Je suis également dans la même situation, en jeedom 4.2
Après mise à jour du plugin, installation des dépendances KO (alors que c’est OK dans la trace)
Et le démon ne veut plus démarrer pour cause de dépendances non installées
Trace d’installation des dépendances :
+ touch /tmp/jeedom_install_in_progress_zigbee
+ echo 1
+ echo 2
+ sudo apt update
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Hit:5 http://phoscon.de/apt/deconz buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 3
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptool
E: Unable to locate package python3-setuptool
+ echo 4
+ sudo pip3 install --upgrade six
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.16.0)
WARNING: You are using pip version 21.0.1; however, version 22.0.3 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
+ echo 5
+ sudo pip3 install --upgrade pyudev
Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.23.1)
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from pyudev) (1.16.0)
+ echo 6
+ sudo pip3 install --upgrade requests
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.27.1)
Requirement already satisfied: idna<4,>=2.5 in /usr/lib/python3/dist-packages (from requests) (2.6)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests) (2018.8.24)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/lib/python3/dist-packages (from requests) (1.24.1)
Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.11)
+ echo 7
+ sudo pip3 install --upgrade setuptools
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (60.7.1)
+ echo 8
+ sudo pip3 install --upgrade wheel
Requirement already satisfied: wheel in /usr/local/lib/python3.7/dist-packages (0.37.1)
+ echo 9
+ sudo pip3 install --upgrade pyserial
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
+ echo 10
+ sudo pip3 install --upgrade tornado
Requirement already satisfied: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
+ echo 11
+ sudo pip3 install --upgrade zigpy
Requirement already satisfied: zigpy in /usr/local/lib/python3.7/dist-packages (0.43.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.7.4.post0)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.1)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.17.0)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.10.1)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy) (3.7.4.3)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (20.3.0)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy) (3.0.4)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (5.1.0)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (1.6.3)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (2.6)
+ echo 12
+ sudo pip3 install --upgrade zha-quirks
Requirement already satisfied: zha-quirks in /usr/local/lib/python3.7/dist-packages (0.0.66)
Requirement already satisfied: zigpy>=0.42.0 in /usr/local/lib/python3.7/dist-packages (from zha-quirks) (0.43.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (3.7.4.post0)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (1.0)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (3.10.1)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (0.17.0)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (0.12.1)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.42.0->zha-quirks) (3.7.4.3)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (3.0.4)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (1.6.3)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (20.3.0)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (5.1.0)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (3.0.1)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.42.0->zha-quirks) (2.6)
+ echo 13
+ sudo pip3 install --upgrade zigpy-znp
Requirement already satisfied: zigpy-znp in /usr/local/lib/python3.7/dist-packages (0.7.0)
Requirement already satisfied: coloredlogs in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (15.0)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (0.5)
Requirement already satisfied: jsonschema in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (3.2.0)
Requirement already satisfied: zigpy>=0.40.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (0.43.0)
Requirement already satisfied: async-timeout in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (3.0.1)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (0.12.1)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-znp) (3.7.4.post0)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-znp) (0.17.0)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-znp) (3.10.1)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-znp) (1.0)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.40.0->zigpy-znp) (3.7.4.3)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-znp) (5.1.0)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-znp) (1.6.3)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-znp) (20.3.0)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-znp) (3.0.4)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.40.0->zigpy-znp) (2.6)
Requirement already satisfied: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->zigpy-znp) (9.1)
Requirement already satisfied: importlib-metadata in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (4.6.3)
Requirement already satisfied: pyrsistent>=0.14.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (0.18.0)
Requirement already satisfied: six>=1.11.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (1.16.0)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (60.7.1)
Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata->jsonschema->zigpy-znp) (3.5.0)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-znp) (3.5)
+ echo 14
+ sudo pip3 install --upgrade zigpy-xbee
Requirement already satisfied: zigpy-xbee in /usr/local/lib/python3.7/dist-packages (0.14.0)
Requirement already satisfied: zigpy>=0.23.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.43.0)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.5)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (1.0)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.10.1)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.17.0)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.12.1)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.7.4.post0)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.0->zigpy-xbee) (3.7.4.3)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.4)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (20.3.0)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (5.1.0)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.1)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (1.6.3)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.0->zigpy-xbee) (2.6)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-xbee) (3.5)
+ echo 15
+ sudo pip3 install --upgrade zigpy-deconz
Requirement already satisfied: zigpy-deconz in /usr/local/lib/python3.7/dist-packages (0.14.0)
Requirement already satisfied: zigpy>=0.40.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.43.0)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.5)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (3.7.4.post0)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (1.0)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (0.17.0)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (3.10.1)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (0.12.1)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.40.0->zigpy-deconz) (3.7.4.3)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (5.1.0)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (3.0.1)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (3.0.4)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (1.6.3)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (20.3.0)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.40.0->zigpy-deconz) (2.6)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-deconz) (3.5)
+ echo 16
+ sudo pip3 install --upgrade zigpy-zigate
Requirement already satisfied: zigpy-zigate in /usr/local/lib/python3.7/dist-packages (0.7.4)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.5)
Requirement already satisfied: zigpy>=0.22.2 in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.43.0)
Requirement already satisfied: pyusb in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (1.1.1)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.10.1)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.7.4.post0)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.17.0)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.12.1)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (1.0)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.22.2->zigpy-zigate) (3.7.4.3)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (1.6.3)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (5.1.0)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.4)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.1)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (20.3.0)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.2->zigpy-zigate) (2.6)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-zigate) (3.5)
+ echo 17
+ sudo pip3 install --upgrade bellows
Requirement already satisfied: bellows in /usr/local/lib/python3.7/dist-packages (0.29.0)
Requirement already satisfied: zigpy>=0.37.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.43.0)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (from bellows) (3.5)
Requirement already satisfied: pure-pcapy3==1.0.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (1.0.1)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from bellows) (0.5)
Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (from bellows) (7.1.2)
Requirement already satisfied: click-log>=0.2.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.3.2)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from bellows) (0.12.1)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (from pure-pcapy3==1.0.1->bellows) (60.7.1)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (1.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (3.7.4.post0)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (0.17.0)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (3.10.1)
Requirement already satisfied: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.37.0->bellows) (3.7.4.3)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (5.1.0)
Requirement already satisfied: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.0.4)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.0.1)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (1.6.3)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (20.3.0)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.37.0->bellows) (2.6)
+ echo 18
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch install of zigbee dependancy
Everything is successfully installed!
+ echo 19
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zigbee
+ rm /tmp/jeedom_install_in_progress_zigbee
*******************End of package installation******************```
