Souci sur homebridge a cause du bug core 4.4.7 résolu depuis
bonjour,
pour faire suite au sujet sur la mise a jour 4.4.7, je rencontre encore deux petit soucis :
  • homebridge a l’air de demarrer correctement dans l’ihm mais je n’ai plus aucun appareil sur mon iPhone, et ces erreurs dans les logs :
[11/06/2024 18:35:02] Loaded config.json with 0 accessories and 2 platforms.
[11/06/2024 18:35:02] Loaded 25 cached accessories from cachedAccessories.
[11/06/2024 18:35:02] ---
[11/06/2024 18:35:03] Loaded plugin: @nebz/homebridge-jeedom@v1.7.0
[11/06/2024 18:35:03] ====================
[11/06/2024 18:35:03] ERROR INITIALIZING PLUGIN @nebz/homebridge-jeedom:
[11/06/2024 18:35:03] Error: Cannot find module './docs'
Require stack:
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/googleapis/build/src/apis/index.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/googleapis/build/src/googleapis.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/googleapis/build/src/index.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/fakegato-history/lib/googleDrive.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/fakegato-history/fakegato-storage.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/fakegato-history/fakegato-history.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/plugin.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/pluginManager.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/api.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/cli.js
- /var/www/html/plugins/homebridge/resources/node_modules/homebridge/bin/homebridge
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    at Function.Module._load (node:internal/modules/cjs/loader:981:27)
    at Module.require (node:internal/modules/cjs/loader:1231:19)
    at require (node:internal/modules/helpers:177:18)
    at Object.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/node_modules/googleapis/build/src/apis/index.js:133:16)
    at Module._compile (node:internal/modules/cjs/loader:1364:14)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    at Module.load (node:internal/modules/cjs/loader:1203:32)
    at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
[11/06/2024 18:35:03] ---
[11/06/2024 18:35:03] Loading 2 platforms...
[11/06/2024 18:35:03] No plugin was found for the platform "Jeedom" in your config.json. Please make sure the corresponding plugin is installed correctly.
[11/06/2024 18:35:03] No plugin was found for the platform "config" in your config.json. Please make sure the corresponding plugin is installed correctly.
[11/06/2024 18:35:03] Failed to find plugin to handle accessory ..... tous mes accessoires
Setup Payload:
X-HM://0023ISYWYFF26
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
[11/06/2024 18:35:03] Homebridge v1.8.2 (HAP v0.12.1) (Jeedom) is running on port 51826.
il ne me reste « plus que » ces deux soucis :smiley:
Un problème par sujet, j’ai retiré à propos du second.
Relancez les dépendances et envoyez moi le log homebridge_dep (et envoyez moi tout le log daemon et en debug avant de lancer le démon svp , sans faire vous même le choix des lignes que vous pensez utiles)
en faisant cela, j’ai bien retrouvé tout le monde, mais dans la mauvaise pièce cette fois ci.
cela veut dire que le souci vient du restore d’un backup, voici le log :
[11/06/2024 19:07:03] Homebridge v1.8.2 (HAP v0.12.1) (Jeedom) is running on port 51826.
[11/06/2024 19:11:00] Got SIGTERM, shutting down Homebridge...
[6/11/2024, 7:13:06 PM] Loaded config.json with 0 accessories and 2 platforms.
[6/11/2024, 7:13:07 PM] Loaded 0 cached accessories from cachedAccessories.
[6/11/2024, 7:13:07 PM] ---
[6/11/2024, 7:13:07 PM] Loaded plugin: @nebz/homebridge-jeedom@v1.7.0
[6/11/2024, 7:13:07 PM] Registering platform '@nebz/homebridge-jeedom.Jeedom'
[6/11/2024, 7:13:07 PM] Loaded plugin: homebridge-alexa@0.6.9
[6/11/2024, 7:13:07 PM] Registering platform 'homebridge-alexa.Alexa'
[6/11/2024, 7:13:07 PM] Loaded plugin: homebridge-camera-ffmpeg@3.1.4
[6/11/2024, 7:13:07 PM] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[6/11/2024, 7:13:07 PM] Loaded plugin: homebridge-config-ui-x@4.56.2
[6/11/2024, 7:13:07 PM] Registering platform 'homebridge-config-ui-x.config'
[6/11/2024, 7:13:07 PM] Loaded plugin: homebridge-gsh@2.2.0
[6/11/2024, 7:13:07 PM] Registering platform 'homebridge-gsh.google-smarthome'
[6/11/2024, 7:13:07 PM] Loading 2 platforms...
[6/11/2024, 7:13:07 PM] [Jeedom] Initializing Jeedom platform...
[6/11/2024, 7:13:07 PM] [Jeedom] debugLevel:400
[6/11/2024, 7:13:08 PM] [Config] Initializing config platform...
[6/11/2024, 7:13:08 PM] [Config] Spawning homebridge-config-ui-x with PID 6317
[6/11/2024, 7:13:08 PM] [Jeedom] Synchronisation Jeedom <> Homebridge...
Setup Payload:
│ 031-45-154 │
[6/11/2024, 7:13:08 PM] Homebridge v1.8.2 (HAP v0.12.1) (Jeedom) is running on port 51826.
[6/11/2024, 7:13:08 PM] [Jeedom] Enumération des scénarios Jeedom...
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Famille > Présence Brice (1)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Scenario invisible, activé, pas coché pour Homebridge
[6/11/2024, 7:13:08 PM] [Jeedom] │ KO : Accessoire Ignoré
[6/11/2024, 7:13:08 PM] [Jeedom] └─────────
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Famille > Présence Charlotte (2)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── undefined > Menu (4)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Scenario invisible, activé, pas dans une pièce, pas coché pour Homebridge
[6/11/2024, 7:13:08 PM] [Jeedom] Enumération des périphériques Jeedom...
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Bureau > Ordinateur (80)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Ordinateur)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Ordinateur)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Caméras > Balcon (77)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Balcon)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Balcon)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Caméras > Garage (26)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Garage)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Garage)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Caméras > Patio (76)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Patio)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Patio)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Caméras > Poteau (75)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Poteau)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Poteau)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Caméras > Salon (78)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Salon)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Salon)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Chambre amis > Ami (12)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Accessoire visible, désactivé
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Chambre parentale > Bricha (13)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Chambre Victor > Victor (11)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Climatisation > Ami (39)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Ami)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Ami)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Climatisation > Bricha (36)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Bricha)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Bricha)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Climatisation > Bureau (40)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Bureau)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Bureau)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Climatisation > Victor (38)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Victor)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Victor)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Cuisine > Cuisine (8)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Cuisine > Piscine (10)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Dressing > Dressing (6)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Famille > Brice (20)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Accessoire sans Type Générique d'Etat
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Famille > Charlotte (22)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Garage > Garage (18)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Maison > Horloge (61)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Maison > Interphone (73)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Interphone)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Interphone)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Piscine > Flipr (35)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Portail > Portail (71)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Portail)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Portail)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Salon > Escalier (62)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Escalier)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Escalier)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Salon > Salon (7)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Salon > Table (63)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Table)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Table)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Salon > Télé (60)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Télé)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Télé)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Ami (33)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Bain (31)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Bain)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Bain)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Cuisine (30)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Cuisine)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Cuisine)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Cumulus (87)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Cumulus)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Cumulus)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Entrée (29)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Entrée)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Entrée)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Patio (84)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Piscine Lumière (86)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Piscine Lumière)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Piscine Lumière)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Piscine Pompe (85)
[6/11/2024, 7:13:08 PM] [Jeedom] │ Nouvel accessoire (Piscine Pompe)
[6/11/2024, 7:13:08 PM] [Jeedom] │ OK : Ajout de l'accessoire (Piscine Pompe)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Shelly > Victor (32)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Téléphones > Téléphone Brice (23)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌──── Téléphones > Téléphone Charlotte (24)
[6/11/2024, 7:13:08 PM] [Jeedom] ┌────RAMASSE-MIETTES─────
[6/11/2024, 7:13:08 PM] [Jeedom] │ (Suppression des accessoires qui sont dans le cache mais plus dans jeedom (peut provenir de renommage ou changement de pièce))
[6/11/2024, 7:13:08 PM] [Jeedom] │ Rien à supprimer
[6/11/2024, 7:13:08 PM] [Jeedom] └────────────────────────
[6/11/2024, 7:13:08 PM] [Jeedom] --== Homebridge est démarré et a intégré 25 accessoires ! ==--
e[0;37m[6/11/2024, 7:13:08 PM] e[0me[0;36m[Homebridge UI]e[0m e[0;33mHomebridge UI v4.56.2 is listening on :: port 33221e[0m
[6/11/2024, 7:13:09 PM] [@nebz/homebridge-jeedom] This plugin generated a warning from the char
Oui logique pour la pièce, non le problème vient du bug core qui est résolu depuis.
Je viens de retester après la dernière mise à jour de faire un backup puis réinstaller propre avec restauration et ça plante pareil
Oui c’est la modification du core que j’ai signalée à @loic qui casse tout. Il a dit que c était une correction en urgence, mais je suppose qu’il corrigera bientôt la source du problème et remettra une exclusion qui est la depuis très longtemps et qui fonctionnait très bien.
