11:09:05][DEBUG] : Init request module v2.32.3
[2024-11-04 11:09:05][DEBUG] : Starting new HTTP connection (1): 192.168.20.190:80
[2024-11-04 11:09:05][DEBUG] : http://192.168.20.190:80 "GET /plugins/teleinfo/core/php/jeeTeleinfo.php?apikey=VytD2R7hyraVeRsU5gStuYjwnOYa2sWX2340iUtv6CBphpwB8dhmTPlb7JAwLKfk HTTP/11" 200 0
[2024-11-04 11:09:05][DEBUG] : Socket interface started
[2024-11-04 11:09:05][DEBUG] : LoopNetServer Thread started
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Start listening...
[2024-11-04 11:09:05][DEBUG] : Listening on: [192.168.20.173:55062]
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Preparing Teleinfo...
[2024-11-04 11:09:05][DEBUG] : MODEM_2cpt------Read Socket Thread Launched
[2024-11-04 11:09:05][DEBUG] : MODEM_2cpt------trace 1
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------Initialisation de la teleinfo
[2024-11-04 11:09:05][INFO] : MODEM_2cpt------MODEM_2cpt------FTDI TYPE : 1
[2024-11-04 11:09:05][DEBUG] : MODEM_2cpt------trace 2
[2024-11-04 11:09:05][DEBUG] : MODEM_2cpt------trace 3
[2024-11-04 11:09:05][DEBUG] : MODEM_2cpt------trace 5
[2024-11-04 11:09:06][DEBUG] : Lecture des donnees
[2024-11-04 11:09:06][DEBUG] : MODEM_2cpt------trace 7
[2024-11-04 11:09:06][DEBUG] : MODEM_2cpt------trace 8
[2024-11-04 11:09:06][DEBUG] : MODEM_2cpt------trace 9
[2024-11-04 11:09:06][DEBUG] : MODEM_2cpt------trace 13
[2024-11-04 11:09:06][ERROR] : MODEM_2cpt------fonction listen => argument 2: TypeError: wrong type
[2024-11-04 11:09:06][DEBUG] : MODEM_2cpt------Shutdown
[2024-11-04 11:09:06][DEBUG] : Removing PID file /tmp/jeedom/teleinfo/teleinfo2cpt.pid
[2024-11-04 11:09:06][DEBUG] : LoopNetServer Thread stopped
[2024-11-04 11:09:06][DEBUG] : Exit 0
et là?
#!/usr/bin/python3
""" Teleinfo reader
License
liability.
import time
#import optparse
#import urllib2
import sys
import os
import traceback
import logging
import signal
import globals
import argparse
import _thread
import json
try:
    import ftdi
    ftdi_type = 0
except ImportError:
    ftdi_type = 1
try:
    sys.exit(1)
# USB settings
usb_vendor = 0x0403
baud_rate = 1200
# Misc
# Datas
global_cle_api = ''
global_debug = ''
class Ftdi(object):
    def __init__(self):
        self.__ftdic = None
    def init(self):
        """ Init ftdi com.
        # Init ftdi context
        if err < 0:
        # Open port
        if err < 0:
        if err < 0:
        if err < 0:
    def shutdown(self):
        if err < 0:
        if err < 0:
        time.sleep(0.1)
        if err < 0:
    def readOne(self):
        buf = ' '
        if err < 0:
            self.shutdown()
        if err:
            return c_error
        else:
            return None
        # Purge buffers
        self.purgeBuffers()
        raw = u""
            c = self.readOne()
                raw += c
        return raw
    import globals
        if ftdi_type == 0:
            self.__ftdi = ftdi_
        else:
            if err < 0:
        if ftdi_type == 0:
        else:
            if err < 0:
            if err < 0:
            time.sleep(0.1)
        logging.debug("MODEM_2cpt------trace 17")
        err, buf = ftdi.read_data(globals.ftdi_context, 1)
        logging.debug("MODEM_2cpt------trace 18")
        if err < 0:
            self.close()
        if err:
            return err, c
        else:
            return err, None
        """ Read raw frame
        if ftdi_type == 0:
        else:
            if err < 0:
            raw = u""
                    raw += c
                    #logging.debug(c)
        logging.debug("MODEM_2cpt------trace 16")
        return raw
        #essai indent
        Content = {}
        for line in lines:
            try:
                checksum = line[-1]
            except:
                pass
                #datas.append(data)
        return Content
            else:
            my_sum = 0
            for cks in datas:
        else:
            my_sum = 0
            for cks in datas:
        # Extract data
        return datas
        num_compteur = 1
        cpt1_data = {}
        cpt2_data = {}
        cpt1_data_temp = {}
        cpt2_data_temp = {}
        raz_time = 600
        separateur = " "
        send_data = {}
        #            Donnees.pop(cle)
        #            _Donnees.pop(cle)
        while(1):
            if raz_time > 1:
            else:
                raz_time = 600
                    cpt1_data.pop(cle)
                    cpt2_data.pop(cle)
            send_data = {}
            #logging.debug(raw)
                    if cle == 'PTEC':
                    else:
                    if cle == 'PTEC':
                    else:
                    else:
                    else:
            try:
                        else:
                        else:
            except Exception:
                num_compteur = 2
            else:
                num_compteur = 1
        self.terminate()
        self.terminate()
    def close(self):
        if ftdi_type == 0:
        else:
            ftdi.close()
        self.close()
        #sys.close(gOutput)
        #sys.exit()
    while True:
        try:
                    return
        time.sleep(cycle)
def listen():
    while 1:
        try:
            if ftdi_type == 0:
                ftdi_ = Ftdi()
                ftdi_.init()
            else:
            shutdown()
    shutdown()
def shutdown():
    #if ftdi_type == 0:
        #ftdi_.shutdown()
    try:
    except:
        pass
    try:
    except:
        pass
    #sys.stdout.flush()
    os._exit(0)
# MAIN
globals.apikey = ''
globals.cycle = 1
if args.apikey:
if args.loglevel:
if args.callback:
if args.socketport:
if args.sockethost:
if args.cycle:
if args.port:
if args.vitesse:
if args.mode:
if args.pidfile:
    shutdown()
listen()
sys.exit()
pas mieux
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Start teleinfod
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Cycle Sommeil : 30.0
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Socket port : 55062
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Socket host : 192.168.20.173
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Log level : debug
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Callback : http://192.168.20.190/plugins/teleinfo/core/php/jeeTeleinfo.php
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Vitesse : 1200
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Apikey : VytD2R7hyraVeRsU5gStuYjwnOYa2sWX2340iUtv6CBphpwB8dhmTPlb7JAwLKfk
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Cycle : 1.0
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Port : /dev/ttyUSB0
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Mode : historique
[2024-11-04 12:36:23][DEBUG] : Writing PID 4481 to /tmp/jeedom/teleinfo/teleinfo2cpt.pid
[2024-11-04 12:36:23][DEBUG] : Init request module v2.32.3
[2024-11-04 12:36:23][DEBUG] : Starting new HTTP connection (1): 192.168.20.190:80
[2024-11-04 12:36:23][DEBUG] : http://192.168.20.190:80 "GET /plugins/teleinfo/core/php/jeeTeleinfo.php?apikey=VytD2R7hyraVeRsU5gStuYjwnOYa2sWX2340iUtv6CBphpwB8dhmTPlb7JAwLKfk HTTP/11" 200 0
[2024-11-04 12:36:23][DEBUG] : Socket interface started
[2024-11-04 12:36:23][DEBUG] : LoopNetServer Thread started
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Start listening...
[2024-11-04 12:36:23][DEBUG] : Listening on: [192.168.20.173:55062]
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Preparing Teleinfo...
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------Read Socket Thread Launched
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 1
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------Initialisation de la teleinfo
[2024-11-04 12:36:23][INFO] : MODEM_2cpt------MODEM_2cpt------FTDI TYPE : 1
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 2
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 3
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 5
[2024-11-04 12:36:23][DEBUG] : Lecture des donnees
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 7
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 8
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 9
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 17
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------trace 13
[2024-11-04 12:36:23][ERROR] : MODEM_2cpt------fonction listen => argument 2: TypeError: wrong type
[2024-11-04 12:36:23][DEBUG] : MODEM_2cpt------Shutdown
[2024-11-04 12:36:23][DEBUG] : Removing PID file /tmp/jeedom/teleinfo/teleinfo2cpt.pid
[2024-11-04 12:36:23][DEBUG] : LoopNetServer Thread stopped
[2024-11-04 12:36:23][DEBUG] : Exit 0
sisi j’avance :wink:
et là:
#!/usr/bin/python3
""" Teleinfo reader
License
liability.
import time
#import optparse
#import urllib2
import sys
import os
import traceback
import logging
import signal
import globals
import argparse
import _thread
import json
try:
    import ftdi
    ftdi_type = 0
except ImportError:
    ftdi_type = 1
try:
    sys.exit(1)
# USB settings
usb_vendor = 0x0403
baud_rate = 1200
# Misc
# Datas
global_cle_api = ''
global_debug = ''
class Ftdi(object):
    def __init__(self):
        self.__ftdic = None
    def init(self):
        """ Init ftdi com.
        # Init ftdi context
        if err < 0:
        # Open port
        if err < 0:
        if err < 0:
        if err < 0:
    def shutdown(self):
        if err < 0:
        if err < 0:
        time.sleep(0.1)
        if err < 0:
    def readOne(self):
        buf = ' '
        if err < 0:
            self.shutdown()
        if err:
            return c_error
        else:
            return None
        # Purge buffers
        self.purgeBuffers()
        raw = u""
            c = self.readOne()
                raw += c
        return raw
    import globals
        if ftdi_type == 0:
            self.__ftdi = ftdi_
        else:
            if err < 0:
        if ftdi_type == 0:
        else:
            if err < 0:
            if err < 0:
            time.sleep(0.1)
        err, buf = ftdi.read_data(globals.ftdi_context, '1')
        if err < 0:
            self.close()
        if err:
            return err, c
        else:
            return err, None
        """ Read raw frame
        if ftdi_type == 0:
        else:
            if err < 0:
            raw = u""
                    raw += c
                    #logging.debug(c)
        return raw
        #essai indent
        Content = {}
        for line in lines:
            try:
                checksum = line[-1]
            except:
                pass
                #datas.append(data)
        return Content
            else:
            my_sum = 0
            for cks in datas:
        else:
            my_sum = 0
            for cks in datas:
        # Extract data
        return datas
        num_compteur = 1
        cpt1_data = {}
        cpt2_data = {}
        cpt1_data_temp = {}
        cpt2_data_temp = {}
        raz_time = 600
        separateur = " "
        send_data = {}
        #            Donnees.pop(cle)
        #            _Donnees.pop(cle)
        while(1):
            if raz_time > 1:
            else:
                raz_time = 600
                    cpt1_data.pop(cle)
                    cpt2_data.pop(cle)
            send_data = {}
            #logging.debug(raw)
                    if cle == 'PTEC':
                    else:
                    if cle == 'PTEC':
                    else:
                    else:
                    else:
            try:
                        else:
                        else:
            except Exception:
                num_compteur = 2
            else:
                num_compteur = 1
        self.terminate()
        self.terminate()
    def close(self):
        if ftdi_type == 0:
        else:
            ftdi.close()
        self.close()
        #sys.close(gOutput)
        #sys.exit()
    while True:
        try:
                    return
        time.sleep(cycle)
def listen():
    while 1:
        try:
            if ftdi_type == 0:
                ftdi_ = Ftdi()
                ftdi_.init()
            else:
            shutdown()
    shutdown()
def shutdown():
    #if ftdi_type == 0:
        #ftdi_.shutdown()
    try:
    except:
        pass
    try:
    except:
        pass
    #sys.stdout.flush()
    os._exit(0)
# MAIN
globals.apikey = ''
globals.cycle = 1
if args.apikey:
if args.loglevel:
if args.callback:
if args.socketport:
if args.sockethost:
if args.cycle:
if args.port:
if args.vitesse:
if args.mode:
if args.pidfile:
    shutdown()
listen()
sys.exit()
pareil
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Start teleinfod
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Cycle Sommeil : 30.0
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Socket port : 55062
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Socket host : 192.168.20.173
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Log level : debug
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Callback : http://192.168.20.190/plugins/teleinfo/core/php/jeeTeleinfo.php
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Vitesse : 1200
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Apikey : VytD2R7hyraVeRsU5gStuYjwnOYa2sWX2340iUtv6CBphpwB8dhmTPlb7JAwLKfk
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Cycle : 1.0
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Port : /dev/ttyUSB0
[2024-11-04 13:08:02][INFO] : MODEM_2cpt------Mode : historique
[2024-11-04 13:08:02][DEBUG] : Writing PID 4716 to /tmp/jeedom/teleinfo/teleinfo2cpt.pid
[2024-11-04 13:08:02][DEBUG] : Init request module v2.32.3
[2024-11-04 13:08:02][DEBUG] : Starting new HTTP connection (1): 192.168.20.190:80
[2024-11-04 13:08:03][DEBUG] : http://192.168.20.190:80 "GET /plugins/teleinfo/core/php/jeeTeleinfo.php?apikey=VytD2R7hyraVeRsU5gStuYjwnOYa2sWX2340iUtv6CBphpwB8dhmTPlb7JAwLKfk HTTP/11" 200 0
[2024-11-04 13:08:03][DEBUG] : Socket interface started
[2024-11-04 13:08:03][DEBUG] : LoopNetServer Thread started
[2024-11-04 13:08:03][INFO] : MODEM_2cpt------Start listening...
[2024-11-04 13:08:03][DEBUG] : Listening on: [192.168.20.173:55062]
[2024-11-04 13:08:03][INFO] : MODEM_2cpt------Preparing Teleinfo...
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------Read Socket Thread Launched
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 1
[2024-11-04 13:08:03][INFO] : MODEM_2cpt------Initialisation de la teleinfo
[2024-11-04 13:08:03][INFO] : MODEM_2cpt------MODEM_2cpt------FTDI TYPE : 1
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 2
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 3
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 5
[2024-11-04 13:08:03][DEBUG] : Lecture des donnees
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 7
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 8
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 9
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 17
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------trace 13
[2024-11-04 13:08:03][ERROR] : MODEM_2cpt------fonction listen => string argument without an encoding
[2024-11-04 13:08:03][DEBUG] : MODEM_2cpt------Shutdown
[2024-11-04 13:08:03][DEBUG] : Removing PID file /tmp/jeedom/teleinfo/teleinfo2cpt.pid
[2024-11-04 13:08:03][DEBUG] : LoopNetServer Thread stopped
[2024-11-04 13:08:03][DEBUG] : Exit 0
je serai absent jusqu en fin d après midi
Désolé
t’inquiète c’est déjà bien d’avoir ta patience :wink:
c’est compliqué de debug quand on n’a pas le matériel sous la main
Salut et merci d’essayer de nous aider. Je ne pense pas que cela vienne de ça car il s’agit de l’exécution d’un programme python sur une machine où jeedom n’est pas installé.
Ah d’accord, je n’avais pas du tout compris que c’était hors Jeedom ! Désolé.
tu as vu que je t’ai écrit en mp?
oui j 'y ai repondu
dis moi si tu l’as eu
pour savoir si tu as reçu un message (mp ou autre) tu vois ça à la petite enveloppe qui apparait à côté de ton avatar. Si tu cliques dessus alors tu as la liste qui apparait
