La réponse est contenue dans mes deux réponses plus haut
désolé je doit être vraiment bête je ne comprend pas
et
tout est là
Bon j’ai fait étape 2 puis 3
Et voila :
Mais tjr pas reconnu
As tu bien redémarré le démon Deconz puis rafraichis la page Jeedom ?
Oui et je viens de le refaire
Logs Deconz ?
000|Usage:
0001|kill [options] [...]
0002|Options:
0003| [...] send signal to every listed
0004|-, -s, --signal
0005|specify the to be sent
0006|-l, --list=[] list all signal names, or convert one to a name
0007|-L, --table list all signal names in a nice table
0008|-h, --help display this help and exit
0009|-V, --version output version information and exit
0010|For more details see kill(1).
0011|Usage:
0012|kill [options] [...]
0013|Options:
0014| [...] send signal to every listed
0015|-, -s, --signal
0016|specify the to be sent
0017|-l, --list=[] list all signal names, or convert one to a name
0018|-L, --table list all signal names in a nice table
0019|-h, --help display this help and exit
0020|-V, --version output version information and exit
0021|For more details see kill(1).
0022|Usage:
0023|kill [options] [...]
0024|Options:
0025| [...] send signal to every listed
0026|-, -s, --signal
0027|specify the to be sent
0028|-l, --list=[] list all signal names, or convert one to a name
0029|-L, --table list all signal names in a nice table
0030|-h, --help display this help and exit
0031|-V, --version output version information and exit
0032|For more details see kill(1).
0033|Usage:
0034|kill [options] [...]
0035|Options:
0036| [...] send signal to every listed
0037|-, -s, --signal
0038|specify the to be sent
0039|-l, --list=[] list all signal names, or convert one to a name
0040|-L, --table list all signal names in a nice table
0041|-h, --help display this help and exit
0042|-V, --version output version information and exit
0043|For more details see kill(1).
0044|Usage:
0045|kill [options] [...]
0046|Options:
0047| [...] send signal to every listed
0048|-, -s, --signal
0049|specify the to be sent
0050|-l, --list=[] list all signal names, or convert one to a name
0051|-L, --table list all signal names in a nice table
0052|-h, --help display this help and exit
0053|-V, --version output version information and exit
0054|For more details see kill(1).
0055|Usage:
0056|kill [options] [...]
0057|Options:
0058| [...] send signal to every listed
0059|-, -s, --signal
0060|specify the to be sent
0061|-l, --list=[] list all signal names, or convert one to a name
0062|-L, --table list all signal names in a nice table
0063|-h, --help display this help and exit
0064|-V, --version output version information and exit
0065|For more details see kill(1).
0066|Usage:
0067|kill [options] [...]
0068|Options:
0069| [...] send signal to every listed
0070|-, -s, --signal
0071|specify the to be sent
0072|-l, --list=[] list all signal names, or convert one to a name
0073|-L, --table list all signal names in a nice table
0074|-h, --help display this help and exit
0075|-V, --version output version information and exit
0076|For more details see kill(1).
0077|Usage:
0078|kill [options] [...]
0079|Options:
0080| [...] send signal to every listed
0081|-, -s, --signal
0082|specify the to be sent
0083|-l, --list=[] list all signal names, or convert one to a name
0084|-L, --table list all signal names in a nice table
0085|-h, --help display this help and exit
0086|-V, --version output version information and exit
0087|For more details see kill(1).
0088|Usage:
0089|kill [options] [...]
0090|Options:
0091| [...] send signal to every listed
0092|-, -s, --signal
0093|specify the to be sent
0094|-l, --list=[] list all signal names, or convert one to a name
0095|-L, --table list all signal names in a nice table
0096|-h, --help display this help and exit
0097|-V, --version output version information and exit
0098|For more details see kill(1).
0099|Usage:
0100|kill [options] [...]
0101|Options:
0102| [...] send signal to every listed
0103|-, -s, --signal
0104|specify the to be sent
0105|-l, --list=[] list all signal names, or convert one to a name
0106|-L, --table list all signal names in a nice table
0107|-h, --help display this help and exit
0108|-V, --version output version information and exit
0109|For more details see kill(1)
Tu as essayé de cliquer sur « installation deconz local » ? Comme décrit dans le §2
C’est les logs que tu obtiens a ce moment qui doivent etre intéressants.
Oui sa change rien
Donc si rien ne se passe, tu dois avoir un message d’erreur durant cette installation qui explique pourquoi rien ne change.
Bonsoir à tous, je tape l’incruste dans cette discussion car j’ai un pb d’appairage de ma sonde Owon THS317-ET dans Jeedom.
Avant de me faire engueuler, ma config :
- Jeedom V4.0.44 sur RPI 3B,
- plugin Deconz,
- dongle ConBee 2, version 2.17.01, firmware 26720700
Donc quand j’essaie d’appairer (ou d’ajouter) ma sonde avec Phoscon tout se passe bien, clignotements rouge puis quelques secondes après clignotements vert. J’en déduis que la sonde est reconnue par le système mais elle n’apparait nulle part.
Quelle est la solution ?
Merci d’avance
Hello, il te faut passer le status du DDF en « Gold » au lieu de « Bronze ». Et si tu as un compte github, demander a ce que ce soit fait officiellement une bonne fois pour toute.
Salut @HugoVal11 et merci pour ta réponse, j’avais lu cette manip sur le forum mais je pensais que c’était corrigé dans les dernières versions.
Pour procéder il faut déplugger le dongle ConBee 2 du Pi et le plugger sur un Pc pour accéder au fichier DDF ? ou peut-on le faire directement sans déplugger le dongle ? Merci d’avance
Ben je viens de vérifier, apparemment ils savent pas si le DDF fonctionne ou pas ^^.
Il y aurait des problemes divers, mais pas toujours les mêmes, et ça marche sans problemes chez certains, faut dire qu’il y a eu du mouvement sur ce DDF, et j’ai pas tout suivi, du coup il est toujours en « Bronze ».
Pour le passer en gold il te faut « juste » editer le fichier « devices/owon/THS317-ET_temperature_sensor.json » et passer le status en « Gold ».
C’est le plus simple, mais le fichier sera remit a zero a la prochaine MAJ de deconz si ils ne le passent pas en « Gold » de leur coté.
Sinon tu peux le mettre dans un répertoire a toi, mais c’est plus compliqué, il te faut creer le fichier json (ou juste en faire une copie)
All DDF provided directly with deCONZ typically reside in
/usr/share/deCONZ/devices/on a Linux system and are loaded first. However, files residing in the home directory of the user running deCONZ (e.g./home/<DECONZUSER>/.local/share/dresden-elektronik/deCONZ/devices) will override the pre-packaged files to allow users to amend and keep their own files if desired.
Suite au message de @HugoVal11, je me suis connecté en SSH avec Putty, j’ai trouvé le fichier json et je l’ai modifié pour le passer en Gold. Relance des dépendances et du démon Deconz. Tentative d’appairage, toujours pas visible ni dans Phoscon ni dans Jeedom, malgré le clignotement en vert.
Ben la je vois plus, ta méthode est bonne pour moi.
Tu es sur de ne pas avoir fais de faute de frappes quand tu as édité le fichier ? De mémoire vu que c’est un capteur de temperature basique, il apparait sans problemes dans phoscon.
Pour les clignotements (d’apres Test de la sonde de température déportée Zigbee Casa.IA CTHS-317-ET - Blog Domadoo)
Insérez les piles dans le module et assurez-vous que le voyant LED clignote en rouge, indiquant qu’il est prêt à rejoindre le réseau de la passerelle. (Sinon, réinitialisez-le aux paramètres d’usine par défaut).
Après quelques secondes, le module rejoindra le réseau Zigbee automatiquement et l’indicateur LED clignotera en vert. Dans le cas contraire il vous faudra effectuer un RESET du module en appuyant sur le bouton “Reset” et maintenez-le enfoncé pendant dix secondes (Le voyant LED clignotera trois fois à la troisième seconde et clignotera à nouveau à la dixième seconde.) Après 10 secondes, le module aura restauré les paramètres d’usine par défaut. Puis refaire la procédure d’inclusion.
Après la remarque de @HugoVal11, j’ai laissé tomber l’affaire, me suis renseigné auprès de Domodoo pour retourner le produit. Et là, bizarre, j’ai trouvé mon capteur dans Jeedom et dans Phoscon sans autre manip !!!
La température remonte bien et semble cohérente, par contre, pas de remontée du niveau des piles.
Mon DDF est en v2.18.00 avec le status modifié en Gold
