Depuis longtemps, je pilote mes prises Belkin Wemo via des scripts. Voici le script en question:
#!/bin/bash
# Name: wemo_control.sh
# Usage: [IP] [ON|OFF|GETSTATE|GETSIGNALSTRENGTH|GETFRIENDLYNAME]
# Description:
# Created: 2015-07-30
# Last Modified:
# Copyright 2014, Victor Mendonca - http://wazem.org
# License: Released under the terms of the GNU GPL license v3
# Sets variables
USAGE="wemo_control.sh [IP|network] [on|off|getstate|getsignal|getname|find]"
#if [[ $# -ne 2 ]] ; then
# echo "$USAGE"
# exit 0
#fi
IP="$1"
CMD="$2"
# Functions
getPort () {
PORTTEST=$(curl -s "$IP":49152 | grep "404")
if [ "$PORTTEST" = "" ] ; then
PORT=49153
else
PORT=49152
fi
turnON () {
getPort
curl -0 -A -m 5 '' -X POST -H 'Accept: ' -H \
'Content-type: text/xml; charset="utf-8"' -H \
"SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data \
'<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' \
-s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut -d">" \
-f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g'
turnOFF () {
getPort
'<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>0</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' \
-s http://$IP:$PORT/upnp/control/basicevent1 | grep "<BinaryState" | cut \
-d">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g'
getName () {
getPort
"SOAPACTION: \"urn:Belkin:service:basicevent:1#GetFriendlyName\"" --data \
'<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetFriendlyName xmlns:u="urn:Belkin:service:basicevent:1"><FriendlyName></FriendlyName></u:GetFriendlyName></s:Body></s:Envelope>' \
-s http://$IP:$PORT/upnp/control/basicevent1 | grep "<FriendlyName" | cut \
getState () {
getPort
"SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" \
--data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' \
getSigStrength () {
getPort
'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetSignalStrength\"" \
--data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetSignalStrength xmlns:u="urn:Belkin:service:basicevent:1"><GetSignalStrength>0</GetSignalStrength></u:GetSignalStrength></s:Body></s:Envelope>' \
-s http://$IP:$PORT/upnp/control/basicevent1 | grep "<SignalStrength" | cut \
findDevices () {
which nmap > /dev/null || \
( echo "nmap is not installed and it's needed for this option" ; exit 1 )
echo "$IP" | grep -q '\*'
if [[ $? -ne 0 ]] ; then
echo "You need to provide a network for this option. It should be similar \
to 1.1.1.*"
exit 1
fi
echo "Finding. This may take a while..."
DEVICES=$(nmap -p 49153 --open "$IP" | grep 'scan report for' | awk '{print $5}')
if [ "$DEVICES" ] ; then
echo "IP NAME"
echo "---------------------"
for DEVICE in $DEVICES ; do
IP="$DEVICE"
echo "$DEVICE $(getName )"
done
else
echo "Did not find any devices"
fi
# Starts script
case "$CMD" in
on) turnON ;;
off) turnOFF ;;
getstate) getState ;;
getsignal) getSigStrength ;;
getname) getName ;;
find) findDevices ;;
*) echo "Unknown option" && exit 1 ;;
esac
exit 0
Je viens de m’apercevoir que cela ne fonctionne plus via l’interface de jeedom. Je suis donc allé en ssh pour exécuter le script, et je n’ai aucune réponse. Sur une autre machine (linux), j’ai ceci:
sh-3.2# ./wemo_control.sh 192.168.249.225 getstate
OFF
Par contre, exécuté depuis jeedom, je n’ai pas de réponse, que ce soit pour le getstate, le on ou bien le off (qui fonctionnent depuis l’autre machine). J’ai l’impression que le script tourne à l’infini. Je ne saurais dire depuis quand.
Mon script est dans /var/www/html/plugins/script/data/, et les droits sont les suivants:
-rwxrwxr-x 1 www-data www-data 5394 oct. 30 2017 wemo_control-pc1.sh
Sauriez vous me conseiller pour débugger la chose?
Merci d’avance
Matériel: raspberry pi3B+
Version Jeedom: 4.0.61
Version plugin script: 2020-06-24 09:18:07
Version Database: 10.3.23-MariaDB-0+deb10u1
Version PHP: 7.3.19-1~deb10u1
Version OS: Linux raspberrypi 5.4.61-v7+ #1339 SMP Tue Sep 1 18:45:30 BST 2020 armv7l GNU/Linux [10.4]
