Solicitud para Aqara Motion Sensor RTCGQ11LM non reconnue
Cet appareil apparaît sur la liste de compatibilité, je pense que le fabricant a changé le firmware.
Informations techniques :
Image png
LUMI.lumi.sensor_motion.aq2
Informations techniques brutes
    "ieee": "00:15:8d:00:08:05:e3:0d",
    "nwk": 46845,
    "status": 2,
    "lqi": "216",
    "rssi": "-46",
    "last_seen": "1666682773.2545536",
    "node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 263,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.sensor_motion.aq2",
            "output_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "BasicCluster",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 1
                            "id": 1,
                            "name": "app_version",
                            "value": 5
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.sensor_motion.aq2"
                            "id": 6,
                            "name": "date_code",
                            "value": "20170627"
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "3000-0001"
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 32,
                            "name": "battery_voltage",
                            "value": 30.2
                            "id": 33,
                            "name": "battery_percentage_remaining",
                            "value": 146
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 2,
                    "name": "Device Temperature",
                    "attributes": [
                            "id": 0,
                            "name": "current_temperature",
                            "value": 2400
                    "id": 1024,
                    "name": "Illuminance Measurement",
                    "attributes": [
                            "id": 0,
                            "name": "measured_value",
                            "value": 8451.980400142567
                    "id": 1030,
                    "name": "Occupancy Sensing",
                    "attributes": [
                            "id": 0,
                            "name": "occupancy",
                            "value": 1
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 0,
                            "name": "zone_state",
                            "value": 1
                    "id": 65535,
                    "name": "Manufacturer Specific",
                    "attributes": []
    "signature": {
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4151,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 263,
                "input_clusters": [
                    0,
                    1,
                    3,
                    2,
                    1024,
                    1030,
                    1280,
                    65535
                    0,
                    25
    "class": "zhaquirks.xiaomi.aqara.motion_aq2"
et le log zigbee
zigbee.log (8,0 Ko)
zigbeed_1.log (71,9 Ko)
Acheteur en:
Toutes les informations nécessaires sont dans vos infos brutes donc pouvez-vous expliquer votre problème?
battery_voltage
value: 30.2 à diviser par 10
« current_temperature »,
« value »: 2400 à diviser par 100
Etc…
Bonjour, les commandes ne sont pas créées
Pouvez-vous créer vous même ces 2 commandes en info numérique pour voir si quelque chose remonte de votre équipement.
1::3::0
1::1::32
Commandes → ajouter une commande…
La première commande ne donne aucun résultat et la seconde donne 30.1
Donc vous avez bien un retour d’info du module.
Reste juste a déchiffrer les infos brutes que je regarderai demain.
Bonjour, au cas où cela vous aiderait.
J’ai essayé cette commande avec des données de température :
1::2::0
ce qui m’inquiète c’est qu’il a fallu beaucoup de temps pour répondre positivement, de plus les données ne sont pas mises à jour en heures et c’est impossible.
Bonjour, des nouvelles ?
