[2020-08-28 15:07:42][DEBUG] : ┌───────── Début de Mise à jour
[2020-08-28 15:07:42][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-08-28 15:07:42][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"mac":"70:FC:8F:68:4C:EA","sensors":[{"id":"temp_hdd0","name":"Disque dur 1","value":47},{"id":"temp_t2","name":"Température 2","value":53},{"id":"temp_t1","name":"Température 1","value":49},{"id":"temp_t3","name":"Température 3","value":47},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":79},{"id":"temp_cpu_ap","name":"Température CPU AP","value":62},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":80}],"model_info":{"has_dect":true,"wifi_type":"2d4_5g_5g","has_home_automation":true,"customer_hdd_slots":4,"name":"fbxgw7-r1\/full","has_lan_sfp":true,"internal_hdd_size":0,"pretty_name":"Freebox v7 (r1)","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1513},{"id":"fan0_speed","name":"Ventilateur 1","value":1401}],"expansions":[{"type":"unknown","present":false,"slot":1,"probe_done":true,"supported":false,"bundle":""},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955800J202502138"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"1 jour 3 minutes 50 secondes","uptime_val":86630,"user_main_storage":"Freebox","box_authenticated":true,"serial":"957603J193501256","firmware_version":"4.2.3"}}
[2020-08-28 15:07:42][DEBUG] : └─────────
[2020-08-28 15:07:53][DEBUG] : ┌───────── Ajout des commandes : Air Média
[2020-08-28 15:07:53][DEBUG] : │ Application des Widgets ou Icônes pour le core V3
[2020-08-28 15:07:54][DEBUG] : ┌───────── Début de Mise à jour
[2020-08-28 15:07:54][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-08-28 15:07:54][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"mac":"70:FC:8F:68:4C:EA","sensors":[{"id":"temp_hdd0","name":"Disque dur 1","value":47},{"id":"temp_t2","name":"Température 2","value":53},{"id":"temp_t1","name":"Température 1","value":49},{"id":"temp_t3","name":"Température 3","value":47},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":80},{"id":"temp_cpu_ap","name":"Température CPU AP","value":62},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":80}],"model_info":{"has_dect":true,"wifi_type":"2d4_5g_5g","has_home_automation":true,"customer_hdd_slots":4,"name":"fbxgw7-r1\/full","has_lan_sfp":true,"internal_hdd_size":0,"pretty_name":"Freebox v7 (r1)","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1513},{"id":"fan0_speed","name":"Ventilateur 1","value":1400}],"expansions":[{"type":"unknown","present":false,"slot":1,"probe_done":true,"supported":false,"bundle":""},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955800J202502138"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"1 jour 4 minutes 2 secondes","uptime_val":86642,"user_main_storage":"Freebox","box_authenticated":true,"serial":"957603J193501256","firmware_version":"4.2.3"}}
[2020-08-28 15:07:54][DEBUG] : └─────────
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Home Adapters ==================
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Disque Dur ==================
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Fbx Wifi ==================
[2020-08-28 15:10:32][DEBUG] : ┌───────── Début de Mise à jour
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"enabled":true,"mac_filter_state":"disabled"}}
[2020-08-28 15:10:32][DEBUG] : └─────────
[2020-08-28 15:10:32][DEBUG] : >───────── Traitement de la Mise à jour de wifi/config avec la valeur : 1
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Système ==================
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"mac":"70:FC:8F:68:4C:EA","sensors":[{"id":"temp_hdd0","name":"Disque dur 1","value":47},{"id":"temp_t2","name":"Température 2","value":53},{"id":"temp_t1","name":"Température 1","value":49},{"id":"temp_t3","name":"Température 3","value":47},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":79},{"id":"temp_cpu_ap","name":"Température CPU AP","value":62},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":80}],"model_info":{"has_dect":true,"wifi_type":"2d4_5g_5g","has_home_automation":true,"customer_hdd_slots":4,"name":"fbxgw7-r1\/full","has_lan_sfp":true,"internal_hdd_size":0,"pretty_name":"Freebox v7 (r1)","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1513},{"id":"fan0_speed","name":"Ventilateur 1","value":1401}],"expansions":[{"type":"unknown","present":false,"slot":1,"probe_done":true,"supported":false,"bundle":""},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955800J202502138"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"1 jour 6 minutes 40 secondes","uptime_val":86800,"user_main_storage":"Freebox","box_authenticated":true,"serial":"957603J193501256","firmware_version":"4.2.3"}}
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Téléchargements ==================
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/downloads/stats/(null)
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"throttling_rate":{"rx_rate":0,"tx_rate":0},"nb_tasks_stopped":0,"dht_stats":{"enabled":false,"node_count_ipv6":0,"enabled_ipv6":false,"node_count":0},"nb_tasks_checking":0,"nb_tasks_queued":0,"blocklist_hits":0,"blocklist_entries":0,"nb_tasks_extracting":0,"nb_tasks_done":0,"nb_tasks_stopping":0,"nzb_config_status":{"status":"error","error":"connection_refused"},"conn_ready":true,"nb_peer":0,"throttling_mode":"normal","nb_tasks_active":0,"nb_tasks_seeding":0,"nb_tasks_error":0,"tx_rate":0,"nb_tasks_repairing":0,"nb_tasks":0,"nb_rss":0,"nb_tasks_downloading":0,"nb_rss_items_unread":0,"rx_rate":0,"throttling_is_scheduled":false}}
[2020-08-28 15:10:32][DEBUG] : ================= CRON pour l'actualisation de : Téléphone ==================
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/call/log/([])
[2020-08-28 15:10:32][DEBUG] : │ [FreeboxRequest] {"success":true,"result":[{"number":"0186612881","type":"missed","id":2,"duration":31,"datetime":1598528002,"contact_id":0,"line_id":0,"name":"0186612881","new":true},{"number":"0988290739","type":"missed","id":1,"duration":23,"datetime":1597940580,"contact_id":0,"line_id":0,"name":"0988290739","new":true}]}
[2020-08-28 15:10:32][DEBUG] : >───────── Nb Appels manqués : 0 -- Liste des appels manqués :
[2020-08-28 15:10:32][DEBUG] : >───────── Nb Appels reçus : 0 -- Liste des appels reçus :
[2020-08-28 15:10:32][DEBUG] : >───────── Nb Appels passés : 0 -- Liste des appels passés :
