Send command: ko: 401
depuis hier soir ou cette nuit, mon plugin Tahoma ne marche plus. J’ai le message d’erreur :
037|[2023-12-22 10:20:05][ERROR] : Erreur sur tahoma::pull() : Le nom de la commande ne peut pas être vide :tahomaCmd Object (     [id:protected] =>      [logicalId:protected] =>      [generic_type:protected] =>      [eqType:protected] =>      [name:protected] =>      [order:protected] =>      [type:protected] => action     [subType:protected] => other     [eqLogic_id:protected] => 259     [isHistorized:protected] => 0     [unite:protected] =>      [configuration:protected] => Array         (             [commandName] => execAction         )      [template:protected] =>      [display:protected] =>      [value:protected] =>      [isVisible:protected] => 1     [alert:protected] =>      [_collectDate:protected] =>      [_valueDate:protected] =>      [_eqLogic:protected] =>      [_needRefreshWidget:protected] => 1     [_needRefreshAlert:protected] =>      [_changed:protected] => 1 )
0038|[2023-12-22 10:30:54][DEBUG] : send command: ko: 401. Will retry
0039|[2023-12-22 10:30:54][DEBUG] : logon with xxxxxxxxxxxxxxx@gmail.com and cookie /tmp/tahomacurlcookie
0040|[2023-12-22 10:30:55][DEBUG] : new cookie - logon: ok: 200
0041|[2023-12-22 10:30:55][DEBUG] : send command bis: ko: 401
0042|[2023-12-22 10:30:55][DEBUG] : send command: ko: 401. Will retry
0043|[2023-12-22 10:30:55][DEBUG] : logon with xxxxxxxxxxxxxxx@gmail.com and cookie /tmp/tahomacurlcookie
0044|[2023-12-22 10:30:55][DEBUG] : new cookie - logon: ok: 200
0045|[2023-12-22 10:30:56][DEBUG] : send command bis: ko: 401
0046|[2023-12-22 10:30:56][DEBUG] : eqlabel: ActionGroups
0047|[2023-12-22 10:30:56][DEBUG] : send command: ko: 401. Will retry
0048|[2023-12-22 10:30:56][DEBUG] : logon with xxxxxxxxxxxxxxx@gmail.com and cookie /tmp/tahomacurlcookie
0049|[2023-12-22 10:30:56][DEBUG] : new cookie - logon: ok: 200
0050|[2023-12-22 10:30:56][DEBUG] : send command bis: ko: 401
0051|[2023-12-22 10:30:56][ERROR] : Erreur sur tahoma::pull() : Le nom de la commande ne peut pas être vide :tahomaCmd Object (     [id:protected] =>      [logicalId:protected] =>      [generic_type:protected] =>      [eqType:protected] =>      [name:protected] =>      [order:protected] =>      [type:protected] => action     [subType:protected] => other     [eqLogic_id:protected] => 259     [isHistorized:protected] => 0     [unite:protected] =>      [configuration:protected] => Array         (             [commandName] => execAction         )      [template:protected] =>      [display:protected] =>      [value:protected] =>      [isVisible:protected] => 1     [alert:protected] =>      [_collectDate:protected] =>      [_valueDate:protected] =>      [_eqLogic:protected] =>      [_needRefreshWidget:protected] => 1     [_needRefreshAlert:protected] =>      [_changed:protected] => 1 )
0052|[2023-12-22 10:33:37][DEBUG] : send command: ko: 401. Will retry
0053|[2023-12-22 10:33:37][DEBUG] : logon with xxxxxxxxxxx@gmail.com and cookie /tmp/tahomacurlcookie
0054|[2023-12-22 10:33:38][DEBUG] : new cookie - logon: ok: 200
0055|[2023-12-22 10:33:38][DEBUG] : send command bis: ko: 401
0056|[2023-12-22 10:33:38][DEBUG] : send command: ko: 401. Will retry
0057|[2023-12-22 10:33:38][DEBUG] : logon with xxxxxxxxxxxxxxx@gmail.com and cookie /tmp/tahomacurlcookie
0058|[2023-12-22 10:33:39][DEBUG] : new cookie - logon: ok: 200
0059|[2023-12-22 10:33:39][DEBUG] : send command bis: ko: 401
On voit bien que l’auth passe (j’ai un logon ok 200), mais ensuite rien ne va plus…
Bonjour, J’ai le même soucis que vous et je n’arrive pas à piloter mon thermostat somfy V2. Les infos et les commandes remontent, mais impossible de lui faire exécuter une action.
[2024-02-14 01:48:11][DEBUG] : logon with xxxxx@xxxxxxx.com and cookie /tmp/tahomacurlcookie
[2024-02-14 01:48:11][DEBUG] : new cookie - logon: ok: 200
[2024-02-14 01:48:12][DEBUG] : eqlabel: ActionGroups
[2024-02-14 02:03:04][DEBUG] : send command: ko: 401. Will retry
et lors de l’envoi d’une action :
[2024-02-14 10:36:42][DEBUG] : {« label »:« Eco »,« actions »:[{« deviceURL »:« somfythermostat://SOMFY_THERMOSTAT-57431/213103483435#1 »,« commands »:[{« name »:« setHeatingLevel »,« parameters »:[« eco »]}]}]}
[2024-02-14 10:36:42][DEBUG] : send command: {« errorCode »:« UNSUPPORTED_OPERATION »,« error »:« No such command : setHeatingLevel on device somfythermostat://SOMFY_THERMOSTAT-57431/213103483435#1 (somfythermostat:SomfyThermostatThermostatComponent) »}
[2024-02-14 10:36:42][DEBUG] : return cancelExecutions: ()
[2024-02-14 10:36:42][DEBUG] : set cancelExecutions: ()
