Je cherche a piloter des devices par jeedom qui sont gérées par magichome version 1.9.11 (dernière version)
Est ce possible avec wifilightv2 (très bon plugin) ou un autre plugin ?
Merci d avance pour votre aide.
Aucune garantie, il faut tester !
Malheureusement cela ne fonctionne pas.
Voici le log :
[2020-04-21 19:54:26][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-04-21 19:54:26][DEBUG] : ****** Device NOT listenable test2 - Class: MagicUFOBulbV4 *****
[2020-04-21 19:54:26][DEBUG] : Cmd : 81 8a 8b 96 - try: 192.168.0.207 - 5577 - time out - socket_connect failed
a priori cela se connecte sur un port 5577 en faisant un scan de port le seul port ouvert est le port 80 en UDP.
Résultat nmap :
Starting Nmap 7.80 ( https://nmap.org ) at 2020-04-21 20:01 Romance Daylight Time
Initiating ARP Ping Scan at 20:01
Scanning 192.168.0.207 [1 port]
Completed ARP Ping Scan at 20:01, 0.95s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 20:01
Completed Parallel DNS resolution of 1 host. at 20:01, 0.01s elapsed
Initiating SYN Stealth Scan at 20:01
Scanning XXXXXXX (192.168.0.207) [1000 ports]
Completed SYN Stealth Scan at 20:01, 5.20s elapsed (1000 total ports)
Initiating UDP Scan at 20:01
Increasing send delay for 192.168.0.207 from 0 to 50 due to 25 out of 83 dropped probes since last increase.
Completed UDP Scan at 20:02, 62.73s elapsed (1000 total ports)
Nmap scan report for XXXXXXX (192.168.0.207)
Host is up (0.000036s latency).
Not shown: 1999 closed ports
PORT STATE SERVICE
80/udp open|filtered http
MAC Address: C8:F7:42:EC:6D:95 (HangZhou Gubei Electronics Technology)
Read data files from: C:\Program Files (x86)\Nmap
Nmap done: 1 IP address (1 host up) scanned in 69.65 seconds
Raw packets sent: 2260 (82.767KB) | Rcvd: 2000 (95.972KB)
Cordialement
apparemment produit totalement web
peux tu couper internet et voir l acces a la lampe via appli?
si ko aucune solution
si ok espionner avec packet capture ou httpcanary les trames echangees
si totalement crypte alors ko
Hello
Je vais faire le test mais pas facile de trouver un créneau pour couper internet.
Je te tiens au courant.
Cordialement
Hello
après coupure plus d’accès.
Merci de ton aide.
Cordialement
peux tu me donner un lien vers la lampe ?
Hello
Un lien vers la lampe ? A travers internet ? Ou un lien commercial ?
Cordialement
un lien vers un site qui vend la lampe
Cordialement
Bonjour,J’ai une ampoule de cette marque et je viens de faire le test avec Http canary, et les données sont en clair.
Par contre je ne sais pas quoi en faire veux tu que je te les envoies?
me donner les trames en indiquant quelle action a été faite à chaque fois.
Le mieux est de faire une commande toutes les 5s et de noter la commande faite avec l’appli.
Je ne garanti rien car de plus en plus les trames sont cryptées.
As tu pu avancer ?
