Bonjour, depuis une mise jour de Jeedom, je ne sais dire si c’est le Core ou le plugin Zigbee2Mqtt, RFLink ne fonctionne plus.
Impossible d’installer les dépendances, ni de lancer le daemon.
J’ai tester de supprimer NodeJs mais le problème ne semble pas venir de là.
+ touch /tmp/jeedom_install_in_progress_rflink
+ echo 1
+ echo 2
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 https://download.docker.com/linux/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
apt-utils is already the newest version (2.2.4).
lsb-release is already the newest version (11.1.0).
git is already the newest version (1:2.30.2-1+deb11u5).
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
[Check Version NodeJS actuelle : Aucune : [ KO ]
Installation de NodeJS 22
Utilisation du dépot officiel
deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_22.x nodistro main
nodejs
0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
Need to get 0 B/37.6 MB of archives.
After this operation, 237 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 74097 files and directories currently installed.)
Preparing to unpack .../nodejs_22.21.0-1nodesource1_amd64.deb ...
Detected old npm client, removing...
Unpacking nodejs (22.21.0-1nodesource1) ...
Setting up nodejs (22.21.0-1nodesource1) ...
Processing triggers for man-db (2.9.4-2) ...
[Check Version NodeJS après install : v22.21.0 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Clean npm cache
npm warn using --force Recommended protections disabled.
+ echo 3
[Check Version NodeJS actuelle : v22.21.0 : [ OK ]
Clean npm cache
+ echo 4
+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
+ sudo /var/www/html/core/class/../../resources/install_composer.sh
Begin installation of composer
--2025-12-20 18:06:41-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 57.128.19.244, 2001:41d0:304:300::18ef
Connecting to getcomposer.org (getcomposer.org)|57.128.19.244|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 59524 (58K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 86% 2.57M 0s
50K ........ 100% 128M=0.02s
2025-12-20 18:06:41 (2.98 MB/s) - 'composer-setup.php' saved [59524/59524]
All settings correct for using Composer
Downloading...
Composer (version 2.9.2) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
+ echo 5
+ cd /var/www/html/core/class/../../plugins/rflink/resources
+ rm -rf node_modules
+ sudo NODE_OPTIONS=--dns-result-order=ipv4first npm install
npm warn deprecated har-validator@5.1.5: this library is no longer supported
npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm error code 1
npm error path /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings
npm error command failed
npm error command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm error make: Entering directory '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build'
npm error CXX(target) Release/obj.target/bindings/src/serialport.o
npm error make: Leaving directory '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build'
npm error prebuild-install WARN install No prebuilt binaries found (target=22.21.0 runtime=node arch=x64 libc= platform=linux)
npm error gyp info it worked if it ends with ok
npm error gyp info using node-gyp@11.2.0
npm error gyp info using node@22.21.0 | linux | x64
npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
npm error gyp info spawn /usr/bin/python3
npm error gyp info spawn args [
npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm error gyp info spawn args 'binding.gyp',
npm error gyp info spawn args '-f',
npm error gyp info spawn args 'make',
npm error gyp info spawn args '-I',
npm error gyp info spawn args '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/config.gypi',
npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm error gyp info spawn args '/root/.cache/node-gyp/22.21.0/include/node/common.gypi',
npm error gyp info spawn args '-Dlibrary=shared_library',
npm error gyp info spawn args '-Dvisibility=default',
npm error gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/22.21.0',
npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
npm error gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',
npm error gyp info spawn args '-Dmodule_root_dir=/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings',
npm error gyp info spawn args '-Dnode_engine=v8',
npm error gyp info spawn args '--depth=.',
npm error gyp info spawn args '--no-parallel',
npm error gyp info spawn args '--generator-output',
npm error gyp info spawn args 'build',
npm error gyp info spawn args '-Goutput_dir=.'
npm error gyp info spawn args ]
npm error gyp info spawn make
npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm error In file included from ../../../nan/nan.h:178,
npm error from ../src/./serialport.h:13,
npm error from ../src/serialport.cpp:1:
npm error ../../../nan/nan_callbacks.h:55:23: error: 'AccessorSignature' is not a member of 'v8'
npm error 55 | typedef v8::Local<v8::AccessorSignature> Sig;
npm error | ^~~~~~~~~~~~~~~~~
npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalid
npm error | ^
npm error In file included from ../src/./serialport.h:13,
npm error ../../../nan/nan.h: In function 'void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)':
npm error ../../../nan/nan.h:2551:16: error: no matching function for call to 'v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)'
npm error 2551 | , signature);
npm error | ^
npm error In file included from /root/.cache/node-gyp/22.21.0/include/node/v8-function.h:15,
npm error from /root/.cache/node-gyp/22.21.0/include/node/v8.h:33,
npm error from /root/.cache/node-gyp/22.21.0/include/node/node.h:74,
npm error from ../../../nan/nan.h:58,
npm error /root/.cache/node-gyp/22.21.0/include/node/v8-template.h:1049:8: note: candidate: 'void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)'
npm error 1049 | void SetAccessor(
npm error /root/.cache/node-gyp/22.21.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from 'v8::AccessControl' to 'v8::PropertyAttribute'
npm error 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None,
npm error | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
npm error /root/.cache/node-gyp/22.21.0/include/node/v8-template.h:1055:8: note: candidate: 'void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)'
npm error 1055 | void SetAccessor(
npm error /root/.cache/node-gyp/22.21.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from 'v8::AccessControl' to 'v8::PropertyAttribute'
npm error 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None,
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':
npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
npm error 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
npm error ../src/serialport.cpp: At global scope:
npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]
npm error 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
npm error | ^
npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]
npm error 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
npm error | ^
npm error In file included from ../../../nan/nan.h:58,
npm error /root/.cache/node-gyp/22.21.0/include/node/node.h:1244:7: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
npm error 1244 | (node::addon_register_func) (regfunc), \
npm error /root/.cache/node-gyp/22.21.0/include/node/node.h:1278:3: note: in expansion of macro 'NODE_MODULE_X'
npm error 1278 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
npm error ../src/serialport.cpp:486:1: note: in expansion of macro 'NODE_MODULE'
npm error 486 | NODE_MODULE(serialport, init);
npm error In file included from /root/.cache/node-gyp/22.21.0/include/node/v8-array-buffer.h:12,
npm error from /root/.cache/node-gyp/22.21.0/include/node/v8.h:24,
npm error /root/.cache/node-gyp/22.21.0/include/node/v8-local-handle.h: In instantiation of 'v8::Local<T>::Local(v8::Local<S>) [with S = v8::Data; T = v8::Value]':
npm error ../../../nan/nan_callbacks_12_inl.h:175:53: required from here
npm error /root/.cache/node-gyp/22.21.0/include/node/v8-local-handle.h:269:42: error: static assertion failed: type check
npm error 269 | static_assert(std::is_base_of<T, S>::value, "type check");
npm error | ^~~~~
npm error make: *** [bindings.target.mk:113: Release/obj.target/bindings/src/serialport.o] Error 1
npm error gyp ERR! build error
npm error gyp ERR! stack Error: `make` failed with exit code: 2
npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)
npm error gyp ERR! System Linux 5.10.0-36-amd64
npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
npm error gyp ERR! cwd /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings
npm error gyp ERR! node -v v22.21.0
npm error gyp ERR! node-gyp -v v11.2.0
npm error gyp ERR! not ok
npm error A complete log of this run can be found in: /root/.npm/_logs/2025-12-20T17_06_42_597Z-debug-0.log
+ sudo chown -R www-data:www-data nodejs.sh package-lock.json package.json rflink rflink.js update_firmware.sh
+ echo 6
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rflink
+ echo 7
+ rm /tmp/jeedom_install_in_progress_rflink
