[2021-10-28 18:23:40][DEBUG] : Message: 08500a261101009a30
[2021-10-28 18:23:40][DEBUG] : Decode : 08500a261101009a30
[2021-10-28 18:23:40][DEBUG] : Test message: 08500a261101009a30
[2021-10-28 18:23:40][DEBUG] : PacketType: 0x50
[2021-10-28 18:23:40][DEBUG] : Length: 9
[2021-10-28 18:23:40][DEBUG] : Start decoding packet type 0x50
[2021-10-28 18:23:40][DEBUG] : Subtype = TEMP10 is TFA 30.3133, 30.3056, 30.3160 pool sensor
[2021-10-28 18:23:40][DEBUG] : Data : {‹ packetlen ›: ‹ 0x08 ›, ‹ packettype ›: ‹ 0x50 ›, ‹ subtype ›: ‹ 0x0A ›, ‹ seqnbr ›: ‹ 0x26 ›, ‹ id1 ›: ‹ 0x11 ›, ‹ id2 ›: ‹ 0x01 ›, ‹ temperaturesign ›: ‹ ›, ‹ temperature ›: 154, ‹ battery ›: 10, ‹ rssi ›: 3}
[2021-10-28 18:23:40][DEBUG] : Decoded info : {‹ packettype ›: ‹ 0x50 ›, ‹ subtype ›: ‹ 0x0A ›, ‹ id ›: ‹ 1101 ›, ‹ temperature ›: ‹ 15.4 ›, ‹ battery ›: 10, ‹ rssi ›: 3}
[2021-10-28 18:23:40][DEBUG] : unknown device id : 1101
[2021-10-28 18:24:16][DEBUG] : Message: 08500a271101009a30
[2021-10-28 18:24:16][DEBUG] : Decode : 08500a271101009a30
[2021-10-28 18:24:16][DEBUG] : Test message: 08500a271101009a30
[2021-10-28 18:24:16][DEBUG] : PacketType: 0x50
[2021-10-28 18:24:16][DEBUG] : Length: 9
[2021-10-28 18:24:16][DEBUG] : Start decoding packet type 0x50
[2021-10-28 18:24:16][DEBUG] : Subtype = TEMP10 is TFA 30.3133, 30.3056, 30.3160 pool sensor
[2021-10-28 18:24:16][DEBUG] : Data : {‹ packetlen ›: ‹ 0x08 ›, ‹ packettype ›: ‹ 0x50 ›, ‹ subtype ›: ‹ 0x0A ›, ‹ seqnbr ›: ‹ 0x27 ›, ‹ id1 ›: ‹ 0x11 ›, ‹ id2 ›: ‹ 0x01 ›, ‹ temperaturesign ›: ‹ ›, ‹ temperature ›: 154, ‹ battery ›: 10, ‹ rssi ›: 3}
[2021-10-28 18:24:16][DEBUG] : Decoded info : {‹ packettype ›: ‹ 0x50 ›, ‹ subtype ›: ‹ 0x0A ›, ‹ id ›: ‹ 1101 ›, ‹ temperature ›: ‹ 15.4 ›, ‹ battery ›: 10, ‹ rssi ›: 3}
[2021-10-28 18:24:16][DEBUG] : unknown device id : 1101
[2021-10-28 18:24:53][DEBUG] : Message: 08500a281101009b30
[2021-10-28 18:24:53][DEBUG] : Decode : 08500a281101009b30
[2021-10-28 18:24:53][DEBUG] : Test message: 08500a281101009b30
[2021-10-28 18:24:53][DEBUG] : PacketType: 0x50
[2021-10-28 18:24:53][DEBUG] : Length: 9
[2021-10-28 18:24:53][DEBUG] : Start decoding packet type 0x50
[2021-10-28 18:24:53][DEBUG] : Subtype = TEMP10 is TFA 30.3133, 30.3056, 30.3160 pool sensor
[2021-10-28 18:24:53][DEBUG] : Data : {‹ packetlen ›: ‹ 0x08 ›, ‹ packettype ›: ‹ 0x50 ›, ‹ subtype ›: ‹ 0x0A ›, ‹ seqnbr ›: ‹ 0x28 ›, ‹ id1 ›: ‹ 0x11 ›, ‹ id2 ›: ‹ 0x01 ›, ‹ temperaturesign ›: ‹ ›, ‹ temperature ›: 155, ‹ battery ›: 10, ‹ rssi ›: 3}
[2021-10-28 18:24:53][DEBUG] : Decoded info : {‹ packettype ›: ‹ 0x50 ›, ‹ subtype ›: ‹ 0x0A ›, ‹ id ›: ‹ 1101 ›, ‹ temperature ›: ‹ 15.5 ›, ‹ battery ›: 10, ‹ rssi ›: 3}
[2021-10-28 18:24:53][DEBUG] : unknown device id : 1101
