Smart air box zigbee envoi toutes les secondes
Mon capteur Smart air box _TZE200_yvx5lh6k est fonctionnel mais les données sont envoyées toutes les secondes par le capteur.
J’ai modifié dans la configuration du capteur les rapports sur les valeurs remonté pour mettre :
Min: 120, Max: 300, value:100 pour la temperature mais cela n’a rien changé.
Avez vous une idée pour faire en sorte que le capteur n’envoie pas des donnes toutes les 1 secondes?
Voici le détail de la configuration json :
    "name": "TZE200_yvx5lh6k.TS0601",
    "configuration": [],
    "commands": [
            "logicalId": "1::1026::0",
            "generic_type": "TEMPERATURE",
            "name": "Température",
            "type": "info",
            "subType": "numeric",
            "isHistorized": "1",
            "unite": "°C",
            "configuration": {
                "calculValueOffset": "#value# \/ 100",
                "minValue": "0",
                "maxValue": "50",
                "historyPurge": "-1 year",
                "repeatEventManagement": "never"
            "template": {
                "dashboard": "default",
                "mobile": "default"
            "isVisible": "1"
            "logicalId": "1::1029::0",
            "generic_type": "HUMIDITY",
            "name": "Humidité",
            "type": "info",
            "unite": "%",
            "configuration": {
            "template": {
                "mobile": "default"
            "isVisible": "1"
            "logicalId": "1::1037::0",
            "generic_type": "CO2",
            "name": "CO2",
            "type": "info",
            "unite": "ppm",
            "configuration": {
                "minValue": "0",
                "maxValue": "3000",
                "calculValueOffset": "#value# * 1000000",
                "historizeRound": "2",
            "template": {
                "mobile": "default"
            "isVisible": "1"
            "logicalId": "1::1067::0",
            "name": "Formaldehyde",
            "type": "info",
            "unite": "ppb",
            "configuration": {
                "minValue": "0",
                "maxValue": "3000",
                "calculValueOffset": "#value# * 10000000",
            "template": {
                "mobile": "default"
            "isVisible": "1"
            "logicalId": "1::1070::0",
            "name": "VOC",
            "type": "info",
            "unite": "ppb",
            "configuration": {
                "minValue": "0",
                "maxValue": "3000",
            "template": {
                "mobile": "default"
            "isVisible": "1"
    "ref": "TZE200_yvx5lh6k.TS0601"
Et voici la config brute :
    "ieee": "a4:c1:38:dd:6b:f2:8d:9e",
    "nwk": 41151,
    "status": 2,
    "lqi": "96",
    "rssi": "-76",
    "last_seen": "1649403414.0734828",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZE200_yvx5lh6k",
            "model": "TS0601",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 70
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_yvx5lh6k"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Tuya Manufacturer Specific",
                    "attributes": []
                    "id": 1037,
                    "name": "Carbon Dioxide (CO\u2082) Concentration",
                    "attributes": [
                            "id": 0,
                            "name": "measured_value",
                            "value": 0.000361
                    "id": 1067,
                    "name": "Formaldehyde Concentration",
                    "attributes": [
                            "id": 0,
                            "value": 0
                    "id": 1029,
                    "name": "Relative Humidity Measurement",
                    "attributes": [
                            "id": 0,
                            "value": 5400
                    "id": 1026,
                    "name": "Temperature Measurement",
                    "attributes": [
                            "id": 0,
                            "value": 1880
                    "id": 1070,
                    "name": "VOC Level",
                    "attributes": [
                            "id": 0,
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    4,
                    5,
                    61184,
                    1037,
                    1067,
                    1029,
                    1026,
                    1070
                    10,
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zhaquirks.tuya.air.ts0601_air_quality"
Pour compléter mon précédent message je met les logs qui montre le spam fait par le capteur :
[2022-04-25 18:41:53]INFO : Send to jeedom : {'devices': {'a4:c1:38:dd:6b:f2:8d:9e': {'1': {'1026': {'0': {'value': '2030', 'cluster_name': 'Temperature Measurement'}}, '61184': {'cmd': {'0': {'value': '2', 'cluster_name': 'Tuya Manufacturer Specific'}, '1': {'value': "TuyaCommand(status=0, tsn=0, dp=18, data=TuyaData(dp_type=, function=0, raw=b'\xcb\x00\x00\x00', *payload=203))", 'cluster_name': 'Tuya Manufacturer Specific'}}}}}}}
[2022-04-25 18:41:55]INFO : Send to jeedom : {'devices': {'a4:c1:38:dd:6b:f2:8d:9e': {'1': {'1026': {'0': {'value': '2030', 'cluster_name': 'Temperature Measurement'}}, '61184': {'cmd': {'0': {'value': '2', 'cluster_name': 'Tuya Manufacturer Specific'}, '1': {'value': "TuyaCommand(status=0, tsn=0, dp=19, data=TuyaData(dp_type=, function=0, raw=b'\xd7\x01\x00\x00', *payload=471))", 'cluster_name': 'Tuya Manufacturer Specific'}}}, '1029': {'0': {'value': '4710', 'cluster_name': 'Relative Humidity Measurement'}}}}}}
[2022-04-25 18:41:58]INFO : Send to jeedom : {'devices': {'a4:c1:38:dd:6b:f2:8d:9e': {'1': {'1026': {'0': {'value': '2020', 'cluster_name': 'Temperature Measurement'}}, '61184': {'cmd': {'0': {'value': '2', 'cluster_name': 'Tuya Manufacturer Specific'}, '1': {'value': "TuyaCommand(status=0, tsn=0, dp=18, data=TuyaData(dp_type=, function=0, raw=b'\xca\x00\x00\x00', *payload=202))", 'cluster_name': 'Tuya Manufacturer Specific'}}}, '1029': {'0': {'value': '4740', 'cluster_name': 'Relative Humidity Measurement'}}}}}}
[2022-04-25 18:42:00]INFO : Send to jeedom : {'devices': {'a4:c1:38:dd:6b:f2:8d:9e': {'1': {'1026': {'0': {'value': '2010', 'cluster_name': 'Temperature Measurement'}}, '61184': {'cmd': {'0': {'value': '2', 'cluster_name': 'Tuya Manufacturer Specific'}, '1': {'value': "TuyaCommand(status=0, tsn=0, dp=19, data=TuyaData(dp_type=, function=0, raw=b'\xdd\x01\x00\x00', *payload=477))", 'cluster_name': 'Tuya Manufacturer Specific'}}}, '1029': {'0': {'value': '4770', 'cluster_name': 'Relative Humidity Measurement'}}}}}}
[2022-04-25 18:42:03]INFO : Send to jeedom : {'devices': {'a4:c1:38:dd:6b:f2:8d:9e': {'1': {'1026': {'0': {'value': '2030', 'cluster_name': 'Temperature Measurement'}}, '61184': {'cmd': {'0': {'value': '2', 'cluster_name': 'Tuya Manufacturer Specific'}, '1': {'value': "TuyaCommand(status=0, tsn=0, dp=19, data=TuyaData(dp_type=, function=0, raw=b'\xd7\x01\x00\x00', *payload=471))", 'cluster_name': 'Tuya Manufacturer Specific'}}}, '1029': {'0': {'value': '4710', 'cluster_name': 'Relative Humidity Measurement'}}}}}}
[2022-04-25 18:42:05]INFO : Send to jeedom : {'devices': {'a4:c1:38:dd:6b:f2:8d:9e': {'1': {'1026': {'0': {'value': '2030', 'cluster_name': 'Temperature Measurement'}}, '61184': {'cmd': {'0': {'value': '2', 'cluster_name': 'Tuya Manufacturer Specific'}, '1': {'value': "TuyaCommand(status=0, tsn=0, dp=18, data=TuyaData(dp_type=, function=0, raw=b'\xcb\x00\x00\x00', *payload=203))", 'cluster_name': 'Tuya Manufacturer Specific'}}}}}}}
et le paramétrage fait pour limiter l’envoie :
Savez vous comment faire pour vérifier si le capteur prend bien en compte ces paramétres?
Oui ce capteur est connu pour ça. C’est pas de la super qualité.
J’ai exactement le même problème avec ces capteurs, avec une charge CPU énorme pour le démon Zigbee.
QUand je mets tes valeurs, ça ne change rien.
As tu trouvé une solution stp ?
Merci !
Oui retour a l’envoyeur. Le frient est très bien (mais moins complet) et remonte les infos toutes les cinq minutes (sauf changement) ce qui est largement suffisant.
Retour aussi à l’envoyeur ?
J’en ai acheté 3 :frowning:
Il était marqué comme intégré par Jeedom…
Compatible veut pas dire de qualité…
