Saturé de messages d'alertes
Je suis 4.2.14 sur VM proxmox nuc i7, depuis ce matin je suis inondé de messages de JMQTT sur le dashborad qui concerne l’équipement ID 747 qui est le broker local
Comment arréter tous ces messages ??
Le journal du demon indique :
[2022-03-27 09:10:29,218][INFO]     : BrkId:  747 : Message received (topic="ESP_Easy_Hygrometre_2/Hygrometre/Temperature", payload="25.40", QoS=0, retain=False)
[2022-03-27 09:10:29,294][INFO]     : BrkId:  747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/Hygrometre/Temperature", "payload": "25.40", "qos": 0, "retain": false}
[2022-03-27 09:10:30,219][INFO]     : BrkId:  747 : Message received (topic="ESP_Easy_Hygrometre_2/Hygrometre/Humidity", payload="55.30", QoS=0, retain=False)
[2022-03-27 09:10:30,296][INFO]     : BrkId:  747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/Hygrometre/Humidity", "payload": "55.30", "qos": 0, "retain": false}
[2022-03-27 09:10:31,223][INFO]     : BrkId:  747 : Message received (topic="ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", payload="0", QoS=0, retain=False)
[2022-03-27 09:10:31,299][INFO]     : BrkId:  747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", "payload": "0", "qos": 0, "retain": false}
[2022-03-27 09:10:34,343][INFO]     : BrkId:  747 : Message received (topic="ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", payload="0", QoS=0, retain=False)
[2022-03-27 09:10:34,407][INFO]     : BrkId:  747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", "payload": "0", "qos": 0, "retain": false}
[2022-03-27 09:10:39,341][INFO]     : BrkId:  747 : Message received (topic="ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", payload="0", QoS=0, retain=False)
[2022-03-27 09:10:39,418][INFO]     : BrkId:  747 : Sending message to Jeedom : {"cmd": "messageIn", "topic": "ESP_Easy_Hygrometre_2/DetecteurInfrarouge/State", "payload": "0", "qos": 0, "retain": false}
Page santé :
Même constat pour moi ce matin avec un bombardement de messages jmqtt.
Cordialement
Ah, tu me rassures !!
Je cherche depuis ce matin, sans succès, le dashboard est inondé de messages !!
Tu crois que ça peut venir du plugin lui-même, sans mise a jour ?
==> j’ai redémarré jeedom, pour l’instant, plus cette salve incessante de messages
Idem il n’a pas aimé le changement d’horaire…
Oui, c’est le changement d’horaire, comme le bug de l’an 2000 lol
Allez sur la page de configuration du plugin et cliquez sur Désactiver, puis Activer.
Capture d’écran 2022-03-27 à 09.50.43
bonjour,
Relancer le demon tout simplement !
Pas eu ce phénomène chez moi.
Hello et merci pour ce signalement !
@leojeedom, @kwet, vous avez quoi comme système ? Pareil, un nuc et Proxmox ?
Quelles versions de Jeedom et jMQTT svp ?
Vous avez bien un serveur NTP correctement configuré ?
Vous avez des crons planifiés dans Jeedom ou sur le système entre 2h et 3h ?
@Flobul, @olive, vous avez eu des soucis et vous avez dû relancer ? (si oui, mêmes questions :wink: )
De mon coté, pas eu de souci sur VMWare, NAS Syno, ni Raspbery Pi…
J’attends vos réponses pour savoir s’il y a quelque chose à faire de notre coté ou non.
Jeedom v4.2.14
Oui, cascade de messages comme le premier post.
J’ai 2 brokers distants et un local.
En relançant le démon, ça continuait d’envoyer les message.
En arrêtant le plugin et relançant, tout est revenu à la normale.
Je n’ai pas analysé plus loin que ça.
Je voulais écrire 4.2.14, Bad
Bonjour Bad,
Pour ma part j’ai eu le même souci que doryphore ce matin aussi.
Jeedom 42.14 sur Pi4/4Go
Rasbian Buster 64bits 10.12
Plugin Beta (sur conseille d’Olive) en date du 2022-03-08 01:01:20
Redémarrage de Jeedom et plus de message depuis
j’ai pas eu le problème tu sais bien que avec la fuite mémoire je relance automatiquement mon demon toute les 2 heures.
Jeedom 4.2.14 sur Pi4/4Go
Rasbian Buster 32 bits
Zigbee2mqtt avec une conbee2
Plugin jmqtt version stable
Pour dépanner j’ai lancé un reboot de mon pi, l’heure était ok sur celui-ci pour info avant le reboot
Désolé, je ne vois pas vraiment de lien entre les installs…
Je pense donc que c’est l’accès à la base de donnée dans le daemon PHP qui a partiellement crashé, ça s’est déjà vu ici ou .
Ce daemon pose un nombre important de problèmes et nous allons le supprimer à moyen terme, comprendre très probablement avant le prochain changement d’heure.
Si ça vous convient, je vous propose de clore ce sujet.
Jeedom 4.1.28
Pas de problème chez moi si ça peut aiguiller.
4.2.13 sur Pi 4, debian buster.
jmqtt version beta du 08-03-2022
Aucun pb ce matin
J’ai également eu le symptôme de message en provenance de jmqtt.
Pour ma part j’ai eu ce comportement après la mise à jour de MariaDB. Et effectivement après reboot de Jeedom plus d’incident.
