j’ai un bouton reconnu par rfxcom et donc inclus, il a la particularité d’envoyer le protocole 0x13 et 0x20
Donc le bouton est bien inclus, dans les logs j’ai ceci :
[2024-11-16 17:48:53][DEBUG] : Message: 0913009e785e88015140
[2024-11-16 17:48:53][DEBUG] : Decode : 0913009e785e88015140
[2024-11-16 17:48:53][DEBUG] : Test message: 0913009e785e88015140
[2024-11-16 17:48:53][DEBUG] : PacketType: 0x13
[2024-11-16 17:48:53][DEBUG] : Length: 10
[2024-11-16 17:48:53][DEBUG] : Start decoding packet type 0x13
[2024-11-16 17:48:53][DEBUG] : Subtype = PT2262, EV1527 433.92MHz
[2024-11-16 17:48:53][DEBUG] : Data : {'packetlen': '0x09', 'packettype': '0x13', 'subtype': '0x00', 'seqnbr': '0x9E', 'cmd1': '0x78', 'cmd2': '0x5E', 'cmd3': '0x88', 'pulse': 337, 'filler': 0, 'rssi': 4}
[2024-11-16 17:48:53][DEBUG] : Decoded info : {'packettype': '0x13', 'subtype': '0x00', 'id': '785E88', 'pulse': 1348, 'rssi': 4}
[2024-11-16 17:48:53][DEBUG] : Device is known id : 785E88
[2024-11-16 17:48:53][DEBUG] : Message: 0913009f785e88015040
[2024-11-16 17:48:53][DEBUG] : Decode : 0913009f785e88015040
[2024-11-16 17:48:53][DEBUG] : Test message: 0913009f785e88015040
[2024-11-16 17:48:53][DEBUG] : Data : {'packetlen': '0x09', 'packettype': '0x13', 'subtype': '0x00', 'seqnbr': '0x9F', 'cmd1': '0x78', 'cmd2': '0x5E', 'cmd3': '0x88', 'pulse': 336, 'filler': 0, 'rssi': 4}
[2024-11-16 17:48:53][DEBUG] : Decoded info : {'packettype': '0x13', 'subtype': '0x00', 'id': '785E88', 'pulse': 1344, 'rssi': 4}
16550|[2024-11-16 18:04:01] DEBUG : Message: 09130061785e88015450
16551|[2024-11-16 18:04:01] DEBUG : Decode : 09130061785e88015450
16552|[2024-11-16 18:04:01] DEBUG : Test message: 09130061785e88015450
16553|[2024-11-16 18:04:01] DEBUG : PacketType: 0x13
16554|[2024-11-16 18:04:01] DEBUG : Length: 10
16555|[2024-11-16 18:04:01] DEBUG : Start decoding packet type 0x13
16556|[2024-11-16 18:04:01] DEBUG : Subtype = PT2262, EV1527 433.92MHz
16557|[2024-11-16 18:04:01] DEBUG : Data : {'packetlen': '0x09', 'packettype': '0x13', 'subtype': '0x00', 'seqnbr': '0x61', 'cmd1': '0x78', 'cmd2': '0x5E', 'cmd3': '0x88', 'pulse': 340, 'filler': 0, 'rssi': 5}
16558|[2024-11-16 18:04:01] DEBUG : Decoded info : {'packettype': '0x13', 'subtype': '0x00', 'id': '785E88', 'pulse': 1360, 'rssi': 5}
16559|[2024-11-16 18:04:01] DEBUG : Device is known id : 785E88
0126|[2024-11-16 18:08:44] DEBUG : Message: 091300d2785e88015040
0127|[2024-11-16 18:08:44] DEBUG : Decode : 091300d2785e88015040
0128|[2024-11-16 18:08:44] DEBUG : Test message: 091300d2785e88015040
0129|[2024-11-16 18:08:44] DEBUG : PacketType: 0x13
0130|[2024-11-16 18:08:44] DEBUG : Length: 10
0131|[2024-11-16 18:08:44] DEBUG : Start decoding packet type 0x13
0132|[2024-11-16 18:08:44] DEBUG : Subtype = PT2262, EV1527 433.92MHz
0133|[2024-11-16 18:08:44] DEBUG : Data : {'packetlen': '0x09', 'packettype': '0x13', 'subtype': '0x00', 'seqnbr': '0xD2', 'cmd1': '0x78', 'cmd2': '0x5E', 'cmd3': '0x88', 'pulse': 336, 'filler': 0, 'rssi': 4}
0134|[2024-11-16 18:08:44] DEBUG : Decoded info : {'packettype': '0x13', 'subtype': '0x00', 'id': '785E88', 'pulse': 1344, 'rssi': 4}
0135|[2024-11-16 18:08:44] DEBUG : Device is known id : 785E88
De temps en temps seulement, malgré la présence de ces messages dans les logs, le bouton remonte dans l’interface :
Il y a bien répétition des valeurs identiques mais « pulse » ne change quasi jamais. J’ai mis un scénario déclenche par le pulse quand j’appuie sur le bouton, c’est très rare que cela fonctionne.
SI vous avez une idée.
